    MMM-AssistantMk2
    421 Posts 61 Posters 789.0k Views 57 Watching
    • citizendevpiC
      citizendevpi @Guest
      @sean no i did some tweeking with mp3 for audio.encoding out and that cleared up the sound issue i do get a frequent js error like every time i use the hotword:Error: open() failed: -1
      at Speaker._open (/home/pi/MagicMirror/modules/MMM-AssistantMk2/node_modules/speaker/index.js:106:13)
      at Speaker._write (/home/pi/MagicMirror/modules/MMM-AssistantMk2/node_modules/speaker/index.js:183:23)
      at doWrite (/home/pi/MagicMirror/modules/MMM-AssistantMk2/node_modules/readable-stream/lib/_stream_writable.js:428:64)
      at writeOrBuffer (/home/pi/MagicMirror/modules/MMM-AssistantMk2/node_modules/readable-stream/lib/_stream_writable.js:417:5)
      at Speaker.Writable.write (/home/pi/MagicMirror/modules/MMM-AssistantMk2/node_modules/readable-stream/lib/_stream_writable.js:334:11)
      at Reader. (/home/pi/MagicMirror/modules/MMM-AssistantMk2/node_helper.js:287:17)
      at emitNone (events.js:111:20)
      at Reader.emit (events.js:208:7)
      at /home/pi/MagicMirror/modules/MMM-AssistantMk2/node_modules/wav/node_modules/readable-stream/lib/_stream_readable.js:934:16
      at _combinedTickCallback (internal/process/next_tick.js:131:7)
      Some error happens. Try again.
      ? 1 Reply Last reply
        A Former User @citizendevpi
        @citizendevpi
        First, I will abandon this annoying module dependency - Speaker. Sometimes it will not work as my feature. So, currently I’m not making fix about Speaker module. it will be deprecated.
        Instead using node module, I will use other stable method - your default audio player program. I’m testing now and it will be released soon.
        citizendevpiC 1 Reply Last reply
        • citizendevpiC
          citizendevpi @Guest
          @sean you are the man !!! thank you for the info and i will be looking forward to the latest release any time you need anything let me know fyi i love ghost in the shell also keep workin.
          • Cr4z33C
            Cr4z33 @Guest
            @sean said in MMM-AssistantMk2 & MMM-GAction:
            @citizendevpi @Cr4z33
            Still got problem?
            I’m making whole new update. It will be more stable and easy to install & use. I’ll release this new update in this week. Plz wait a few days.
            Fortunately I was busy at getting to work two LED strips so OK I will wait with pleasure hehe.
            Thanks for letting me know. :thumbs_up_medium-light_skin_tone:
              A Former User
              UPDATED (2.0.0)
              • Whole new build-up.
              • Annoying speaker dependencies deprecated
              • More stable. (I think)
              • Choppy sound issue solved(I think), If you get still this issue, that might be the lack of computing power of your device.
              • NotificationTrigger dependency free. Now you can activate without NotificationTrigger (But If you want, you can still use it.)
              • Making Hook and GAction becomes easier
              • MMM-TelegramBot and other modules supported
              Cr4z33C citizendevpiC 3 Replies Last reply
              • Cr4z33C
                Cr4z33 @Guest
                @sean
                HURRAY! :man_dancing_medium-light_skin_tone:
                Going to implement it right now!
                • Cr4z33C
                  Cr4z33 @Guest
                  @sean hmm it is to my understanding that a device ID is mandatory right?
                  Do you have any idea if the Raspberry Voice HAT can be used with your model?
                  And if yes how can I find out the device id then? :thinking_face:
                    A Former User @Cr4z33
                    @cr4z33
                    Do you mean device ID for audio device?
                    If you have a sound card(HAT) or audio processing integrated into your motherboard, get a list of all the audio devices on your system by executing this command:
                    arecord --list-devices
                    You should get output similar to this:
                    **** List of CAPTURE Hardware Devices ****
                    card 0: IXP [ATI IXP], device 0: ATI IXP AC97 [ATI IXP AC97]
                      Subdevices: 1/1
                      Subdevice #0: subdevice #0
                    In this case, your recording device is hw:0,0.
