    MMM-AssistantMk2
    421 Posts 61 Posters 626.1k Views 57 Watching
      A Former User @Stabber
      @stabber
      I think your Google project(project-1019057327317) is not setup completely. There could be many reasons to cause 4XX errors. But I think you missed making consent screen. Go To Google Cloud Platform > YOUR PROJECT > APIs & Services > Credentials > OAuth Consent Screen Tab and put some information.
      I think Application name and Support email are enough. You don’t need to verify, just save it. Then try again.
      • Cr4z33C Offline
        Cr4z33
        Before I am going to try to use these modules can someone please tell me whether they can be used with the Google AIY Voice Kit (v1) or not? :grimacing_face:
        ? citizendevpiC 2 Replies Last reply Reply Quote 0
          A Former User @Cr4z33
          @cr4z33
          If you can record and play your voice with that device, it could be.
          • citizendevpiC Offline
            citizendevpi @Cr4z33
            @cr4z33 I am in the process of setting up now on voice kit v1. did you start yet?
              citizendevpi
              ok so i have installed hotword (working i guess), assistantmk2 i went all the way tru and got a response after typing hello what time is it . and get api interactions in my google cloud. also installed notifaction trigger the mirror starts up and if i say jarvis,smartmirror i get hotword dectected but nothing from assistant im at a loss on how to get it going/response. i will upload my terminal output if i can figure out how if any one can help im pretty sure im missing somthing in my config.EDIT ok i input the test config and BAM it is alive the audio is super crunchy but it could be a hardware issue so any one interested yes i am running pi3b+ with aiy kit v 1 and it works.
                A Former User @citizendevpi
                @citizendevpi @Cr4z33
                Still got problem?
                I’m making whole new update. It will be more stable and easy to install & use. I’ll release this new update in this week. Plz wait a few days.
                citizendevpiC Cr4z33C 2 Replies Last reply Reply Quote 0
                  citizendevpi @Guest
                  @sean no i did some tweeking with mp3 for audio.encoding out and that cleared up the sound issue i do get a frequent js error like every time i use the hotword:Error: open() failed: -1
                  at Speaker._open (/home/pi/MagicMirror/modules/MMM-AssistantMk2/node_modules/speaker/index.js:106:13)
                  at Speaker._write (/home/pi/MagicMirror/modules/MMM-AssistantMk2/node_modules/speaker/index.js:183:23)
                  at doWrite (/home/pi/MagicMirror/modules/MMM-AssistantMk2/node_modules/readable-stream/lib/_stream_writable.js:428:64)
                  at writeOrBuffer (/home/pi/MagicMirror/modules/MMM-AssistantMk2/node_modules/readable-stream/lib/_stream_writable.js:417:5)
                  at Speaker.Writable.write (/home/pi/MagicMirror/modules/MMM-AssistantMk2/node_modules/readable-stream/lib/_stream_writable.js:334:11)
                  at Reader. (/home/pi/MagicMirror/modules/MMM-AssistantMk2/node_helper.js:287:17)
                  at emitNone (events.js:111:20)
                  at Reader.emit (events.js:208:7)
                  at /home/pi/MagicMirror/modules/MMM-AssistantMk2/node_modules/wav/node_modules/readable-stream/lib/_stream_readable.js:934:16
                  at _combinedTickCallback (internal/process/next_tick.js:131:7)
                  Some error happens. Try again.
                    @citizendevpi
                    First, I will abandon this annoying module dependency - Speaker. Sometimes it will not work as my feature. So, currently I’m not making fix about Speaker module. it will be deprecated.
                    Instead using node module, I will use other stable method - your default audio player program. I’m testing now and it will be released soon.
                    citizendevpiC 1 Reply Last reply Reply Quote 0
                      citizendevpi @Guest
                      @sean you are the man !!! thank you for the info and i will be looking forward to the latest release any time you need anything let me know fyi i love ghost in the shell also keep workin.
                      • Cr4z33C Offline
                        Cr4z33 @Guest
                        @sean said in MMM-AssistantMk2 & MMM-GAction:
                        Still got problem?
                        Fortunately I was busy at getting to work two LED strips so OK I will wait with pleasure hehe.
                        Thanks for letting me know. :thumbs_up_medium-light_skin_tone:
                        • 11
                        • 12
                        • 13
                        • 14
                        • 15
                        • 42
                        • 43
                        • 13 / 43
