    Adjusting News Feed so it doesn’t overlap with left and right modules
    4 Posts 2 Posters 2.3k Views 2 Watching
    • H
      huso15
      As the title states, how can I adjust the newsfeed to make sure it doesn’t overlap with left and right modules when the news feed is a bit longer.
      https://imgur.com/gallery/Lj6duLy
      Here is my mirror for the reference. When I enable newsfeed, I often see it overlap with my live scores (left module) and Hue (right module). Astheticalkt it looks horrible. I want to fix it before I enable to module.
      Thank you!
      • MarosM
        Maros
        You can do it with configuration options mentioned in readme.
        Cut to more lines or select how many leathers can be displayed
        https://github.com/MichMich/MagicMirror/blob/master/modules/default/newsfeed/README.md
        • H
          huso15 @Maros
          @maros set wrap title to true? And adjust the characters length.
          • MarosM
            Maros
            @huso15 you can choose what is better.
            try cut lines and if it will be not acceptable you can try second option.