                    You can test with this.
                    arecord  -D hw:0,0 -d 5 test.wav
                    For output device, similar. use
                    aplay --list-devices
                    Cr4z33C 1 Reply Last reply
                    • Cr4z33C
                      Cr4z33 @Guest
                      @sean
                      Thanks for helping a (Raspberry) noob here hehe.
                      I got a different result:
                      $ arecord --list-devices
                      card 0: sndrpigooglevoi [snd_rpi_googlevoicehat_soundcar], device 0: Google voiceHAT SoundCard HiFi voicehat-hifi-0 []
                        Subdevices: 0/1
                      Therefore would my recording device still be hw:0,0?
                      aplay gave me this:
                      **** List of PLAYBACK Hardware Devices ****
                        Subdevices: 0/1
                      I believe it’s the same ID like above right?
                        @cr4z33 Details are dependent with also your asound config. But,
                        Can you record and play some audio in Terminal?
                        arecord -t 5 test.wav & aplay test.wav
                        Can you execute this? tell me the result.
                        (I haven’t had voiceHAT, so cannot guaranteed, but same name could be available.)
                        • Cr4z33C
                          Cr4z33 @Guest
                          @sean
                          I get an error and please note that I’ve tried to translate to English. :winking_face:
                          [1] 2911
                          arecord: main:574: unrecognized file format 5
                          test.wav: File or directory does not exist
                          [1]+  Output 1                arecord -t 5 test.wav
                            @cr4z33
                            Try this.
                            arecord -t 5 -D hw:0,0 test.wav
                            Does this make test.wav?
                            If so, try this again.
                            aplay -D hw:0,0 test.wav
                            • Cr4z33C
                              Cr4z33 @Guest
                              @sean
                              Nope. :pensive_face:
                              ? 2 Replies Last reply
                                @cr4z33
                                cat ~/.asoundrc
                                Tell me the result.
                                How you can setup previously? (I think you purchased that device for Google AIY project. Was there any instructions?)
                                  @cr4z33
                                  Oops ! my mistake!
                                  arecord -d 5 -D hw:0,0 test.wav
                                  • Cr4z33C
                                    Cr4z33 @Guest
                                    @cr4z33
                                    cat ~/.asoundrc
                                    Tell me the result.
                                    pi@raspberrypi:~ $ cat ~/.asoundrc
                                    cat: /home/pi/.asoundrc: File or directory does not exist
                                    It’s the so- called Google Voice Kit AIY (https://aiyprojects.withgoogle.com/voice-v1/).
                                    I used a ready meal Raspbian image made by Google.
                                    Apart from creating the JSON file everything else consists of ready scripts (i.e assistant_library_demo.py is a script to runs and uses Google Assistant):
                                    https://github.com/google/aiyprojects-raspbian/tree/voicekit
                                      @cr4z33
                                      Hmmm… As I know,
                                      arecord -d 5 test.wav
                                      aplay test.wav
                                      This should work because there is no other suspicious things. your card and device no is 0,0 and that is the default.
                                      Cr4z33C 2 Replies Last reply
                                      • Cr4z33C
                                        Cr4z33 @Guest
                                        @sean
                                        Again I made a noob error… I ran both commands at once lol! :smiling_face_with_open_mouth_cold_sweat:
                                        Running them separately worked like a charm! :thumbs_up_medium-light_skin_tone:
                                        I am going now to retry with the module addition.
                                        • Cr4z33C
                                          Cr4z33 @Guest
                                          @sean
                                          So after following the installation instructions I ran a test by using the ‘Very simple version but limited’ module.
                                          As a result all I get now from MM is a black empty screen (no config.js message and no trace of other modules can be seen).
                                            sgopala @Cr4z33
                                            @cr4z33 There is a small typo in the config file, please correct as under:
                                            Incorrect: [replace this]
                                            play: { // Full values are in FOR EXPERTS section.
                                            playProgram: “mpg321”, // recommended.
                                            Correct: [with this]
                                            • 21
                                            • 22
                                            • 7 / 22
