    Calendar Font Size
    13 Posts 2 Posters 11.9k Views 2 Watching
      DerOptiker86
      Hi there builders!
      I build up my MM and try to install some modules.
      After all i get it to run the modules and placed them in the righ space of the mirror.
      I also read the CSS tut and read all the topics in the CSS Blog… but there is a hole in my head and i can’t understand what’s wrong in my custom.css file…
      I try some ways to change font size of my calendar that is pointed on the top center.
      I like to show up it a little bit bigger.
      and second prob is… if I change the font size of my clock it clips into my date… is there a line i forgot to @?
      So what`s my fault? Sorry but i don’t get it :(
      Thats my custom.css file and my screen
      .body {
      .clock .time {
                            font-size 60px;
                            color: blue;
      .clock .date {
                           font-size: 30px
      .calendar {
                       font-size: 200px
      greetz from germany
      • justjim1220J Offline
        justjim1220 Module Developer @DerOptiker86
        @deroptiker86
        Add this from the calendar.css to your custom.css…
        .calendar .symbol {
          padding-left: 0;
          padding-right: 10px;
          font-size: 80%;
          vertical-align: top;
        .calendar .symbol span {
          display: inline-block;
          -ms-transform: translate(0, 2px); /* IE 9 */
          -webkit-transform: translate(0, 2px); /* Safari */
        .calendar .title {
          padding-left: 0;
          padding-right: 0;
        .calendar .time {
          padding-left: 30px;
          text-align: right;
        then you can change the font size from there.
        Go to your clock.js file and look for this section…
        		 * Create wrappers for DIGITAL clock
        		var dateWrapper = document.createElement("div");
        		var timeWrapper = document.createElement("div");
        		var secondsWrapper = document.createElement("sup");
        		var periodWrapper = document.createElement("span");
        		var weekWrapper = document.createElement("div")
        		// Style Wrappers
        		dateWrapper.className = "date normal xlarge bolder";
        		timeWrapper.className = "time bright large bolder";
        		secondsWrapper.className = "dimmed";
        		weekWrapper.className = "week dimmed medium"
        change the sizes of the date and time here. You can use the sizes as defined in your main.css file…
        .xsmall {
          font-size: 15px;
          line-height: 20px;
        .small {
          font-size: 20px;
          line-height: 25px;
        .medium {
          font-size: 30px;
          line-height: 35px;
        .large {
          font-size: 65px;
          line-height: 65px;
        .xlarge {
          font-size: 75px;
          line-height: 75px;
          letter-spacing: -3px;
        Hope this helps!
        "Life's Too Short To Dance With Ugly People"
        Jim Hallock - 1995
          DerOptiker86
          Great thanks for reply!!!
          I’ll try it in the evening and hope it fits :)
          THX justjim1220
            DerOptiker86
            ok… i fixed the clock with the main.css… changing the font-size for xlarge and it fits nice… but the calendar is still as smal as before…
            here my custom.css again:
            .calendar .symbol {
              padding-left: 0;
              font-size: 100%;
            .calendar .title {
              padding-left: 0;
              padding-right: 0;
            .calendar .time {
              padding-left: 30px;
              text-align: right;
            .calendar {
             width: 375px
            with the command
            .calendar {
            width: 375px
            } (see above)
            nothing is happen to the size of it. still i miss a .class add?
            greetz
            justjim1220J 2 Replies Last reply Reply Quote 0
              @deroptiker86 said in Calendar Font Size:
              .calendar {
              width: 375px
              Add the following to the above…
              font-size: 2em;
              line-height: 2.5em;
              OR…
              font-size: 35px;
              line-height: 40px;
              Then, play with the numbers to get it how you want it.
              Jim Hallock - 1995
                @deroptiker86
                Like this…
                .calendar {
                 width: 375px;
                font-size: 2em;
                line-height: 2.5em;
                OR…
                .calendar {
                 width: 375px;
                font-size: 35px;
                line-height: 40px;
                And you are missing the ‘;’ after ‘width: 375px’
                Jim Hallock - 1995
                  DerOptiker86
                  :/ hmmmm ok i add the lines…
                  then change the px… and restart and it still looks like the same… thats crazy…0_1533059358493_mm screen.jpg
                    @deroptiker86
                    Hmmm, let me play with it on my end.
