    MMM-AssistantMk2
    421 Posts 61 Posters 778.9k Views 57 Watching
    • T
      teitlebot @MarkV
      @markv have a look at this if your mic isnt working
      https://github.com/eouia/MMM-AssistantMk2/issues/16
      • T
        teitlebot
        @jomwells @Module-Developers
        Did anyone figure out how to add led or sound, like a beep to show when google is listening and speaking. I dont think I’m good enough with linux to do this without a tutorial. Is it something that needs to be implemented in the module or can i learn how to do it from a simple aiy kit?
          A Former User @teitlebot
          @teitlebot
          https://github.com/eouia/MMM-AssistantMk2#outgoing-notifications-as-assistant-response
          Basic notifications will be emitted by its status.
          And you can modify module for catching the status to do your specific job.
          See https://github.com/eouia/MMM-AssistantMk2/blob/93d7eca6a3995987554d8deb4f4cd76b44e3f096/MMM-AssistantMk2.js#L264
          In .socketNotificationReceived(), you can catch each Assistant status.
          Anyway, I’m considering to add simple ding-dong waves for convenience in next patch.
          • T
            teitlebot
            @sean I had to leave the assistant action part of the code out because it was causing errors in my config file.
              cola0927
              Hi, I just tried installing MMM-AssistantMk2 by following the instruction. After saving the config.js (use default configuration) nothing shows up and all I can see is a black screen but a movable mouse pointer. I can’t even quit the mirror. I have no idea what do to now, do I have to start over from the very beginning? :loudly_crying_face:
              T ? 2 Replies Last reply Reply Quote 0
              • T
                teitlebot @cola0927
                @cola0927 many of us had this issue and thats why we run it in servomode
                • T
                  teitlebot
                  @Module-Developers Why do you set this up as a smart TV. Why cant it be set up as a google assistant with video like the new displays they sell now?
                    cola0927 @teitlebot
                    @teitlebot oh, ok, thanks. It’s my first mirror, no relative experience before. I’ll be more careful next time.
                      mirror.master
                      Dying to use this module, but im stuck on node auth_and_test.js i keep getting the GLIBBCXX_3.4.21 not found error. tried the solutions found on the module page and a few others spots. but to no avail. any suggestions?
                        A Former User @cola0927
                        @cola0927 said in MMM-AssistantMk2 & MMM-GAction:
                        Show me your error logs. there could be many reasons about that symptom.
                          @teitlebot said in MMM-AssistantMk2 & MMM-GAction:
                          Is there a google assistant with video at the setup moment? Wasn’t it on my development. If it exists, go ahead sure.
                            mirror.master
                            dude try a: pm2 stop mm while ssh and then check your config. you are never stranded lol
                              A Former User @mirror.master
                              @mirror-master said in MMM-AssistantMk2 & MMM-GAction:
                              GLIBCXX problem shows your RPI doesn’t be running on Raspbian Stretch or proper dev-modules are not installed. My suggestion is… to use Stretch
                                mirror.master
                                upgrading now in hopes. thanks my friend. i have several pi’s with diff versions . when i was paranoid and less exp’d i was cloning my pie config, but forgot that one was jessie , one is stretch and another is whatever the hell i installed. Im pretty sure this is the older OS. Thanks again
                                  cola0927
                                  @sean Keyboard input or mouse clicking had no effect, maybe because I missed the “rebuild binaries” step.
                                  So I started over again today and this time the microphone icon appeared after MMM-AssistantMk2 was installed, but couldn’t detect the voice, even after installed MMM-Hotword and MMM-NotificationTrigger.
                                  Here is my config.js, basically used default values.
                                                          module: "MMM-AssistantMk2",
                                                          position: "lower_third",
                                                          module: "MMM-Hotword",
                                                          module: "MMM-NotificationTrigger",
                                                            triggers:[
                                                               trigger: "ASSISTANT_ACTION",
                                                               triggerSenderFilter: (sender) => {
        console.log(sender)
        if (sender.name == 'MMM-AssistantMk2') {
        return true
        } else {
        return false
                                                               triggerPayloadFilter: (payload) => {
        console.log(payload)
        return true
                                                               fires: [
        fire:"SHOW_ALERT",
        payload: (payload) => {
        return {
        type: "notification",
        title: payload.type,
        message: payload.command
                                  Could you please let me know which part(s) I should modify? Thank you!
                                    @cola0927
                                    Your MMM-NotificationTrigger configuration is wrong.
                                            triggers:[
                                                trigger: "HOTWORD_DETECTED",
                                                fires: [
                                                    fire:"HOTWORD_PAUSE",
                                                    fire:"ASSISTANT_ACTIVATE",
                                    		delay: 200,
                                                    payload: function(payload) {
                                                      return {
                                                        "profile": payload.hotword
                                                trigger: "ASSISTANT_DEACTIVATED",
                                                fires: [
                                                    fire:"HOTWORD_RESUME"
                                    Try this.
                                      cola0927 @Guest
                                      @sean Thank you for your prompt reply. I replaced my MMM-NotificationTrigger configuration, but still not working.
                                      In the terminal, it shows that
                                      assistant ready
                                      Conversation Error: { Error: 14 UNAVAILABLE: Service unavailable.
                                          at Object.exports.createStatusError (/home/pi/MagicMirror/modules/MMM-AssistantMk2/node_modules/grpc/src/common.js:87:15)
                                          at ClientDuplexStream._emitStatusIfDone (/home/pi/MagicMirror/modules/MMM-AssistantMk2/node_modules/grpc/src/client.js:235:26)
                                          at ClientDuplexStream._receiveStatus (/home/pi/MagicMirror/modules/MMM-AssistantMk2/node_modules/grpc/src/client.js:213:8)
                                          at Object.onReceiveStatus (/home/pi/MagicMirror/modules/MMM-AssistantMk2/node_modules/grpc/src/client_interceptors.js:1290:15)
                                          at InterceptingListener._callNext (/home/pi/MagicMirror/modules/MMM-AssistantMk2/node_modules/grpc/src/client_interceptors.js:564:42)
                                          at InterceptingListener.onReceiveStatus (/home/pi/MagicMirror/modules/MMM-AssistantMk2/node_modules/grpc/src/client_interceptors.js:614:8)
                                          at /home/pi/MagicMirror/modules/MMM-AssistantMk2/node_modules/grpc/src/client_interceptors.js:1110:18
                                        code: 14,
                                        metadata: Metadata { _internal_repr: {} },
                                        details: 'Service unavailable.' }
                                      Does it mean that something is incorrect in MMM-AssistantMk2?
                                        @cola0927
                                        I think that might be the same issue with this;
                                          @cola0927
                                          Or most of those cases are caused by your mic setup. Check your configuration whether record.device has a proper name. (If your mic is default device, leave that field as null but when your mic has another name like plughw:1, set that field with it.
                                            cola0927 @Guest
                                            @sean After I changed the device name in both MMM-AssistantMk2 and MMM-Hotword, the module worked partially. I had to hit microphone icon to let its start listen to me, but that was a one-time response.
                                            Do you have any idea what the problem is? Thank you so much.
                                            • 21
                                            • 22
                                            • 5 / 22
