Solved A few days after upgrading to 2.4.1, my disk filled up and now my mirror won't run. Sad face!
Upgraded. Did all the config changes. Worked great. Went out of town. Came back to a blank mirror. Was confused to find the screen and RPi still working fine. SSH’ed in, and every pm2 command I tried gave me
[PM2] Spawning PM2 daemon with pm2_home=/home/pi/.pm2
Much googling ensued. Tried changing permission on a couple of files. Didn’t work. Finally decided it must mean my disk is full.
pi@raspberrypi:~ $ df -h Filesystem Size Used Avail Use% Mounted on /dev/root 13G 13G 0 100% / devtmpfs 333M 0 333M 0% /dev tmpfs 462M 0 462M 0% /dev/shm tmpfs 462M 12M 450M 3% /run tmpfs 5.0M 4.0K 5.0M 1% /run/lock tmpfs 462M 0 462M 0% /sys/fs/cgroup /dev/mmcblk0p6 68M 21M 47M 31% /boot tmpfs 93M 0 93M 0% /run/user/1000
So suspicions confirmed I guess?
I used
ncdu
to try to figure out if something ballooned out of control and that’s when I realized I’m a complete beginner and have no idea what to look for. Here’s what I saw:--- / ------------------------------------------------------------------------------------------------------------------------------ . 7.4 GiB [##########] /var 2.8 GiB [### ] /usr 1.0 GiB [# ] /home 945.6 MiB [# ] /opt 182.2 MiB [ ] /lib 21.0 MiB [ ] /boot . 11.9 MiB [ ] /run 7.3 MiB [ ] /sbin 6.8 MiB [ ] /bin . 5.7 MiB [ ] /etc . 228.0 KiB [ ] /tmp ! 16.0 KiB [ ] /lost+found . 12.0 KiB [ ] /media e 4.0 KiB [ ] /srv ! 4.0 KiB [ ] /root e 4.0 KiB [ ] /mnt . 0.0 B [ ] /sys . 0.0 B [ ] /proc 0.0 B [ ] /dev
Selecting that top directory (assuming the culprit is somewhere in there), I see this:
--- /var --------------------------------------------------------------------------------------------------------------------------- /.. . 7.1 GiB [##########] /log . 145.6 MiB [ ] /cache . 115.3 MiB [ ] /lib 100.0 MiB [ ] swap 296.0 KiB [ ] /backups . 68.0 KiB [ ] /tmp . 28.0 KiB [ ] /spool e 4.0 KiB [ ] /opt e 4.0 KiB [ ] /mail e 4.0 KiB [ ] /local @ 0.0 B [ ] lock @ 0.0 B [ ] run
Hm. Let’s try that top one again. Here’s what we get (truncated to the directories that take up any substantial space):
--- /var/log ----------------------------------------------------------------------------------------------------------------------- /.. 2.4 GiB [##########] kern.log 1.8 GiB [####### ] messages 1.4 GiB [##### ] messages.1 534.7 MiB [## ] syslog.1 533.4 MiB [## ] kern.log.1 287.9 MiB [# ] syslog 24.9 MiB [ ] syslog.3.gz
And that’s where I’m stuck. Is my culprit in there? Can I delete it? How can I prevent this from happening in the future?
I think you should be able to delete everything from /var/log as these are just log files. But the question remains why the logs are inflated so much. Something gets triggered to write something in the logs. I wouldn’t know how to find out what it is as I am a total n00b myself (even after years of using Linux).
Thanks for the response!
Based on that, I went ahead and deleted those guys. I did this:
pi@raspberrypi:~ $ sudo rm /var/log/kern* &>/dev/null pi@raspberrypi:~ $ sudo rm /var/log/messages* &>/dev/null
…then rebooted and everything came back to life.
I’ve now got a little breathing room on my disk:
pi@raspberrypi:~ $ df -h Filesystem Size Used Avail Use% Mounted on /dev/root 13G 11G 1.4G 89% / devtmpfs 333M 0 333M 0% /dev tmpfs 462M 0 462M 0% /dev/shm tmpfs 462M 12M 450M 3% /run tmpfs 5.0M 4.0K 5.0M 1% /run/lock tmpfs 462M 0 462M 0% /sys/fs/cgroup /dev/mmcblk0p6 68M 21M 47M 31% /boot tmpfs 93M 0 93M 0% /run/user/1000
And I guess I need to implement some kind of solution to “rotate my logs” if that’s the correct nomenclature?
The question remains: why did this happen? I know one of my modules is kind of noisy in the logs – like it updates once a minute and even though it’s working it sends an error message to the logs every time. But it’s hard to imagine that that one-line error would take up multiple gigs in a couple months. I dunno.
Maybe “log rotation” should be addressed in the config instructions?
For future generations looking to solve this problem:
I believe one of my modules (MMM-CTA for the record) poops out a ton of log entries. Those fill up my SD card after a few weeks.
I ended up installing a pm2 module called pm2-logrotate. https://www.npmjs.com/package/pm2-logrotate
I’m setting it to rotate my var/log file before it gets too big. Hopefully this will solve future problems.
pi@raspberrypi:~ $ pm2 install pm2-logrotate pi@raspberrypi:~ $ pm2 set pm2-logrotate:max_size 2G