                    I’ll be right back in a few minutes.
                    Jim Hallock - 1995
                      DerOptiker86
                      nice thx!
                      .calendar .time {
                        padding-left: 30px;
                        text-align: right;
                      .calendar {
                       width: 375px;
                       font-size: 200px;
                       line-height: 40px;
                      i also drop my cofig.js here… maybe thats my fault:
                        language: "de",
                              timeFormat: 24,
                              units: "metric",
                                              module: "alert",
                                              module: "updatenotification",
                                              position: "top_bar"
                                              module: "clock",
                                              position: "top_left"
                                              header: "Icloud Calender",
                                              position: "top_center",
        symbol: "calendar-check-o ",
        url:"webcal://pxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx
                                              module: 'MMM-NFL',
                                              position: 'left',
                                                      colored: true
                                              module: 'MMM-NFL',
                                              position: 'right',
                                                      colored: true,
                                                      focus_on: "NE"
                                              module: "MMM-rain-forecast",
                                              position: "top_right",   // see mirror setting for options
                                              header: "Gibt es Regen",
                                                      lat: xxxx,
                                                      lon: xxxxx,
                                                      pleaseWait: "Bitte warten",
                                                      noRainText: "Bis %s kein Regen",
                                                      fillColour: '#0074d9'   // This is a blue color you can also use blue, cyan etc
                                              module: 'mmm-moon-phases',
                                              header: 'Aktuelle Mondphase',   // optionally you can add a header to this block
                                              position: 'bottom_right',        // this can be any of the regions
                                              module: "weatherforecast",
                        @DerOptiker86
                        OK, add the following to your config.js…
                        tableClass: "large",
                        like this…
                            header: "iCloud Calendar",
                        		url: " "
                        you can change a lot of the defaults in the config…
                        defaults: {
                        		maximumEntries: 10, // Total Maximum Entries
                        		maximumNumberOfDays: 365,
                        		displaySymbol: true,
                        		defaultSymbol: "calendar-alt", // Fontawesome Symbol see http://fontawesome.io/cheatsheet/
                        		displayRepeatingCountTitle: false,
                        		defaultRepeatingCountTitle: "",
                        		maxTitleLength: 50,
                        		wrapEvents: false, // wrap events to multiple lines breaking at maxTitleLength
                        		fetchInterval: 30 * 60 * 1000, // Update every 30 minutes.
                        		animationSpeed: 2000,
                        		fade: false,
                        		urgency: 7,
                        		timeFormat: "relative",
                        		dateFormat: "MMM Do",
                        		fullDayEventDateFormat: "MMM Do",
                        		getRelative: 6,
                        		fadePoint: 0.25, // Start on 1/4th of the list.
                        		hidePrivate: false,
                        		hideOngoing: false,
                        		colored: true,
                        		coloredSymbolOnly: true,
                        				symbol: "calendar",
                        				url: "http://www.calendarlabs.com/templates/ical/US-Holidays.ics",
                        		titleReplace: {
                        			"De verjaardag van ": "",
                        			"'s birthday": ""
                        		broadcastEvents: true,
                        		excludedEvents: []
                        I hope this is what you’re looking for. :winking_face:
                        Jim Hallock - 1995
                          DerOptiker86
                          :rolling_on_the_floor_laughing: :rolling_on_the_floor_laughing: :rolling_on_the_floor_laughing:
                          it works :face_with_tears_of_joy: :face_with_tears_of_joy:
                          now i only must to fix the size :vulcan_salute_light_skin_tone:
                          realy thank you for your fast help!!!
                          :call_me_hand_medium-light_skin_tone:
                          justjim1220J 1 Reply Last reply Reply Quote 1
                            @DerOptiker86
                            And, you can remove this entry in your custom.css…
                            .calendar {
                             width: 375px;
                             font-size: 200px;
                             line-height: 40px;
                            :upside-down_face:
                            Jim Hallock - 1995
                              @deroptiker86
                              Always glad to help out!
                              Jim Hallock - 1995
