    MMM-AssistantMk2
    421 Posts 61 Posters 802.4k Views 57 Watching
      Sun @jomwells
      @jomwells Mine is a little bit different as I use the hdmi on tv as speaker as well. the default device fall on card 0 with alsa. For microphone is usb on card 1. I don’t have problem with microphone but I did have problem with sound via hdmi. Sometime sound just come out right through the hdmi but with lag sound, sometime no sound at all and say device busy. Also, to avoid hdmi device busy, I use usb sound card instead of hdmi sound also very lag.
      pcm.!default {
      type asym
      playback.pcm
      type hw
      card 0
      device 1
      capture.pcm
      type hw
      card 1
      device 0
        Sun @Guest
        @sean How to change the piping Linear 16 to ogg. Can I just put ogg in the
        encodingOut: “OPUS_IN_OGG”,
        ? 1 Reply Last reply
          A Former User @Sun
          @sun
          No, mp3 and Ogg should be written to file or piping to proper player, frankly I didn’t implement those function, because I thought nobody needs.
          I’ll try those till next update.
            jomwells
            Thank you, I will look into piping the audio, but its unlikely I will get very far :)
            Question: is it possible to run terminal commands at the different stages of MMM-AssistantMk2, such as running a command to turn on a GPIO pin (using the built in ‘GPIO write X 1’ ) when the module begins listening, and turning it off again when it is understanding, or speaking perhaps? the use case for which would be a status LED on the mirror. Thanks again.
              A Former User @jomwells
              @jomwells
              You can fork my repository to yours and modify it.
              When you want to relay status to other modules, add .sendNotification() in ’socketNotificationReceived()’ of AssistantMk2.js where proper event is located.
              When you want to do something directly, add your job in ’Conversation.on(EVENT)’ of node_helper.js.
                Sun
                1. What else do I need to do for install for mmm-assistantmk2 to play youtube.
                2. I try the same command say Celine Dion The power of love. Then pop up below detail about Celine Dion and the youtube video automatically pop up but cannot play anything.
                3. My magic mirror is vertical mode, rotate = 1 . I try to adjust from your height 480 width 854 of display but it also show in vertical mode height 480 with 640 also height 640 width 480. No different.
                  A Former User @Sun
                  @sun
                  • Some youtube videos are not allowed for embedded player.
                  • some videos are not caught, it will be fixed.
                  • some videos are not only video but playlist, so it is not caught, but it will be fixed also.
                  • sometime Google gives no information about youtube. I guess smart tv is using not only YouTube but also other dedicated apps for music and video, yogether
                  D 1 Reply Last reply
                    JRCelis @jomwells
                    @jomwells
                    I get the same issue, I hear a buzz at the beginning of the answered sentences in my speaker and clear voice after two seconds of the sentences start.
                      A Former User @JRCelis
                      @jrcelis
                      What kind of speaker do you use? Analog? HDMI output? USB? Bluetooth?
                      Except for Bluetooth speaker, All others could have buzz sound.
                      J T 2 Replies Last reply
                        JRCelis @Guest
                        @sean
                        Hello @Sean and thanks for your help. I’m using the speaker that is coming with Google Voice Kit V1 and is working fine when I’m testing the sound, no buzz or distorted sound and the beginning of the sentences, the issue starts when I click the speaker icon when MMM-assistantk2 is running, the assistants answer start whit a big distorted noise o buzz and then will be fine.
                          @jrcelis
                          Unfortunately, I’m not an expert in sound configuration.
                          I use node module speaker for output. The buffered voice output from Google Assistant Server is directly piped to speaker module. And there is narrowly little margin to control speaker module.
                          My guess is, burden of system could make some delay causing distortion. but just guessing.
                          Anyway, I’m considering to convert voice output to mp3 file then play it. but it needs somewhat computing power, so I’m not sure whether it will be really good for RPI.
                          Or I will search other solution for better result.
                            mariecbilodeau
                            Hello! I got Hotword working but assistant triggers error. I tried to rebuild electron as explained in the installation guide but it’s not working. I have the google voice kit installed on my raspberry… do you think that is the problem?
