Issue booting up MM
You forgot to post your config.js file…
/* Magic Mirror Config Sample
*- By Michael Teeuw http://michaelteeuw.nl
- MIT Licensed.
- For more information how you can configurate this file
- See https://github.com/MichMich/MagicMirror#configuration
var config = {
// - “”, “0.0.0.0”, “::” to listen on any interface
// Default, when address config is left out, is “localhost”
port: 8080,
ipWhitelist: [“127.0.0.1”, “::ffff:127.0.0.1”, “::1”], // Set [] to allow all IP addresses
// [“127.0.0.1”, “::ffff:127.0.0.1”, “::1”, “::ffff:192.168.1.5”],
// [“127.0.0.1”, “::ffff:127.0.0.1”, “::1”, “::ffff:192.168.3.0/28”],language: "en", timeFormat: 12, units: "imperial", modules: [ { module: "alert", }, { module: "updatenotification", position: "top_bar" }, { module: "clock", position: "top_left" }, { module: "MMM-NowPlayingOnSpotify", position: "bottom_left", config: { clientID: "9cbb4966327e429ea6611b896c7aa475", clientSecret: "5fb34270e7974d4db88b72184ffea965", accessToken: "BQAV5hhJmzGt_yFq9JgfqQmOaYBeWBQsZJZYgnwr8rRXehDtB9huPdLZMBlY7H6SLWJFiSBlVVwh_Pbx_Ax2ehtYbyHjur1OTSuvt1BA_SVMC_Zmtk6fBMQd3TdrzNnz9n9zUXCaS0YA5llPKauKWz9_N_g", refreshToken: "AQC9r0Dr3B6v5oDnIGcxCfsXVT73Z9fWkj83NGk3CBritcOj7ReotWoOjQomMQhO3M8vjsnvDtkBYCNzj__-MCQILSY_uxyeBzN4XtqKQhulIo0TfrnfSPk6KHSOQlKrvB8" } }, { module: "calendar", header: "Ben's Events", position: "top_left", config: { calendars: [ { symbol: "calendar-check-o ", url: "https://calendar.google.com/calendar/ical/brperlson%40gmail.com/private-4e5979ce33a6de99058ea95ee43eb965/basic.ics" } ] } }, { module: "currentweather", position: "top_right", config: { location: "Iowa City", locationID: "4862034", //ID from http://www.openweathermap.org/help/city_list.txt appid: "ab97a6b07b76d512b14cff642fa674e6" } }, { module: "weatherforecast", position: "top_right", header: "Weather Forecast", config: { location: "Iowa City", locationID: "4862034", //ID from http://www.openweathermap.org/help/city_list.txt appid: "ab97a6b07b76d512b14cff642fa674e6" } }, //{ // module: "newsfeed", // position: "bottom_bar", // config: { // feeds: [ // { // title: "New York Times", // url: "http://www.nytimes.com/services/xml/rss/nyt/HomePage.xml" // } // ], // showSourceTitle: true, // showPublishDate: true // } //}, ]
if (typeof module !== “undefined”) {module.exports = config;} -
Two things:
Remove all private data like API keys, personal calendar urls etc, just put ‘…’ or ‘xxxx’ or so. You don’t want other people too access your private data.Can you fix the format? It’s barely readable like this.
@madscientist I cannot edit the post now. But what was the second thing?
@madscientist
Fatal error in …/deps/v8/src/snapshot/deserializer.cc, line 662Check failed: false.
that is what I get when I try to start it…
Of course you can edit your post and you really should.
The second thing was to fix the format to make it more readable.
I have no idea where ‘…/deps/v8/src/snapshot/deserializer.cc’ is. Isn’t it giving the full path? Maybe try to deactivate the MMM-NowPlayingOnSpotify module and see if the mirror is starting.
If i google “deserializer.cc” i get a link to the git of chromium.
so maybe your chromium installation is broken.
Did u use the automatic installer or not?
Maybe you should delete the MagicMirror folder in your home dictionary and try this if u use a raspberry pi:
bash -c "$(curl -sL https://raw.githubusercontent.com/MichMich/MagicMirror/master/installers/raspberry.sh)"
And u should read this carefully:
https://github.com/MichMich/MagicMirrorAaaaaand u should edit your post as MadScientist said ;)
