    MMM-AssistantMk2
    421 Posts 61 Posters 762.0k Views 57 Watching
    • T Offline
      teitlebot
      @cola0927 what word are you using for wakeup? Try snowboy.
        cola0927 @teitlebot
        @teitlebot Yes, I tried. It showed that hotword had deteted my voice but then stopped listening instead of waking up assistant. I agree with @Sean that the problem is notification trigger is not working properly. Unfortunately I have no idea how to correct it.
        • SubLim3S Offline
          SubLim3
          So I have been working on my mirror for a few weeks now and so far the MMM-AssistantMk2 module is the only thing I cant seem to get working. As mentioned in a number of previous post, when I apply the default module setup in the config.js and restart, I get an all black screen and nothing is responsive. I can SSH into the config.js and comment out the 5 lines for that module, reboot and all is good again. I have removed and rebuild the module with no errors and no new results.
          Has anyone found the cause behind this and how to resolve? I do have Hotword and NotificationTrigger modules running with no problem. Let me know if I need to drop an image file or some log files for further help. I’m truly stumped here. Any help would be greatly appreciated. Thanks in advanced.
          • T Offline
            teitlebot @SubLim3
            @sublim3 I dont know if there is a fix for this but thats why many of us are running in serveronly mode
              A Former User @cola0927
              @cola0927 @SubLim3
              Well, sorry for the inconvenience. Your configuration looks no problem. The easy way to fix could be to test some suspicious points and log it, but it might need some experiences.
              Do you have Telegram? I can help you with it in real-time. my Telegram ID is “@eouia”. Give me a chat anytime.
                mirror.master @Guest
                @sean Yes sir! Thank you! Updated everything to stretch and got my mkassistant to run! my next dilemma was linking hotword and notrigger but i gave up, make just make a physical button to click the mic, now on to those tutorials lol wherever they may be.
                • T Offline
                  teitlebot
                  @Sean Any suggestions of integration facial recognition to the magic mirror?
                    A Former User @teitlebot
                    @teitlebot said in MMM-AssistantMk2 & MMM-GAction:
                    I made this module to work with other modules by NotificationTrigger. So Another Facial recognition module could activate AssistantMK2 if there is a proper notification broadcasting. There is no need to implement that function in AssistantMk2 itself.
                    • T Offline
                      teitlebot @Guest
                      @sean Thank You. Some more learning on my part. I plan on installing
                      https://github.com/paviro/MMM-Facial-Recognition and will report back here.
                      • T Offline
                        teitlebot
                        For those interested, I upgraded from a tiny usb mic to a playstation eye and had much improvement on voice recognition.
                          mirror.master
                          Hey guys any idea why my Google assistant won’t go back to sleep after use? It’s honestly recent, and weird. I can use it as normal, but the Mic stays blue after the fact and doesn’t turn off.
                          • V Offline
                            vijayrraut @Guest
                            Hello @sean , I am also looking for a “ding” sound on hotword detection, but no luck. Did you get a chance to add this feature to assistantmk2. It would be of great help when talking to the mirror from far distance.
                              A Former User @vijayrraut
                              @vijayrraut
                              I’ll consider it.
                                @vijayrraut
                                Ver 1.1.0 is ready. (not yet merged into master branch)
                                You can use ding sound on 1.1.0. It will be my pleasure if you test this for me.
                                https://github.com/eouia/MMM-AssistantMk2/tree/1.1.0
                                T V 2 Replies Last reply Reply Quote 0
                                • T Offline
                                  teitlebot @Guest
                                  @sean I’ll give it a try. How do I install something that isnt in the master branch?
                                    @teitlebot
                                    sudo apt-get install mpg321
                                    cd ~/MagicMirror/modules/MMM-AssistantMk2
                                    git pull
                                    git checkout 1.1.0
                                    npm install --save wav
                                      A Former User
                                      UPDATE
                                      [1.1.0] - 2018.10.04
                                      • MP3 Output is supported. Now you can get more unchunky sound result.(Set audio.encodingOut to MP3 // OGG is not yet supported.)
                                      • ding.wav will be played when Assistant is ready to hear your voice.
                                      • How to update from prior version
                                      git pull
                                      • T Offline
                                        teitlebot @Guest
                                        @sean Thank You
                                        Ding is working just fine. Thank You. A little annoying sound and I was thinking of replacing it with another sound file. What if I wanted google to say something instead of ding, can I give it text to say easily?
                                          @teitlebot
                                          change other wav file and rename it as ding.wav,
                                          Anyway, if you mean Text-To-Speech, nope. (My prior had that functionality but I abandoned it) I don’t want to back again.
                                            cola0927 @teitlebot
                                            @teitlebot totally agree!
                                            • 21
                                            • 22
                                            • 6 / 22
