    MMM-AssistantMk2
    421 Posts 61 Posters 690.2k Views 57 Watching
    • T Offline
      teitlebot
      @Module-Developers Why do you set this up as a smart TV. Why cant it be set up as a google assistant with video like the new displays they sell now?
        cola0927 @teitlebot
        @teitlebot oh, ok, thanks. It’s my first mirror, no relative experience before. I’ll be more careful next time.
          mirror.master
          Dying to use this module, but im stuck on node auth_and_test.js i keep getting the GLIBBCXX_3.4.21 not found error. tried the solutions found on the module page and a few others spots. but to no avail. any suggestions?
            A Former User @cola0927
            @cola0927 said in MMM-AssistantMk2 & MMM-GAction:
            Hi, I just tried installing MMM-AssistantMk2 by following the instruction. After saving the config.js (use default configuration) nothing shows up and all I can see is a black screen but a movable mouse pointer. I can’t even quit the mirror. I have no idea what do to now, do I have to start over from the very beginning? :loudly_crying_face:
            Show me your error logs. there could be many reasons about that symptom.
              A Former User @teitlebot
              @teitlebot said in MMM-AssistantMk2 & MMM-GAction:
              Is there a google assistant with video at the setup moment? Wasn’t it on my development. If it exists, go ahead sure.
                mirror.master
                dude try a: pm2 stop mm while ssh and then check your config. you are never stranded lol
                  A Former User @mirror.master
                  @mirror-master said in MMM-AssistantMk2 & MMM-GAction:
                  GLIBCXX problem shows your RPI doesn’t be running on Raspbian Stretch or proper dev-modules are not installed. My suggestion is… to use Stretch
                    mirror.master
                    upgrading now in hopes. thanks my friend. i have several pi’s with diff versions . when i was paranoid and less exp’d i was cloning my pie config, but forgot that one was jessie , one is stretch and another is whatever the hell i installed. Im pretty sure this is the older OS. Thanks again
                      cola0927
                      @sean Keyboard input or mouse clicking had no effect, maybe because I missed the “rebuild binaries” step.
                      So I started over again today and this time the microphone icon appeared after MMM-AssistantMk2 was installed, but couldn’t detect the voice, even after installed MMM-Hotword and MMM-NotificationTrigger.
                      Here is my config.js, basically used default values.
                                              module: "MMM-AssistantMk2",
                                              position: "lower_third",
                                              module: "MMM-Hotword",
                                              module: "MMM-NotificationTrigger",
                                                triggers:[
                                                   trigger: "ASSISTANT_ACTION",
                                                   triggerSenderFilter: (sender) => {
                                                     console.log(sender)
                                                     if (sender.name == 'MMM-AssistantMk2') {
                                                       return true
                                                     } else {
                                                       return false
                                                   triggerPayloadFilter: (payload) => {
                                                     console.log(payload)
                                                     return true
                                                   fires: [
                                                       fire:"SHOW_ALERT",
                                                       payload: (payload) => {
                                                         return {
                                                           type: "notification",
                                                           title: payload.type,
                                                           message: payload.command
                      Could you please let me know which part(s) I should modify? Thank you!
                        @cola0927
                        Your MMM-NotificationTrigger configuration is wrong.
                                triggers:[
                                    trigger: "HOTWORD_DETECTED",
                                    fires: [
                                        fire:"HOTWORD_PAUSE",
                                        fire:"ASSISTANT_ACTIVATE",
                        		delay: 200,
                                        payload: function(payload) {
                                          return {
                                            "profile": payload.hotword
                                    trigger: "ASSISTANT_DEACTIVATED",
                                    fires: [
                                        fire:"HOTWORD_RESUME"
                        Try this.
                          cola0927 @Guest
                          @sean Thank you for your prompt reply. I replaced my MMM-NotificationTrigger configuration, but still not working.
                          In the terminal, it shows that
                          assistant ready
                          Conversation Error: { Error: 14 UNAVAILABLE: Service unavailable.
                              at Object.exports.createStatusError (/home/pi/MagicMirror/modules/MMM-AssistantMk2/node_modules/grpc/src/common.js:87:15)
                              at ClientDuplexStream._emitStatusIfDone (/home/pi/MagicMirror/modules/MMM-AssistantMk2/node_modules/grpc/src/client.js:235:26)
                              at ClientDuplexStream._receiveStatus (/home/pi/MagicMirror/modules/MMM-AssistantMk2/node_modules/grpc/src/client.js:213:8)
                              at Object.onReceiveStatus (/home/pi/MagicMirror/modules/MMM-AssistantMk2/node_modules/grpc/src/client_interceptors.js:1290:15)
                              at InterceptingListener._callNext (/home/pi/MagicMirror/modules/MMM-AssistantMk2/node_modules/grpc/src/client_interceptors.js:564:42)
                              at InterceptingListener.onReceiveStatus (/home/pi/MagicMirror/modules/MMM-AssistantMk2/node_modules/grpc/src/client_interceptors.js:614:8)
                              at /home/pi/MagicMirror/modules/MMM-AssistantMk2/node_modules/grpc/src/client_interceptors.js:1110:18
                            code: 14,
                            metadata: Metadata { _internal_repr: {} },
                            details: 'Service unavailable.' }
                          Does it mean that something is incorrect in MMM-AssistantMk2?
                            @cola0927
                            I think that might be the same issue with this;
                            https://github.com/eouia/MMM-AssistantMk2/issues/16
                              @cola0927
                              Or most of those cases are caused by your mic setup. Check your configuration whether record.device has a proper name. (If your mic is default device, leave that field as null but when your mic has another name like plughw:1, set that field with it.
                                cola0927 @Guest
                                @sean After I changed the device name in both MMM-AssistantMk2 and MMM-Hotword, the module worked partially. I had to hit microphone icon to let its start listen to me, but that was a one-time response.
                                Do you have any idea what the problem is? Thank you so much.
                                  @cola0927
                                  Show me your configuration related with MMM-NotificationTrigger. I think MMM-NotificationTrigger cannot relay the connection between Hotword and Assistant.
                                    cola0927 @Guest
                                    @sean I used the one that you told me previously in config.js with a default MMM-NotificationTrigger.js
                                                              triggers:[
        fires: [
                                    		                  delay: 200,
        return {
        fires: [
                                    • T Offline
                                      teitlebot
                                      @cola0927 what word are you using for wakeup? Try snowboy.
                                        cola0927 @teitlebot
                                        @teitlebot Yes, I tried. It showed that hotword had deteted my voice but then stopped listening instead of waking up assistant. I agree with @Sean that the problem is notification trigger is not working properly. Unfortunately I have no idea how to correct it.
                                        • SubLim3S Offline
                                          SubLim3
                                          So I have been working on my mirror for a few weeks now and so far the MMM-AssistantMk2 module is the only thing I cant seem to get working. As mentioned in a number of previous post, when I apply the default module setup in the config.js and restart, I get an all black screen and nothing is responsive. I can SSH into the config.js and comment out the 5 lines for that module, reboot and all is good again. I have removed and rebuild the module with no errors and no new results.
                                          Has anyone found the cause behind this and how to resolve? I do have Hotword and NotificationTrigger modules running with no problem. Let me know if I need to drop an image file or some log files for further help. I’m truly stumped here. Any help would be greatly appreciated. Thanks in advanced.
                                          • T Offline
                                            teitlebot @SubLim3
                                            @sublim3 I dont know if there is a fix for this but thats why many of us are running in serveronly mode
                                            • 21
                                            • 22
                                            • 5 / 22