                              A Former User @mariecbilodeau
                              @mariecbilodeau more details are needed to answer. Error logs or screenshots could be helpful.
                                mariecbilodeau
                                this is when I load my mirror with just hotword and assistant installed. I’ll try to rebuild electron again to get the log
                                > magicmirror@2.4.1 start /home/pi/MagicMirror
                                > sh run-start.sh
                                Starting MagicMirror: v2.4.1
                                Loading config ...
                                Loading module helpers ...
                                Module helper loaded: MMM-Hotword
                                WARNING! Could not load config file. Starting with default configuration. Error found: Error: Failed to load gRPC binary module because it was not installed for the current system
                                Expected directory: electron-v2.0-linux-arm-glibc
                                Found: [node-v59-linux-arm-glibc]
                                This problem can often be fixed by running "npm rebuild" on the current system
                                Original error: Cannot find module '/home/pi/MagicMirror/modules/MMM-AssistantMk2/node_modules/grpc/src/node/extension_binary/electron-v2.0-linux-arm-glibc/grpc_node.node'
                                App threw an error during load
                                    at Object.<anonymous> (/home/pi/MagicMirror/modules/MMM-AssistantMk2/node_modules/grpc/src/grpc_extension.js:53:17)
                                    at Object.<anonymous> (/home/pi/MagicMirror/modules/MMM-AssistantMk2/node_modules/grpc/src/grpc_extension.js:63:3)
                                    at Module._compile (module.js:642:30)
                                    at Object.Module._extensions..js (module.js:653:10)
                                    at Module.load (module.js:561:32)
                                    at tryModuleLoad (module.js:504:12)
                                    at Function.Module._load (module.js:496:3)
                                    at Module.require (module.js:586:17)
                                    at require (internal/module.js:11:18)
                                    at Object.<anonymous> (/home/pi/MagicMirror/modules/MMM-AssistantMk2/node_modules/grpc/src/client_interceptors.js:145:12)
                                { Error: Failed to load gRPC binary module because it was not installed for the current system
                                    at Object.<anonymous> (/home/pi/MagicMirror/modules/MMM-AssistantMk2/node_modules/grpc/src/client_interceptors.js:145:12) code: 'MODULE_NOT_FOUND' }
                                Launching application.
                                pi@raspberrypi:~/MagicMirror $
                                  mariecbilodeau
                                  this is part of my rebuild error
                                  pi@raspberrypi:~/MagicMirror/modules/MMM-AssistantMk2 $ npm install --save-dev electron-rebuild
                                  npm WARN MMM-AssistantMk2@1.0.1 No repository field.
                                  + electron-rebuild@1.8.2
                                  updated 1 package in 18.167s
                                  pi@raspberrypi:~/MagicMirror/modules/MMM-AssistantMk2 $ ./node_modules/.bin/electron-rebuild
                                  ✖ Rebuild Failed
                                  An unhandled error occurred inside electron-rebuild
                                  gyp info it worked if it ends with ok
                                  gyp info using node-gyp@3.8.0
                                  gyp info using node@9.11.2 | linux | arm
                                  gyp info spawn /usr/bin/python2
                                  gyp info spawn args [ '/home/pi/MagicMirror/modules/MMM-AssistantMk2/node_modules/node-gyp/gyp/gyp_main.py',
                                  gyp info spawn args   'binding.gyp',
                                  gyp info spawn args   '-f',
                                  gyp info spawn args   'make',
                                  gyp info spawn args   '-I',
                                  gyp info spawn args   '/home/pi/MagicMirror/modules/MMM-AssistantMk2/node_modules/grpc/build/config.gypi',
                                  gyp info spawn args   '/home/pi/MagicMirror/modules/MMM-AssistantMk2/node_modules/node-gyp/addon.gypi',
                                  gyp info spawn args   '/home/pi/.electron-gyp/.node-gyp/iojs-2.0.0/common.gypi',
                                  gyp info spawn args   '-Dlibrary=shared_library',
