    MMM-AssistantMk2
    421 Posts 61 Posters 804.1k Views 57 Watching
    • T
      teitlebot @Guest
      @sean I see. I manually created a sound file and replaced it and it works fine, although a bit choppy.
      • T
        teitlebot @Guest
        @sean Next Question
        Why doesnt google allow me to use the MM to play music. I can get it to play out of my google home mini in my kitchen using the MM but there doesnt seem a way to use the MM speaker to play. not even spotify.
        Although youtube does work as you seem to have added that functionality.
        ? 1 Reply Last reply
          A Former User @teitlebot
          @teitlebot
          Idk. Because this sdk might be just on beta stage?
          • V
            vijayrraut @Guest
            @sean Thank you very much. The changes for “ding” sound are working like a charm. Initially I got error while git pull as I had my own changes to my .js files. I did ‘git stash’ and merged the new changes. Thank you so much.
            git stash
            git pull
            git stash pop
            npm install --save wav
              Stabber
              Hi. I have a problem at this point:
              In your SBC, you can run auth-tool for authentification. (not via SSH)
              cd ~/MagicMirror/modules/MMM-AssistantMk2
              node auth_and_test.js
              and i see this:
              1. That’s an error.
              Error: disabled_client
              A native application: project-1019057327317
              You can email the developer of this application at: unconfiguredapp@google.com
              This app is not yet configured to make OAuth requests. To do that, set up the app’s OAuth consent screen in the Google Cloud Console.
              Probably SSH is the problem, but I don’t understand this: “(So you’d better to execute this script in your RPI shell, not via SSH)”
              Could you help me with this?
                A Former User @Stabber
                @stabber
                I think your Google project(project-1019057327317) is not setup completely. There could be many reasons to cause 4XX errors. But I think you missed making consent screen. Go To Google Cloud Platform > YOUR PROJECT > APIs & Services > Credentials > OAuth Consent Screen Tab and put some information.
                I think Application name and Support email are enough. You don’t need to verify, just save it. Then try again.
                • Cr4z33C
                  Cr4z33
                  Before I am going to try to use these modules can someone please tell me whether they can be used with the Google AIY Voice Kit (v1) or not? :grimacing_face:
                  ? citizendevpiC 2 Replies Last reply
                    A Former User @Cr4z33
                    @cr4z33
                    If you can record and play your voice with that device, it could be.
                    • citizendevpiC
                      citizendevpi @Cr4z33
                      @cr4z33 I am in the process of setting up now on voice kit v1. did you start yet?
                      • citizendevpiC
                        citizendevpi
                        ok so i have installed hotword (working i guess), assistantmk2 i went all the way tru and got a response after typing hello what time is it . and get api interactions in my google cloud. also installed notifaction trigger the mirror starts up and if i say jarvis,smartmirror i get hotword dectected but nothing from assistant im at a loss on how to get it going/response. i will upload my terminal output if i can figure out how if any one can help im pretty sure im missing somthing in my config.EDIT ok i input the test config and BAM it is alive the audio is super crunchy but it could be a hardware issue so any one interested yes i am running pi3b+ with aiy kit v 1 and it works.
                          A Former User @citizendevpi
                          @citizendevpi @Cr4z33
                          Still got problem?
                          I’m making whole new update. It will be more stable and easy to install & use. I’ll release this new update in this week. Plz wait a few days.
                          citizendevpiC Cr4z33C 2 Replies Last reply
                          • citizendevpiC
                            citizendevpi @Guest
                            @sean no i did some tweeking with mp3 for audio.encoding out and that cleared up the sound issue i do get a frequent js error like every time i use the hotword:Error: open() failed: -1
                            at Speaker._open (/home/pi/MagicMirror/modules/MMM-AssistantMk2/node_modules/speaker/index.js:106:13)
                            at Speaker._write (/home/pi/MagicMirror/modules/MMM-AssistantMk2/node_modules/speaker/index.js:183:23)
                            at doWrite (/home/pi/MagicMirror/modules/MMM-AssistantMk2/node_modules/readable-stream/lib/_stream_writable.js:428:64)
                            at writeOrBuffer (/home/pi/MagicMirror/modules/MMM-AssistantMk2/node_modules/readable-stream/lib/_stream_writable.js:417:5)
                            at Speaker.Writable.write (/home/pi/MagicMirror/modules/MMM-AssistantMk2/node_modules/readable-stream/lib/_stream_writable.js:334:11)
                            at Reader. (/home/pi/MagicMirror/modules/MMM-AssistantMk2/node_helper.js:287:17)
                            at emitNone (events.js:111:20)
                            at Reader.emit (events.js:208:7)
                            at /home/pi/MagicMirror/modules/MMM-AssistantMk2/node_modules/wav/node_modules/readable-stream/lib/_stream_readable.js:934:16
                            at _combinedTickCallback (internal/process/next_tick.js:131:7)
                            Some error happens. Try again.
