    MMM-AssistantMk2
    421 Posts 61 Posters 778.9k Views 57 Watching
    • citizendevpiC
      citizendevpi
      ok so i have installed hotword (working i guess), assistantmk2 i went all the way tru and got a response after typing hello what time is it . and get api interactions in my google cloud. also installed notifaction trigger the mirror starts up and if i say jarvis,smartmirror i get hotword dectected but nothing from assistant im at a loss on how to get it going/response. i will upload my terminal output if i can figure out how if any one can help im pretty sure im missing somthing in my config.EDIT ok i input the test config and BAM it is alive the audio is super crunchy but it could be a hardware issue so any one interested yes i am running pi3b+ with aiy kit v 1 and it works.
        A Former User @citizendevpi
        @citizendevpi @Cr4z33
        Still got problem?
        I’m making whole new update. It will be more stable and easy to install & use. I’ll release this new update in this week. Plz wait a few days.
        citizendevpiC Cr4z33C 2 Replies Last reply Reply Quote 0
        • citizendevpiC
          citizendevpi @Guest
          @sean no i did some tweeking with mp3 for audio.encoding out and that cleared up the sound issue i do get a frequent js error like every time i use the hotword:Error: open() failed: -1
          at Speaker._open (/home/pi/MagicMirror/modules/MMM-AssistantMk2/node_modules/speaker/index.js:106:13)
          at Speaker._write (/home/pi/MagicMirror/modules/MMM-AssistantMk2/node_modules/speaker/index.js:183:23)
          at doWrite (/home/pi/MagicMirror/modules/MMM-AssistantMk2/node_modules/readable-stream/lib/_stream_writable.js:428:64)
          at writeOrBuffer (/home/pi/MagicMirror/modules/MMM-AssistantMk2/node_modules/readable-stream/lib/_stream_writable.js:417:5)
          at Speaker.Writable.write (/home/pi/MagicMirror/modules/MMM-AssistantMk2/node_modules/readable-stream/lib/_stream_writable.js:334:11)
          at Reader. (/home/pi/MagicMirror/modules/MMM-AssistantMk2/node_helper.js:287:17)
          at emitNone (events.js:111:20)
          at Reader.emit (events.js:208:7)
          at /home/pi/MagicMirror/modules/MMM-AssistantMk2/node_modules/wav/node_modules/readable-stream/lib/_stream_readable.js:934:16
          at _combinedTickCallback (internal/process/next_tick.js:131:7)
          Some error happens. Try again.
            @citizendevpi
            First, I will abandon this annoying module dependency - Speaker. Sometimes it will not work as my feature. So, currently I’m not making fix about Speaker module. it will be deprecated.
            Instead using node module, I will use other stable method - your default audio player program. I’m testing now and it will be released soon.
            citizendevpiC 1 Reply Last reply Reply Quote 0
            • citizendevpiC
              citizendevpi @Guest
              @sean you are the man !!! thank you for the info and i will be looking forward to the latest release any time you need anything let me know fyi i love ghost in the shell also keep workin.
              • Cr4z33C
                Cr4z33 @Guest
                @sean said in MMM-AssistantMk2 & MMM-GAction:
                Still got problem?
                Fortunately I was busy at getting to work two LED strips so OK I will wait with pleasure hehe.
                Thanks for letting me know. :thumbs_up_medium-light_skin_tone:
                  A Former User
                  UPDATED (2.0.0)
                  • Whole new build-up.
                  • Annoying speaker dependencies deprecated
                  • More stable. (I think)
                  • Choppy sound issue solved(I think), If you get still this issue, that might be the lack of computing power of your device.
                  • NotificationTrigger dependency free. Now you can activate without NotificationTrigger (But If you want, you can still use it.)
                  • Making Hook and GAction becomes easier
                  • MMM-TelegramBot and other modules supported
                  Cr4z33C citizendevpiC 3 Replies Last reply Reply Quote 1
                  • Cr4z33C
                    Cr4z33 @Guest
                    @sean
                    HURRAY! :man_dancing_medium-light_skin_tone:
                    Going to implement it right now!
