    Issue booting up MM
    8 Posts 3 Posters 2.2k Views 2 Watching
      bperlson
        MadScientist
        You forgot to post your config.js file…
          bperlson
          0_1534446047090_aaf8f064-9507-4bc4-af39-dad84ff35ac3-image.png /* Magic Mirror Config Sample
          • MIT Licensed.
          • For more information how you can configurate this file
          • See https://github.com/MichMich/MagicMirror#configuration
          var config = {
          // - “”, “0.0.0.0”, “::” to listen on any interface
          // Default, when address config is left out, is “localhost”
          port: 8080,
          ipWhitelist: [“127.0.0.1”, “::ffff:127.0.0.1”, “::1”], // Set [] to allow all IP addresses
          // [“127.0.0.1”, “::ffff:127.0.0.1”, “::1”, “::ffff:192.168.1.5”],
          // [“127.0.0.1”, “::ffff:127.0.0.1”, “::1”, “::ffff:192.168.3.0/28”],
          language: "en",
          timeFormat: 12,
          units: "imperial",
          		module: "alert",
          		module: "updatenotification",
          		position: "top_bar"
          		module: "clock",
          		position: "top_left"
          		  module: "MMM-NowPlayingOnSpotify",
          		  position: "bottom_left",
          		    clientID: "9cbb4966327e429ea6611b896c7aa475",
          		    clientSecret: "5fb34270e7974d4db88b72184ffea965",
          		    accessToken: "BQAV5hhJmzGt_yFq9JgfqQmOaYBeWBQsZJZYgnwr8rRXehDtB9huPdLZMBlY7H6SLWJFiSBlVVwh_Pbx_Ax2ehtYbyHjur1OTSuvt1BA_SVMC_Zmtk6fBMQd3TdrzNnz9n9zUXCaS0YA5llPKauKWz9_N_g",
          		    refreshToken: "AQC9r0Dr3B6v5oDnIGcxCfsXVT73Z9fWkj83NGk3CBritcOj7ReotWoOjQomMQhO3M8vjsnvDtkBYCNzj__-MCQILSY_uxyeBzN4XtqKQhulIo0TfrnfSPk6KHSOQlKrvB8"
          		header: "Ben's Events",
          					symbol: "calendar-check-o ",
          					url: "https://calendar.google.com/calendar/ical/brperlson%40gmail.com/private-4e5979ce33a6de99058ea95ee43eb965/basic.ics"
          		module: "currentweather",
          			locationID: "4862034",  //ID from http://www.openweathermap.org/help/city_list.txt
          			appid: "ab97a6b07b76d512b14cff642fa674e6"
          		module: "weatherforecast",
          		header: "Weather Forecast",
          	//	module: "newsfeed",
          	//	position: "bottom_bar",
          	//	config: {
          	//		feeds: [
          	//				title: "New York Times",
          	//				url: "http://www.nytimes.com/services/xml/rss/nyt/HomePage.xml"
          	//		showSourceTitle: true,
          	//		showPublishDate: true
          if (typeof module !== “undefined”) {module.exports = config;}
            MadScientist
            Two things:
            Remove all private data like API keys, personal calendar urls etc, just put ‘…’ or ‘xxxx’ or so. You don’t want other people too access your private data.
            Can you fix the format? It’s barely readable like this.
              bperlson @MadScientist
              @madscientist I cannot edit the post now. But what was the second thing?
                @madscientist
                Fatal error in …/deps/v8/src/snapshot/deserializer.cc, line 662
                Check failed: false.
                that is what I get when I try to start it…
                  MadScientist
                  Of course you can edit your post and you really should.
                  The second thing was to fix the format to make it more readable.
                  I have no idea where ‘…/deps/v8/src/snapshot/deserializer.cc’ is. Isn’t it giving the full path? Maybe try to deactivate the MMM-NowPlayingOnSpotify module and see if the mirror is starting.
                  • cruunnerrC Offline
                    cruunnerr
                    If i google “deserializer.cc” i get a link to the git of chromium.
                    so maybe your chromium installation is broken.
                    Did u use the automatic installer or not?
                    Maybe you should delete the MagicMirror folder in your home dictionary and try this if u use a raspberry pi:
                    bash -c "$(curl -sL https://raw.githubusercontent.com/MichMich/MagicMirror/master/installers/raspberry.sh)"
                    And u should read this carefully:
                    Aaaaaand u should edit your post as MadScientist said ;)
