    MMM-MirrorMirrorOnTheWall installation issue
    138 Posts 11 Posters 203.2k Views 10 Watching
    • richland007R
      richland007
      Ok so i was reading your steps and i basically did exactly the same thing and followed @joanaz instruction but with one exception!!! … are you absolutely sure that “node_modules” folder gets created by “npm install” inside the “src” folder on the “MirrorMirrorOnTheWallSkill” ??? …OR… did “node_modules” get created when you run “start.sh” on the IoT procedure and than copy that over to the “src” folder???
      Do we only copy the 4 certificate files from the IoT part only or everything in that folder over to the “src” ???
      Denis
      • richland007R
        richland007
        @OceanK Ok major major development on my end i got it to work …sort of LOL :) …meaning when i am on Magic Mirror and its doing its thing displaying the modules i can call Alexa ask her to start “on the wall” the mirror replies back with How can i Help you my Queen but when i ask to display a text or anything it says there was a problem with your skills response. Why is that???
        D
        O 1 Reply Last reply
        • O
          OceanK @richland007
          @richland007 Thais is EXACTLY! where I am =)
          I have to check this in the weekend from scratch!
          I think there is something wrong with the lamda.
          displaying what modules? sounds like you have come further than me?
          • richland007R
            richland007
            @OceanK Well i meant i got the MMM-MirrorMirrorOnTheWall module for Magic Mirror figured out but it is not working right if that makes sense. :rolling_on_the_floor_laughing: :rolling_on_the_floor_laughing: So when Magic Mirror itself is lunched and it is displaying other modules like Weather and Calendar and all that, it is not throwing an error for MMM-MirrorMirrorOnTheWall so i got the certs path figured out and you need to run “npm Install” on MMM-MirrorMirrorOnTheWall module before using it after you clone it on modules folder. I use Alexa Pi which has its own module on MM so when i call Alexa and i ask to “Start On the wall” the mirror replies as “Hello my queen what can i do for you” but when i ask to do something like hide a module or display anything it says an error has occurred with your skills response please try again later. I have no clue whats causing that so i guess some more research is needed.
            Denis
            • O
              OceanK
              Hey!
              I have AlexaPi Aswell. In the module MMM-MirrorMirronOnTheWall, you copied the certs folder from MirrorMirrorOnTheWallSkill , right?
              Then npm install in MMM-MirrorMirronOnTheWall
              Did you change the path in anyway in the files for the certs? Like we discussed before ?
              Regards K
              • O
                OceanK
                OK so Im going to do this again from scratch.
                what did you enter in your config.js file for the mirror, just this part?
                module: ‘MMM-MirrorMirrorOnTheWall’,
                position: “middle_center”,
                config: {}
                • richland007R
                  richland007
                  Ok so here is my hardcoding of certs path on the Magic Mirror module
                  keyPath: “/home/pi/MagicMirror/modules/MMM-MirrorMirrorOnTheWall/certs/MagicMirror.private.key”,
                  certPath: “/home/pi/MagicMirror/modules/MMM-MirrorMirrorOnTheWall/certs/MagicMirror.cert.pem”,
                  caPath: “/home/pi/MagicMirror/modules/MMM-MirrorMirrorOnTheWall/certs/root-CA.crt”,
                  Also dont forget to add your iot-endpoint
                  region: “us-east-1”,
                  host: “aonu6XXXX8o.iot.us-east-1.amazonaws.com”,
                  I kept the config on module just as yours or the default for testing purposses
                  • O
                    OceanK
                    Cool thanx, well I am at same stage as you, When I try the skill after build and the test. I get the !my queen etc etc" when I try to say “close all modules” I just get the error response skill etc.
                    so I have no cloue whats wrong. I think its something with the lambda function itself.
