    MMM-AssistantMk2
    421 Posts 61 Posters 778.9k Views 57 Watching
      mirror.master
      dude try a: pm2 stop mm while ssh and then check your config. you are never stranded lol
        A Former User @mirror.master
        @mirror-master said in MMM-AssistantMk2 & MMM-GAction:
        Dying to use this module, but im stuck on node auth_and_test.js i keep getting the GLIBBCXX_3.4.21 not found error. tried the solutions found on the module page and a few others spots. but to no avail. any suggestions?
        GLIBCXX problem shows your RPI doesn’t be running on Raspbian Stretch or proper dev-modules are not installed. My suggestion is… to use Stretch
          mirror.master
          upgrading now in hopes. thanks my friend. i have several pi’s with diff versions . when i was paranoid and less exp’d i was cloning my pie config, but forgot that one was jessie , one is stretch and another is whatever the hell i installed. Im pretty sure this is the older OS. Thanks again
            cola0927
            @sean Keyboard input or mouse clicking had no effect, maybe because I missed the “rebuild binaries” step.
            So I started over again today and this time the microphone icon appeared after MMM-AssistantMk2 was installed, but couldn’t detect the voice, even after installed MMM-Hotword and MMM-NotificationTrigger.
            Here is my config.js, basically used default values.
                                    module: "MMM-AssistantMk2",
                                    position: "lower_third",
                                    module: "MMM-Hotword",
                                    module: "MMM-NotificationTrigger",
                                      triggers:[
                                         trigger: "ASSISTANT_ACTION",
                                         triggerSenderFilter: (sender) => {
                                           console.log(sender)
                                           if (sender.name == 'MMM-AssistantMk2') {
                                             return true
                                           } else {
                                             return false
                                         triggerPayloadFilter: (payload) => {
                                           console.log(payload)
                                           return true
                                         fires: [
                                             fire:"SHOW_ALERT",
                                             payload: (payload) => {
                                               return {
                                                 type: "notification",
                                                 title: payload.type,
                                                 message: payload.command
            Could you please let me know which part(s) I should modify? Thank you!
              A Former User @cola0927
              @cola0927
              Your MMM-NotificationTrigger configuration is wrong.
                      triggers:[
                          trigger: "HOTWORD_DETECTED",
                          fires: [
                              fire:"HOTWORD_PAUSE",
                              fire:"ASSISTANT_ACTIVATE",
              		delay: 200,
                              payload: function(payload) {
                                return {
                                  "profile": payload.hotword
                          trigger: "ASSISTANT_DEACTIVATED",
                          fires: [
                              fire:"HOTWORD_RESUME"
              Try this.
                cola0927 @Guest
                @sean Thank you for your prompt reply. I replaced my MMM-NotificationTrigger configuration, but still not working.
                In the terminal, it shows that
                assistant ready
                Conversation Error: { Error: 14 UNAVAILABLE: Service unavailable.
                    at Object.exports.createStatusError (/home/pi/MagicMirror/modules/MMM-AssistantMk2/node_modules/grpc/src/common.js:87:15)
                    at ClientDuplexStream._emitStatusIfDone (/home/pi/MagicMirror/modules/MMM-AssistantMk2/node_modules/grpc/src/client.js:235:26)
                    at ClientDuplexStream._receiveStatus (/home/pi/MagicMirror/modules/MMM-AssistantMk2/node_modules/grpc/src/client.js:213:8)
                    at Object.onReceiveStatus (/home/pi/MagicMirror/modules/MMM-AssistantMk2/node_modules/grpc/src/client_interceptors.js:1290:15)
                    at InterceptingListener._callNext (/home/pi/MagicMirror/modules/MMM-AssistantMk2/node_modules/grpc/src/client_interceptors.js:564:42)
                    at InterceptingListener.onReceiveStatus (/home/pi/MagicMirror/modules/MMM-AssistantMk2/node_modules/grpc/src/client_interceptors.js:614:8)
                    at /home/pi/MagicMirror/modules/MMM-AssistantMk2/node_modules/grpc/src/client_interceptors.js:1110:18
                  code: 14,
                  metadata: Metadata { _internal_repr: {} },
                  details: 'Service unavailable.' }
                Does it mean that something is incorrect in MMM-AssistantMk2?
                  @cola0927
                  I think that might be the same issue with this;
                  https://github.com/eouia/MMM-AssistantMk2/issues/16
                    @cola0927
                    Or most of those cases are caused by your mic setup. Check your configuration whether record.device has a proper name. (If your mic is default device, leave that field as null but when your mic has another name like plughw:1, set that field with it.
                      cola0927 @Guest
                      @sean After I changed the device name in both MMM-AssistantMk2 and MMM-Hotword, the module worked partially. I had to hit microphone icon to let its start listen to me, but that was a one-time response.
                      Do you have any idea what the problem is? Thank you so much.
                        @cola0927
                        Show me your configuration related with MMM-NotificationTrigger. I think MMM-NotificationTrigger cannot relay the connection between Hotword and Assistant.
                          cola0927 @Guest
                          @sean I used the one that you told me previously in config.js with a default MMM-NotificationTrigger.js
                                                    triggers:[
                                                        fires: [
                          		                  delay: 200,
                                                              return {
                                                        fires: [
                          • T
                            teitlebot
                            @cola0927 what word are you using for wakeup? Try snowboy.
                              cola0927 @teitlebot
                              @teitlebot Yes, I tried. It showed that hotword had deteted my voice but then stopped listening instead of waking up assistant. I agree with @Sean that the problem is notification trigger is not working properly. Unfortunately I have no idea how to correct it.
                              • SubLim3S
                                SubLim3
                                So I have been working on my mirror for a few weeks now and so far the MMM-AssistantMk2 module is the only thing I cant seem to get working. As mentioned in a number of previous post, when I apply the default module setup in the config.js and restart, I get an all black screen and nothing is responsive. I can SSH into the config.js and comment out the 5 lines for that module, reboot and all is good again. I have removed and rebuild the module with no errors and no new results.
                                Has anyone found the cause behind this and how to resolve? I do have Hotword and NotificationTrigger modules running with no problem. Let me know if I need to drop an image file or some log files for further help. I’m truly stumped here. Any help would be greatly appreciated. Thanks in advanced.
                                • T
                                  teitlebot @SubLim3
                                  @sublim3 I dont know if there is a fix for this but thats why many of us are running in serveronly mode
                                    @cola0927 @SubLim3
                                    Well, sorry for the inconvenience. Your configuration looks no problem. The easy way to fix could be to test some suspicious points and log it, but it might need some experiences.
                                    Do you have Telegram? I can help you with it in real-time. my Telegram ID is “@eouia”. Give me a chat anytime.
                                      mirror.master @Guest
                                      @sean Yes sir! Thank you! Updated everything to stretch and got my mkassistant to run! my next dilemma was linking hotword and notrigger but i gave up, make just make a physical button to click the mic, now on to those tutorials lol wherever they may be.
                                      • T
                                        teitlebot
                                        @Sean Any suggestions of integration facial recognition to the magic mirror?
                                          A Former User @teitlebot
                                          @teitlebot said in MMM-AssistantMk2 & MMM-GAction:
                                          I made this module to work with other modules by NotificationTrigger. So Another Facial recognition module could activate AssistantMK2 if there is a proper notification broadcasting. There is no need to implement that function in AssistantMk2 itself.
                                          • T
                                            teitlebot @Guest
                                            @sean Thank You. Some more learning on my part. I plan on installing
                                            https://github.com/paviro/MMM-Facial-Recognition and will report back here.
                                            • 21
                                            • 22
                                            • 5 / 22