                              @citizendevpi
                              First, I will abandon this annoying module dependency - Speaker. Sometimes it will not work as my feature. So, currently I’m not making fix about Speaker module. it will be deprecated.
                              Instead using node module, I will use other stable method - your default audio player program. I’m testing now and it will be released soon.
                              citizendevpiC 1 Reply Last reply
                              • citizendevpiC
                                citizendevpi @Guest
                                @sean you are the man !!! thank you for the info and i will be looking forward to the latest release any time you need anything let me know fyi i love ghost in the shell also keep workin.
                                • Cr4z33C
                                  Cr4z33 @Guest
                                  @sean said in MMM-AssistantMk2 & MMM-GAction:
                                  Still got problem?
                                  Fortunately I was busy at getting to work two LED strips so OK I will wait with pleasure hehe.
                                  Thanks for letting me know. :thumbs_up_medium-light_skin_tone:
                                    A Former User
                                    UPDATED (2.0.0)
                                    • Whole new build-up.
                                    • Annoying speaker dependencies deprecated
                                    • More stable. (I think)
                                    • Choppy sound issue solved(I think), If you get still this issue, that might be the lack of computing power of your device.
                                    • NotificationTrigger dependency free. Now you can activate without NotificationTrigger (But If you want, you can still use it.)
                                    • Making Hook and GAction becomes easier
                                    • MMM-TelegramBot and other modules supported
                                    Cr4z33C citizendevpiC 3 Replies Last reply
                                    • Cr4z33C
                                      Cr4z33 @Guest
                                      @sean
                                      HURRAY! :man_dancing_medium-light_skin_tone:
                                      Going to implement it right now!
                                      • Cr4z33C
                                        Cr4z33 @Guest
                                        @sean hmm it is to my understanding that a device ID is mandatory right?
                                        Do you have any idea if the Raspberry Voice HAT can be used with your model?
                                        And if yes how can I find out the device id then? :thinking_face:
                                          @cr4z33
                                          Do you mean device ID for audio device?
                                          If you have a sound card(HAT) or audio processing integrated into your motherboard, get a list of all the audio devices on your system by executing this command:
                                          arecord --list-devices
                                          You should get output similar to this:
                                          **** List of CAPTURE Hardware Devices ****
                                          card 0: IXP [ATI IXP], device 0: ATI IXP AC97 [ATI IXP AC97]
                                            Subdevices: 1/1
                                            Subdevice #0: subdevice #0
                                          In this case, your recording device is hw:0,0.
                                          You can test with this.
                                          arecord  -D hw:0,0 -d 5 test.wav
                                          For output device, similar. use
                                          aplay --list-devices
                                          Cr4z33C 1 Reply Last reply
                                          • Cr4z33C
                                            Cr4z33 @Guest
                                            @sean
                                            Thanks for helping a (Raspberry) noob here hehe.
                                            I got a different result:
                                            $ arecord --list-devices
                                            card 0: sndrpigooglevoi [snd_rpi_googlevoicehat_soundcar], device 0: Google voiceHAT SoundCard HiFi voicehat-hifi-0 []
                                              Subdevices: 0/1
                                            Therefore would my recording device still be hw:0,0?
                                            aplay gave me this:
                                            **** List of PLAYBACK Hardware Devices ****
                                              Subdevices: 0/1
                                            I believe it’s the same ID like above right?
                                            • 21
                                            • 22
                                            • 7 / 22