                    • Cr4z33C
                      Cr4z33 @Guest
                      @sean hmm it is to my understanding that a device ID is mandatory right?
                      Do you have any idea if the Raspberry Voice HAT can be used with your model?
                      And if yes how can I find out the device id then? :thinking_face:
                        A Former User @Cr4z33
                        @cr4z33
                        Do you mean device ID for audio device?
                        If you have a sound card(HAT) or audio processing integrated into your motherboard, get a list of all the audio devices on your system by executing this command:
                        arecord --list-devices
                        You should get output similar to this:
                        **** List of CAPTURE Hardware Devices ****
                        card 0: IXP [ATI IXP], device 0: ATI IXP AC97 [ATI IXP AC97]
                          Subdevices: 1/1
                          Subdevice #0: subdevice #0
                        In this case, your recording device is hw:0,0.
                        You can test with this.
                        arecord  -D hw:0,0 -d 5 test.wav
                        For output device, similar. use
                        aplay --list-devices
                        • Cr4z33C
                          Cr4z33 @Guest
                          @sean
                          Thanks for helping a (Raspberry) noob here hehe.
                          I got a different result:
                          $ arecord --list-devices
                          card 0: sndrpigooglevoi [snd_rpi_googlevoicehat_soundcar], device 0: Google voiceHAT SoundCard HiFi voicehat-hifi-0 []
                            Subdevices: 0/1
                          Therefore would my recording device still be hw:0,0?
                          aplay gave me this:
                          **** List of PLAYBACK Hardware Devices ****
                            Subdevices: 0/1
                          I believe it’s the same ID like above right?
                            @cr4z33 Details are dependent with also your asound config. But,
                            Can you record and play some audio in Terminal?
                            arecord -t 5 test.wav & aplay test.wav
                            Can you execute this? tell me the result.
                            (I haven’t had voiceHAT, so cannot guaranteed, but same name could be available.)
                            • Cr4z33C
                              Cr4z33 @Guest
                              @sean
                              I get an error and please note that I’ve tried to translate to English. :winking_face:
                              [1] 2911
                              arecord: main:574: unrecognized file format 5
                              test.wav: File or directory does not exist
                              [1]+  Output 1                arecord -t 5 test.wav
                                @cr4z33
                                Try this.
                                arecord -t 5 -D hw:0,0 test.wav
                                Does this make test.wav?
                                If so, try this again.
                                aplay -D hw:0,0 test.wav
                                • Cr4z33C
                                  Cr4z33 @Guest
                                  @sean
                                  Nope. :pensive_face:
                                    @cr4z33
                                    cat ~/.asoundrc
                                    Tell me the result.
                                    How you can setup previously? (I think you purchased that device for Google AIY project. Was there any instructions?)
                                      @cr4z33
                                      Oops ! my mistake!
                                      arecord -d 5 -D hw:0,0 test.wav
                                      • Cr4z33C
                                        Cr4z33 @Guest
                                        @cr4z33
                                        cat ~/.asoundrc
                                        Tell me the result.
                                        pi@raspberrypi:~ $ cat ~/.asoundrc
                                        cat: /home/pi/.asoundrc: File or directory does not exist
                                        It’s the so- called Google Voice Kit AIY (https://aiyprojects.withgoogle.com/voice-v1/).
                                        I used a ready meal Raspbian image made by Google.
                                        Apart from creating the JSON file everything else consists of ready scripts (i.e assistant_library_demo.py is a script to runs and uses Google Assistant):
                                        https://github.com/google/aiyprojects-raspbian/tree/voicekit
                                          @cr4z33
                                          Hmmm… As I know,
                                          arecord -d 5 test.wav
                                          aplay test.wav
                                          This should work because there is no other suspicious things. your card and device no is 0,0 and that is the default.
                                          • Cr4z33C
                                            Cr4z33 @Guest
                                            @sean
                                            Again I made a noob error… I ran both commands at once lol! :smiling_face_with_open_mouth_cold_sweat:
                                            Running them separately worked like a charm! :thumbs_up_medium-light_skin_tone:
                                            I am going now to retry with the module addition.
                                            • 21
                                            • 22
                                            • 7 / 22