                    When I try to say “find youtube video on how to make slime” she says the error but when I check the clod logs its actually looking for videon on slime/youtube:’
                    2018-09-01T15:41:33.768Z 806824d0-adfd-11e8-aea5-f7829904bba6
                    “kind”: “youtube#searchListResponse”,
                    “etag”: “"XI7nbFXulYBIpL0ayR_gDh3eu1k/trfpcxzuGVnn32QncnihWoxjjgs"”,
                    “nextPageToken”: “CAEQAA”,
                    “regionCode”: “US”,
                    “pageInfo”: {
                    “totalResults”: 1000000,
                    “resultsPerPage”: 1
                    “items”: [
                    “kind”: “youtube#searchResult”,
                    “etag”: “"XI7nbFXulYBIpL0ayR_gDh3eu1k/BqgWo2mCqNCYN8WncT1NMhRM7VE"”,
                    “id”: {
                    “kind”: “youtube#video”,
                    “videoId”: “eaALjlyKDZI”
                    “snippet”: {
                    “publishedAt”: “2017-04-11T19:00:03.000Z”,
                    “channelId”: “UCIze4Pldy_KjXhYHqBwMLDQ”,
                    “title”: “How to Make SLIME for Beginners! Best EASY Way to Make Slime!”,
                    “description”: “YOU CAN NOW BUY MY SLIME ON ETSY: https://goo.gl/9GMmWA Hey guys! Today I’ll be showing you the best, easiest way to make slime. Check out my other …”,
                    “thumbnails”: {
                    “default”: {
                    “url”: “https://i.ytimg.com/vi/eaALjlyKDZI/default.jpg”,
                    “width”: 120,
                    “height”: 90
                    “medium”: {
                    “url”: “https://i.ytimg.com/vi/eaALjlyKDZI/mqdefault.jpg”,
                    “width”: 320,
                    “height”: 180
                    “high”: {
                    “url”: “https://i.ytimg.com/vi/eaALjlyKDZI/hqdefault.jpg”,
                    “width”: 480,
                    “height”: 360
                    “channelTitle”: “Courtney Lundquist”,
                    “liveBroadcastContent”: “none”
                    • O
                      OceanK
                      and here is some error in the logs when I try other stuff:
                      2018-09-01T15:41:09.907Z 722f8cd3-adfd-11e8-befe-f5fd64df2d92
                      “errorMessage”: “In state: . No handler function was defined for event SessionEndedRequest and no ‘Unhandled’ function was defined.”,
                      “errorType”: “Error”,
                      “stackTrace”: [
                      “AlexaRequestEmitter.EmitEvent (/var/task/node_modules/alexa-sdk/lib/alexa.js:212:15)”,
                      “AlexaRequestEmitter.ValidateRequest (/var/task/node_modules/alexa-sdk/lib/alexa.js:181:23)”,
                      “HandleLambdaEvent.i18n.use.init (/var/task/node_modules/alexa-sdk/lib/alexa.js:123:29)”,
                      “/var/task/node_modules/i18next/dist/commonjs/i18next.js:190:9”,
                      “done (/var/task/node_modules/i18next/dist/commonjs/i18next.js:281:21)”,
                      “/var/task/node_modules/i18next/dist/commonjs/i18next.js:302:7”,
                      “I18n.loadResources (/var/task/node_modules/i18next/dist/commonjs/i18next.js:238:7)”,
                      “I18n.changeLanguage (/var/task/node_modules/i18next/dist/commonjs/i18next.js:301:10)”,
                      “load (/var/task/node_modules/i18next/dist/commonjs/i18next.js:186:14)”,
                      “I18n.init (/var/task/node_modules/i18next/dist/commonjs/i18next.js:195:7)”
                      • richland007R
                        richland007
                        Where do you find these log files at?? so i can look at mine??
                        it seems like it doesn’t find the way to sent the results back and where to send them??
                        • O
                          OceanK
                          Login to your console where u created the lamda, search for CloudWatch and then Logs, console.aws.amazon.com
                          • O
                            OceanK
                            Whats the progress and status on this?@richland007
                            • richland007R
                              richland007
                              @OceanK Absolutely nothing i have to do much more research and read everything on the forums when it comes to this.
                              It seems like it has a problem with: No handler function was defined for event AMAZON.FallbackIntent and no ‘Unhandled’ function was defined.