                                  gyp info spawn args   '-Dvisibility=default',
                                  gyp info spawn args   '-Dnode_root_dir=/home/pi/.electron-gyp/.node-gyp/iojs-2.0.0',
                                  gyp info spawn args   '-Dnode_gyp_dir=/home/pi/MagicMirror/modules/MMM-AssistantMk2/node_modules/node-gyp',
                                  gyp info spawn args   '-Dnode_lib_file=/home/pi/.electron-gyp/.node-gyp/iojs-2.0.0/<(target_arch)/iojs.lib',
                                  gyp info spawn args   '-Dmodule_root_dir=/home/pi/MagicMirror/modules/MMM-AssistantMk2/node_modules/grpc',
                                  gyp info spawn args   '-Dnode_engine=v8',
                                  gyp info spawn args   '--depth=.',
                                  gyp info spawn args   '--no-parallel',
                                  gyp info spawn args   '--generator-output',
                                  gyp info spawn args   'build',
                                  gyp info spawn args   '-Goutput_dir=.' ]
                                  gyp info spawn make
                                  gyp info spawn args [ 'BUILDTYPE=Release', '-C', 'build' ]
                                  make : on entre dans le répertoire « /home/pi/MagicMirror/modules/MMM-AssistantMk2/node_modules/grpc/build »
                                    CXX(target) Release/obj.target/grpc/deps/grpc/src/core/lib/surface/init.o
                                    CXX(target) Release/obj.target/grpc/deps/grpc/src/core/lib/avl/avl.o
                                    CXX(target) Release/obj.target/grpc/deps/grpc/src/core/lib/backoff/backoff.o
                                    CXX(target) Release/obj.target/grpc/deps/grpc/src/core/lib/channel/channel_args.o
                                    CXX(target) Release/obj.target/grpc/deps/grpc/src/core/lib/channel/channel_stack.o
                                    CXX(target) Release/obj.target/grpc/deps/grpc/src/core/lib/channel/channel_stack_builder.o
                                    CXX(target) Release/obj.target/grpc/deps/grpc/src/core/lib/channel/channel_trace.o
                                    CXX(target) Release/obj.target/grpc/deps/grpc/src/core/lib/channel/channelz.o
                                    CXX(target) Release/obj.target/grpc/deps/grpc/src/core/lib/channel/channelz_registry.o
                                    CXX(target) Release/obj.target/grpc/deps/grpc/src/core/lib/channel/connected_channel.o
                                    CXX(target) Release/obj.target/grpc/deps/grpc/src/core/lib/channel/handshaker.o
                                    CXX(target) Release/obj.target/grpc/deps/grpc/src/core/lib/channel/handshaker_factory.o
                                    CXX(target) Release/obj.target/grpc/deps/grpc/src/core/lib/channel/handshaker_registry.o
                                    CXX(target) Release/obj.target/grpc/deps/grpc/src/core/lib/channel/status_util.o
                                    CXX(target) Release/obj.target/grpc/deps/grpc/src/core/lib/compression/compression.o
                                    CXX(target) Release/obj.target/grpc/deps/grpc/src/core/lib/compression/compression_internal.o
                                    CXX(target) Release/obj.target/grpc/deps/grpc/src/core/lib/compression/message_compress.o
                                    CXX(target) Release/obj.target/grpc/deps/grpc/src/core/lib/compression/stream_compression.o
                                    CXX(target) Release/obj.target/grpc/deps/grpc/src/core/lib/compression/stream_compression_gzip.o
                                    CXX(target) Release/obj.target/grpc/deps/grpc/src/core/lib/compression/stream_compression_identity.o
                                    CXX(target) Release/obj.target/grpc/deps/grpc/src/core/lib/debug/stats.o
                                    CXX(target) Release/obj.target/grpc/deps/grpc/src/core/lib/debug/stats_data.o
                                    CXX(target) Release/obj.target/grpc/deps/grpc/src/core/lib/http/format_request.o
                                    CXX(target) Release/obj.target/grpc/deps/grpc/src/core/lib/http/httpcli.o
                                    CXX(target) Release/obj.target/grpc/deps/grpc/src/core/lib/http/parser.o
                                    CXX(target) Release/obj.target/grpc/deps/grpc/src/core/lib/iomgr/call_combiner.o
                                    CXX(target) Release/obj.target/grpc/deps/grpc/src/core/lib/iomgr/combiner.o
                                    CXX(target) Release/obj.target/grpc/deps/grpc/src/core/lib/iomgr/endpoint.o
