    How to check version of MM
    4 Posts 2 Posters 6.7k Views 2 Watching
    • foxF Offline
      fox
      Hi
      how can i check the version of my Magic Mirror?
      Issues With MMM-WatchDog known?
      https://forum.magicmirror.builders/post/29827
      Useful for PIR-Sensor: https://forum.magicmirror.builders/post/21299
        A Former User @fox
        @fox
        Log will show which version is running, at the start moment.
        Starting MagicMirror: v2.4.1
        Loading config ...
        Loading module helpers ...
          A Former User @Guest
          Or you can check version from package.json (in MagicMirror directory)
            "name": "magicmirror",
            "version": "2.4.1",
            "description": "The open source modular smart mirror platform.",
            "main": "js/electron.js",
            "scripts": {
          But it could be different with your current running instance.
          foxF 1 Reply Last reply Reply Quote 0
          • foxF Offline
            fox @Guest
            @sean said in How to check version of MM:
              "version": "2.4.1",
              "scripts": {
            that worked for me thank you !!