                              Here is my error log as well and it is exactly like yours
                              We need to continue reading
                              Denis
                              • O
                                OceanK
                                Have you seen that the code makers repo has changed 2 files like 2 month ago? Though it didn’t make any difference still stuck at the same place as you. I think it’s something with the iot part and lamda function.
                                Let’s keep going ;)
                                • richland007R
                                  richland007
                                  @OceanK Well now i get no errors in Lamda but i dont think its working still this is what i did after a lot of reading in the internet and in the MM forums.
                                  Step 1. Delete your archive.zip you have on your Rpi
                                  2. Go to “MirrorMirrorOnTheWallSkill” open “src” folder and open to edit “index.js”
                                  3. At the very end of that file right before the very last } bracket
                                  enter the following:
                                      'Unhandled': function () {
                                          this.emit(':ask', 'Sorry I didnt understand that. Say help for assistance.');
                                  notice the “,” right after the prior to last } before 'Unhandled" … so it wont give you a syntax error.
                                  4. Go all the way up almost at the beginning of the file “index.js” and replace the following:
                                  const appId = "amzn1.ask.skill.XXXXXXXXXXX-XXXXX-9b1c-3d309a950fcf";
                                  const MirrorMirror = require('./MirrorMirror');
                                  MirrorMirror.setup();
                                  const Keys = require("./certs/keys.json");
                                  const GoogleImages = require('google-images');
                                  var googleImages = new GoogleImages(Keys.cse.ID, Keys.cse.API_key);
                                  const YouTube = require('youtube-node');
                                  var youTube = new YouTube();
                                  youTube.setKey(Keys.youtube.API_key);
                                  exports.handler = function(event, context, callback) {
                                      let alexa = Alexa.handler(event, context);
                                      alexa.appId = appId;
                                  Make sure to change your appId with your own
                                  You will see no more errors on Lamda and if you ask after on the wall it will say i am sorry i dont understand and if you ask for help it will tell you what help it can provide but nothing more than that… yet.
                                  To be continued
                                  Denis
                                  • richland007R
                                    richland007
                                    Oh after that step 5 zip it back again and upload it to Lamda and save it
                                    you should see no more errors
                                    Denis
                                    • O
                                      OceanK
                                      Ok cook I will try it. Just one more question. When you zip the files for the first time. Did you hardcode the MirrorMirror.js with the cert paths as well?
                                      And then again hardcoded the cert path for the MMM-MirrorMirrorOnTheWall
                                      Am I understanding it right?
                                      • O
                                        OceanK @richland007
                                        @richland007 So need more info here about this: At the very end of that file right before the very last } bracket
                                        ‘Unhandled’: function () {
                                        this.emit(‘:ask’, ‘Sorry I didnt understand that. Say help for assistance.’);
                                        So if I copy the last part from the index.js it should look like this with that extra ?
                                        // Send publish attempt to AWS IoT
                                        MirrorMirror.showVideo(result.items[0].id.videoId, searchTerm, alexaEmit);
                                        } else {
                                        this.emit(‘:askWithCard’, this.t(“SHOW_VIDEO_ERR”), this.t(“SHOW_VIDEO_ERR”), this.t(“ERROR_CARD”), this.t(“SHOW_VIDEO_ERR”))
                                        • O
                                          OceanK
                                          One more thing I notice. So Im going to do this from scratch again. when I did the npm install in the src folder(MirrorMirrorOnTheWallSkill)
                                          I did get these infor/error:
                                          npm WARN deprecated alexa-sdk@1.0.25: This version of the Alexa Skills Kit SDK is no longer supported. Please use the v2 release found here: https://github.com/alexa/alexa-skills-kit-sdk-for-nodejs
                                          do you think thats a problem ?
                                          • O
                                            OceanK
                                            I still get lamda error. could you please add your whole index.js and MirrorMirror.js file? just delete your key. So I can see how its all together.
                                            then I can repack the zip and upload to lamda and try it again
                                            • 2 / 7
