    MMM-AssistantMk2
    421 Posts 61 Posters 804.2k Views 57 Watching
      A Former User @vijayrraut
      @vijayrraut
      I’ll consider it.
        @vijayrraut
        Ver 1.1.0 is ready. (not yet merged into master branch)
        You can use ding sound on 1.1.0. It will be my pleasure if you test this for me.
        https://github.com/eouia/MMM-AssistantMk2/tree/1.1.0
        T V 2 Replies Last reply
        • T
          teitlebot @Guest
          @sean I’ll give it a try. How do I install something that isnt in the master branch?
          ? 1 Reply Last reply
            A Former User @teitlebot
            @teitlebot
            sudo apt-get install mpg321
            cd ~/MagicMirror/modules/MMM-AssistantMk2
            git pull
            git checkout 1.1.0
            npm install --save wav
              A Former User
              UPDATE
              [1.1.0] - 2018.10.04
              • MP3 Output is supported. Now you can get more unchunky sound result.(Set audio.encodingOut to MP3 // OGG is not yet supported.)
              • ding.wav will be played when Assistant is ready to hear your voice.
              • How to update from prior version
              git pull
              T 1 Reply Last reply
              • T
                teitlebot @Guest
                @sean Thank You
                Ding is working just fine. Thank You. A little annoying sound and I was thinking of replacing it with another sound file. What if I wanted google to say something instead of ding, can I give it text to say easily?
                  @teitlebot
                  change other wav file and rename it as ding.wav,
                  Anyway, if you mean Text-To-Speech, nope. (My prior had that functionality but I abandoned it) I don’t want to back again.
                    cola0927 @teitlebot
                    @teitlebot totally agree!
                    • T
                      teitlebot @Guest
                      @sean ok. Can I ask why you abandoned it?
                        @teitlebot
                        Complexity. And most TTS solutions ate not so good to hear. The best Google solution is not free.
                        T 2 Replies Last reply
                        • T
                          teitlebot @Guest
                          @sean I see. I manually created a sound file and replaced it and it works fine, although a bit choppy.
                          • T
                            teitlebot @Guest
                            @sean Next Question
                            Why doesnt google allow me to use the MM to play music. I can get it to play out of my google home mini in my kitchen using the MM but there doesnt seem a way to use the MM speaker to play. not even spotify.
                            Although youtube does work as you seem to have added that functionality.
                              @teitlebot
                              Idk. Because this sdk might be just on beta stage?
                              • V
                                vijayrraut @Guest
                                @sean Thank you very much. The changes for “ding” sound are working like a charm. Initially I got error while git pull as I had my own changes to my .js files. I did ‘git stash’ and merged the new changes. Thank you so much.
                                git stash
                                git pull
                                git stash pop
                                  Stabber
                                  Hi. I have a problem at this point:
                                  In your SBC, you can run auth-tool for authentification. (not via SSH)
                                  node auth_and_test.js
                                  and i see this:
                                  1. That’s an error.
                                  Error: disabled_client
                                  A native application: project-1019057327317
                                  You can email the developer of this application at: unconfiguredapp@google.com
                                  This app is not yet configured to make OAuth requests. To do that, set up the app’s OAuth consent screen in the Google Cloud Console.
                                  Probably SSH is the problem, but I don’t understand this: “(So you’d better to execute this script in your RPI shell, not via SSH)”
                                  Could you help me with this?
                                    A Former User @Stabber
                                    @stabber
                                    I think your Google project(project-1019057327317) is not setup completely. There could be many reasons to cause 4XX errors. But I think you missed making consent screen. Go To Google Cloud Platform > YOUR PROJECT > APIs & Services > Credentials > OAuth Consent Screen Tab and put some information.
                                    I think Application name and Support email are enough. You don’t need to verify, just save it. Then try again.
                                    • Cr4z33C
                                      Cr4z33
                                      Before I am going to try to use these modules can someone please tell me whether they can be used with the Google AIY Voice Kit (v1) or not? :grimacing_face:
                                      ? citizendevpiC 2 Replies Last reply
                                        A Former User @Cr4z33
                                        @cr4z33
                                        If you can record and play your voice with that device, it could be.
                                        • citizendevpiC
                                          citizendevpi @Cr4z33
                                          @cr4z33 I am in the process of setting up now on voice kit v1. did you start yet?
                                          • citizendevpiC
                                            citizendevpi
                                            ok so i have installed hotword (working i guess), assistantmk2 i went all the way tru and got a response after typing hello what time is it . and get api interactions in my google cloud. also installed notifaction trigger the mirror starts up and if i say jarvis,smartmirror i get hotword dectected but nothing from assistant im at a loss on how to get it going/response. i will upload my terminal output if i can figure out how if any one can help im pretty sure im missing somthing in my config.EDIT ok i input the test config and BAM it is alive the audio is super crunchy but it could be a hardware issue so any one interested yes i am running pi3b+ with aiy kit v 1 and it works.
                                            • 21
                                            • 22
                                            • 6 / 22
