    Echo dot and magicmirror
    13 Posts 3 Posters 8.6k Views 3 Watching
      maxbachmann
      You could just use a big IFrame to show the website
      C 1 Reply Last reply
        chassain 0 @maxbachmann
        @maxbachmann thanks for response…
        The iframe don t support web page. Only work with youtube…
        I try to disable fullscreen of magicmirror when i launch the mm… i don t find parameters…with this i ll could open a another web windows ( and so my alexa amazon application)…
        How can i reduce or have specify size of magicmiror ?..have a good day
          maxbachmann
          @chassain-0 true some sites don’t work (forgot the reason someone explained it to me a while back xD). But it’s definetly not just youtube working ;)
          I don’t know how to set the start size and hide the browser stuff. maybe someone else here knows :)
            chassain 0
            Maybe with electronOptions to configurate size and position…or in css with parameters html…i will try
              chassain 0
              It s ok. The solution was electronOptions…i have a windows for magicmirror and a another Windows for result of response echo dot…all in my screen of tv…bye
                chassain 0
                Hello everybody,
                Now i need your help. Actually the both Windows are on my screen (50% alexa and 50% MagicMirror) but it s not perfect to see moduls. So, i prefer to keep fullscreen and i would like to command the windows of alexa in the first plan (for example 20 s) with a script and come back to magicmirror automatically…
                The second and best idea will be to display alexa in the first plan when the alexa amazon application detects a new resultat on this app after calling the echo dot.
                This is différent of lot moduls here because moduls of alexa don t display results (only voice).
                I don t know if i m clear with my english (so fare).
                Thanks for your experience.
                  chassain 0
                  No one to launch a command on raspberry with echo dot alexa ? I find no script. Only with gpio.
                    maxbachmann
                    I never did this with javascript stuff yet but it’s definetly possible in the node_helper ;)
                    Appears there are already some libraries, but console input/output stuff I only did with C++ and python so far myself
                      chassain 0
                      thanks guy…i have to looking for about this
                        BenGig
                        Connecting an Echo dot is not easy. You probably have to create a custom skill in the Alexa developer console, connect it to a Lambda function which in turn calls your mirror by http. A web service has to receive the parsed response and react properly.
                        This is how it is done it with FHEM. It provides code for the local web service and templates for the Lamda function.
                          chassain 0
                          Thanks. i ve seen with alexa developper application but i am not strong with python and json script to arrange at my sauce :). (just a code with gpio). What is it FHEM ?
