Unsolved MMM-MirrorMirrorOnTheWall installation issue
@richland007 Thais is EXACTLY! where I am =)
I have to check this in the weekend from scratch!
I think there is something wrong with the lamda.
displaying what modules? sounds like you have come further than me?
@OceanK Well i meant i got the MMM-MirrorMirrorOnTheWall module for Magic Mirror figured out but it is not working right if that makes sense. :rolling_on_the_floor_laughing: :rolling_on_the_floor_laughing: So when Magic Mirror itself is lunched and it is displaying other modules like Weather and Calendar and all that, it is not throwing an error for MMM-MirrorMirrorOnTheWall so i got the certs path figured out and you need to run “npm Install” on MMM-MirrorMirrorOnTheWall module before using it after you clone it on modules folder. I use Alexa Pi which has its own module on MM so when i call Alexa and i ask to “Start On the wall” the mirror replies as “Hello my queen what can i do for you” but when i ask to do something like hide a module or display anything it says an error has occurred with your skills response please try again later. I have no clue whats causing that so i guess some more research is needed.
Denis -
Hey!
I have AlexaPi Aswell. In the module MMM-MirrorMirronOnTheWall, you copied the certs folder from MirrorMirrorOnTheWallSkill , right?
Then npm install in MMM-MirrorMirronOnTheWall
Did you change the path in anyway in the files for the certs? Like we discussed before ?
Regards K
OK so Im going to do this again from scratch.
what did you enter in your config.js file for the mirror, just this part?
module: ‘MMM-MirrorMirrorOnTheWall’,
position: “middle_center”,
config: {}
Ok so here is my hardcoding of certs path on the Magic Mirror module
keyPath: “/home/pi/MagicMirror/modules/MMM-MirrorMirrorOnTheWall/certs/MagicMirror.private.key”,
certPath: “/home/pi/MagicMirror/modules/MMM-MirrorMirrorOnTheWall/certs/MagicMirror.cert.pem”,
caPath: “/home/pi/MagicMirror/modules/MMM-MirrorMirrorOnTheWall/certs/root-CA.crt”,Also dont forget to add your iot-endpoint
region: “us-east-1”,
host: “aonu6XXXX8o.iot.us-east-1.amazonaws.com”,I kept the config on module just as yours or the default for testing purposses
Cool thanx, well I am at same stage as you, When I try the skill after build and the test. I get the !my queen etc etc" when I try to say “close all modules” I just get the error response skill etc.
so I have no cloue whats wrong. I think its something with the lambda function itself.
When I try to say “find youtube video on how to make slime” she says the error but when I check the clod logs its actually looking for videon on slime/youtube:’
2018-09-01T15:41:33.768Z 806824d0-adfd-11e8-aea5-f7829904bba6
“kind”: “youtube#searchListResponse”,
“etag”: ““XI7nbFXulYBIpL0ayR_gDh3eu1k/trfpcxzuGVnn32QncnihWoxjjgs””,
“nextPageToken”: “CAEQAA”,
“regionCode”: “US”,
“pageInfo”: {
“totalResults”: 1000000,
“resultsPerPage”: 1
“items”: [
“kind”: “youtube#searchResult”,
“etag”: ““XI7nbFXulYBIpL0ayR_gDh3eu1k/BqgWo2mCqNCYN8WncT1NMhRM7VE””,
“id”: {
“kind”: “youtube#video”,
“videoId”: “eaALjlyKDZI”
“snippet”: {
“publishedAt”: “2017-04-11T19:00:03.000Z”,
“channelId”: “UCIze4Pldy_KjXhYHqBwMLDQ”,
“title”: “How to Make SLIME for Beginners! Best EASY Way to Make Slime!”,
“description”: “YOU CAN NOW BUY MY SLIME ON ETSY: https://goo.gl/9GMmWA Hey guys! Today I’ll be showing you the best, easiest way to make slime. Check out my other …”,
“thumbnails”: {
“default”: {
“url”: “https://i.ytimg.com/vi/eaALjlyKDZI/default.jpg”,
“width”: 120,
“height”: 90
“medium”: {
“url”: “https://i.ytimg.com/vi/eaALjlyKDZI/mqdefault.jpg”,
“width”: 320,
“height”: 180
“high”: {
“url”: “https://i.ytimg.com/vi/eaALjlyKDZI/hqdefault.jpg”,
“width”: 480,
“height”: 360
“channelTitle”: “Courtney Lundquist”,
“liveBroadcastContent”: “none”
and here is some error in the logs when I try other stuff:
2018-09-01T15:41:09.907Z 722f8cd3-adfd-11e8-befe-f5fd64df2d92
“errorMessage”: “In state: . No handler function was defined for event SessionEndedRequest and no ‘Unhandled’ function was defined.”,
“errorType”: “Error”,
“stackTrace”: [
“AlexaRequestEmitter.EmitEvent (/var/task/node_modules/alexa-sdk/lib/alexa.js:212:15)”,
“AlexaRequestEmitter.ValidateRequest (/var/task/node_modules/alexa-sdk/lib/alexa.js:181:23)”,
“HandleLambdaEvent.i18n.use.init (/var/task/node_modules/alexa-sdk/lib/alexa.js:123:29)”,
“/var/task/node_modules/i18next/dist/commonjs/i18next.js:190:9”,
“done (/var/task/node_modules/i18next/dist/commonjs/i18next.js:281:21)”,
“/var/task/node_modules/i18next/dist/commonjs/i18next.js:302:7”,
“I18n.loadResources (/var/task/node_modules/i18next/dist/commonjs/i18next.js:238:7)”,
“I18n.changeLanguage (/var/task/node_modules/i18next/dist/commonjs/i18next.js:301:10)”,
“load (/var/task/node_modules/i18next/dist/commonjs/i18next.js:186:14)”,
“I18n.init (/var/task/node_modules/i18next/dist/commonjs/i18next.js:195:7)”
Where do you find these log files at?? so i can look at mine??
it seems like it doesn’t find the way to sent the results back and where to send them?? -
Login to your console where u created the lamda, search for CloudWatch and then Logs, console.aws.amazon.com
Whats the progress and status on this?@richland007