                                    CXX(target) Release/obj.target/grpc/deps/grpc/src/core/lib/iomgr/endpoint_pair_posix.o
                                    CXX(target) Release/obj.target/grpc/deps/grpc/src/core/lib/iomgr/endpoint_pair_uv.o
                                    CXX(target) Release/obj.target/grpc/deps/grpc/src/core/lib/iomgr/endpoint_pair_windows.o
                                    CXX(target) Release/obj.target/grpc/deps/grpc/src/core/lib/iomgr/error.o
                                    CXX(target) Release/obj.target/grpc/deps/grpc/src/core/lib/iomgr/ev_epoll1_linux.o
                                    CXX(target) Release/obj.target/grpc/deps/grpc/src/core/lib/iomgr/ev_epollex_linux.o
                                    CXX(target) Release/obj.target/grpc/deps/grpc/src/core/lib/iomgr/ev_epollsig_linux.o
                                    CXX(target) Release/obj.target/grpc/deps/grpc/src/core/lib/iomgr/ev_poll_posix.o
                                    CXX(target) Release/obj.target/grpc/deps/grpc/src/core/lib/iomgr/ev_posix.o
                                    CXX(target) Release/obj.target/grpc/deps/grpc/src/core/lib/iomgr/ev_windows.o
                                    CXX(target) Release/obj.target/grpc/deps/grpc/src/core/lib/iomgr/exec_ctx.o
                                    CXX(target) Release/obj.target/grpc/deps/grpc/src/core/lib/iomgr/executor.o
                                    CXX(target) Release/obj.target/grpc/deps/grpc/src/core/lib/iomgr/fork_posix.o
                                    CXX(target) Release/obj.target/grpc/deps/grpc/src/core/lib/iomgr/fork_windows.o
                                    CXX(target) Release/obj.target/grpc/deps/grpc/src/core/lib/iomgr/gethostname_fallback.o
                                    CXX(target) Release/obj.target/grpc/deps/grpc/src/core/lib/iomgr/gethostname_host_name_max.o
                                    CXX(target) Release/obj.target/grpc/deps/grpc/src/core/lib/iomgr/gethostname_sysconf.o
                                    CXX(target) Release/obj.target/grpc/deps/grpc/src/core/lib/iomgr/iocp_windows.o
                                    CXX(target) Release/obj.target/grpc/deps/grpc/src/core/lib/iomgr/iomgr.o
                                    CXX(target) Release/obj.target/grpc/deps/grpc/src/core/lib/iomgr/iomgr_custom.o
                                    CXX(target) Release/obj.target/grpc/deps/grpc/src/core/lib/iomgr/iomgr_internal.o
                                    @mariecbilodeau
                                    “gyp ERR …” lines are needed. Your log is missing those infos.
                                    M 1 Reply Last reply
                                    • T
                                      themc
                                      is there any way to play local stored mp3 files on the raspbery pi using the play … command
                                      currently when saying prhases like play mp3 it says oke and stops.
                                      im wondering if it is possible to play music mp3s from the music folder using the built in player of vlc player by sying the google command of a gaction
                                      would be a nice addition to the plugin
                                        A Former User @themc
                                        @themc
                                        If you have a module to play mp3 and it is able to be activated by notification, it could. But adding some specific job to Assistant itself, I think it is not so good idea, because each circumstance is different.
                                        So have you a module which can play mp3? I can make gaction sample for it.
                                          dvbit @Guest
                                          @sean thanks for all the info.
                                          Just saw this after sending you request for info.
                                          will search better / more in the future :-)
                                            dvbit
                                            Looking for a solution for my vertical setup and browsing the file system I have seen that the cardsare stored in a temp_screen html file in the plugin folder.
                                            changing there font size from 40px to 20px makes already a big diff (no scroll bars… in the cards)
                                            is htere a way I can intercept that file and edit before presentation?
                                            that would already do a good trick :-)
                                            • 21
                                            • 22
                                            • 3 / 22
