    Add an external output to Dash Board from an html or Xml file.
    3 Posts 2 Posters 1.7k Views 2 Watching
    • O
      ooskay
      I would like to display content in an html file on the dashboard.
      http://serverip/mirror.hmtl or http://serverip/mirror.xml
      content in it will be looks like :
      TotalSales:100
      TopSeller:Jhon
      TopItem:Book
      how i can able to do that?
      thanks advance…
        Charley Module Developer
        You try to get the data in JSON format and with a node_helper make a small module that reads the data and displays it. There are several modules where you can see how to retrieve data. You can look at the code from my Domoticz module
        MMM-Bose-Soundtouch, MMM-Domoticz, MMM-crypto-portfolio, MMM-Fibaro, MMM-rain-forecast
        • O
          ooskay
          @charley said in Add an external output to Dash Board from an html or Xml file.:
          Domoticz module
          Thanks for the reply. Yes, i think JSON is best solution at this moment. Thanks again for your kindly respond…
