    Failed at the magicmirror@2.0.0 start script 'electron js/electron.js'.
    9 Posts 4 Posters 6.5k Views 4 Watching
      Jakllo
      I did just install MagicMirror with the tutorial in the hardware forum, no errors until the last step to run it.
      pi@magicpi:~/MagicMirror $ npm start
      -> magicmirror@2.0.0 start /home/pi/MagicMirror
      -> electron js/electron.js
      npm ERR! Linux 4.4.19-v7+
      npm ERR! argv “/usr/local/bin/node” “/usr/local/bin/npm” “start”
      npm ERR! node v4.0.0
      npm ERR! npm v2.14.2
      npm ERR! code ELIFECYCLE
      npm ERR! magicmirror@2.0.0 start: electron js/electron.js
      npm ERR! Exit status 1
      npm ERR!
      npm ERR! Failed at the magicmirror@2.0.0 start script ‘electron js/electron.js’.
      npm ERR! This is most likely a problem with the magicmirror package,
      npm ERR! not with npm itself.
      npm ERR! electron js/electron.js
      npm ERR! You can get their info via:
      npm ERR! npm owner ls magicmirror
      npm ERR! /home/pi/MagicMirror/npm-debug.log
      pi@magicpi:~/MagicMirror $ nano /home/pi/MagicMirror/npm-debug.log =
      1 verbose cli [ ‘/usr/local/bin/node’, ‘/usr/local/bin/npm’, ‘start’ ]
      2 info using npm@2.14.2
      3 info using node@v4.0.0
      4 verbose run-script [ ‘prestart’, ‘start’, ‘poststart’ ]
      5 info prestart magicmirror@2.0.0
      6 info start magicmirror@2.0.0
      7 verbose unsafe-perm in lifecycle true
      8 info magicmirror@2.0.0 Failed to exec start script
      9 verbose stack Error: magicmirror@2.0.0 start: electron js/electron.js
      9 verbose stack Exit status 1
      9 verbose stack at EventEmitter. (/usr/local/lib/node_modules/npm/lib/utils/lifecycle.js:214:16)
      9 verbose stack at emitTwo (events.js:87:13)
      9 verbose stack at EventEmitter.emit (events.js:172:7)
      9 verbose stack at ChildProcess. (/usr/local/lib/node_modules/npm/lib/utils/spawn.js:24:14)
      9 verbose stack at ChildProcess.emit (events.js:172:7)
      9 verbose stack at maybeClose (internal/child_process.js:817:16)
      9 verbose stack at Process.ChildProcess._handle.onexit (internal/child_process.js:211:5)
      10 verbose pkgid magicmirror@2.0.0
      11 verbose cwd /home/pi/MagicMirror
      12 error Linux 4.4.19-v7+
      13 error argv “/usr/local/bin/node” “/usr/local/bin/npm” “start”
      14 error node v4.0.0
      15 error npm v2.14.2
      16 error code ELIFECYCLE
      17 error magicmirror@2.0.0 start: electron js/electron.js
      17 error Exit status 1
      18 error Failed at the magicmirror@2.0.0 start script ‘electron js/electron.js’.
      18 error This is most likely a problem with the magicmirror package,
      18 error not with npm itself.
      18 error Tell the author that this fails on your system:
      18 error electron js/electron.js
      18 error You can get their info via:
      18 error npm owner ls magicmirror
      18 error There is likely additional logging output above.
      19 verbose exit [ 1, true ]
      Raspberry pi3, what is wrong? I know nothing about linux…
      If i use “node serveronly” I can connect to it from the desktop.
      • cowboysdudeC Offline
        “npm install electron” from a terminal window without quotes…
        • strawberry 3.141S Offline
          that must be a pretty old turorial when your running node on version 4
          i would recommend to take this tutorial https://forum.magicmirror.builders/topic/236/complete-setup-tutorial
            Listen to Strawberry, he knows. I didn’t realize it was old. His answer is much better
              Jakllo @strawberry 3.141
              @strawberry-3.141 said in Failed at the magicmirror@2.0.0 start script 'electron js/electron.js'.:
              I did follow that guide at first, same error. After some google someone said to install that specific version, still same error. Now I don’t know how to update it :)
              @cowboysdude said in Failed at the magicmirror@2.0.0 start script 'electron js/electron.js'.:
              Still same error.
              pi@magicpi:~/MagicMirror $ sudo npm install electron
              -> electron@1.3.4 postinstall /home/pi/MagicMirror/node_modules/electron
              -> node install.js
              Downloading electron-v1.3.4-linux-arm.zip
              [============================================>] 100.0% of 37.04 MB (1.48 MB/s)
              electron@1.3.4 node_modules/electron
              npm ERR!
              GNU nano 2.2.6 File: /home/pi/MagicMirror/npm-debug.log
              9 verbose stack at EventEmitter. (/usr/local/lib/node_modules/npm/lib/utils/lifecy$
              9 verbose stack at ChildProcess. (/usr/local/lib/node_modules/npm/lib/utils/spawn.$
                Well my first time I ended up going to the magic mirror dir in terminal and installed node.js and elec myself. Then it worked. Look up how to install node and elec. they will give the commands to do it. That’s how I did it. For some reason when I had to redo everything I downloaded magic mirror and installed it directly from my sd card and it went without issue
                  amanzimdwini @Jakllo
                  @Jakllo
                  I initially had that problem too - you need to be logged in as PI - not root.
                  I’d suggest starting all over: it really wont take that long. Follow the
                  tutorial @strawberry-3-141 mentioned (https://forum.magicmirror.builders/topic/236/complete-setup-tutorial) to the letter. It was written by @KirAsh4 & made all of my problem go away. I have now done it 4 times, getting it done in less than an hour from unpacking to having it all run!
                  My raspberry all of a sudden even connected via WiFi, and I am expecting my hair to grow back any day now.
                  I’m telling you - pure magic, these guys.
                  All the best
                  cowboysdudeC J 2 Replies Last reply Reply Quote 2
                    cowboysdude Module Developer @amanzimdwini
                    @amanzimdwini said in Failed at the magicmirror@2.0.0 start script 'electron js/electron.js'.:
                    @Jakllo
                    All the best
                    ^ This… yes do that!
                      Jakllo @amanzimdwini
                      @Jakllo
                      All the best
                      Thank you very much, it works now!
                      Before I used Putty after SSH got enabled, logged in with pi/raspberry login.
