    MMM-AssistantMk2
    421 Posts 61 Posters 801.4k Views 57 Watching
      A Former User @Stabber
      @stabber
      I think your Google project(project-1019057327317) is not setup completely. There could be many reasons to cause 4XX errors. But I think you missed making consent screen. Go To Google Cloud Platform > YOUR PROJECT > APIs & Services > Credentials > OAuth Consent Screen Tab and put some information.
      I think Application name and Support email are enough. You don’t need to verify, just save it. Then try again.
      • Cr4z33C
        Cr4z33
        Before I am going to try to use these modules can someone please tell me whether they can be used with the Google AIY Voice Kit (v1) or not? :grimacing_face:
        ? citizendevpiC 2 Replies Last reply
          A Former User @Cr4z33
          @cr4z33
          If you can record and play your voice with that device, it could be.
          • citizendevpiC
            citizendevpi @Cr4z33
            @cr4z33 I am in the process of setting up now on voice kit v1. did you start yet?
            • citizendevpiC
              citizendevpi
              ok so i have installed hotword (working i guess), assistantmk2 i went all the way tru and got a response after typing hello what time is it . and get api interactions in my google cloud. also installed notifaction trigger the mirror starts up and if i say jarvis,smartmirror i get hotword dectected but nothing from assistant im at a loss on how to get it going/response. i will upload my terminal output if i can figure out how if any one can help im pretty sure im missing somthing in my config.EDIT ok i input the test config and BAM it is alive the audio is super crunchy but it could be a hardware issue so any one interested yes i am running pi3b+ with aiy kit v 1 and it works.
              ? 1 Reply Last reply
                A Former User @citizendevpi
                @citizendevpi @Cr4z33
                Still got problem?
                I’m making whole new update. It will be more stable and easy to install & use. I’ll release this new update in this week. Plz wait a few days.
                citizendevpiC Cr4z33C 2 Replies Last reply
                • citizendevpiC
                  citizendevpi @Guest
                  @sean no i did some tweeking with mp3 for audio.encoding out and that cleared up the sound issue i do get a frequent js error like every time i use the hotword:Error: open() failed: -1
                  at Speaker._open (/home/pi/MagicMirror/modules/MMM-AssistantMk2/node_modules/speaker/index.js:106:13)
                  at Speaker._write (/home/pi/MagicMirror/modules/MMM-AssistantMk2/node_modules/speaker/index.js:183:23)
                  at doWrite (/home/pi/MagicMirror/modules/MMM-AssistantMk2/node_modules/readable-stream/lib/_stream_writable.js:428:64)
                  at writeOrBuffer (/home/pi/MagicMirror/modules/MMM-AssistantMk2/node_modules/readable-stream/lib/_stream_writable.js:417:5)
                  at Speaker.Writable.write (/home/pi/MagicMirror/modules/MMM-AssistantMk2/node_modules/readable-stream/lib/_stream_writable.js:334:11)
                  at Reader. (/home/pi/MagicMirror/modules/MMM-AssistantMk2/node_helper.js:287:17)
                  at emitNone (events.js:111:20)
                  at Reader.emit (events.js:208:7)
                  at /home/pi/MagicMirror/modules/MMM-AssistantMk2/node_modules/wav/node_modules/readable-stream/lib/_stream_readable.js:934:16
                  at _combinedTickCallback (internal/process/next_tick.js:131:7)
                  Some error happens. Try again.
                    @citizendevpi
                    First, I will abandon this annoying module dependency - Speaker. Sometimes it will not work as my feature. So, currently I’m not making fix about Speaker module. it will be deprecated.
                    Instead using node module, I will use other stable method - your default audio player program. I’m testing now and it will be released soon.
                    citizendevpiC 1 Reply Last reply
                    • citizendevpiC
                      citizendevpi @Guest
                      @sean you are the man !!! thank you for the info and i will be looking forward to the latest release any time you need anything let me know fyi i love ghost in the shell also keep workin.
                      • Cr4z33C
                        Cr4z33 @Guest
                        @sean said in MMM-AssistantMk2 & MMM-GAction:
                        Still got problem?
                        Fortunately I was busy at getting to work two LED strips so OK I will wait with pleasure hehe.
                        Thanks for letting me know. :thumbs_up_medium-light_skin_tone:
                          A Former User
                          UPDATED (2.0.0)
                          • Whole new build-up.
                          • Annoying speaker dependencies deprecated
                          • More stable. (I think)
                          • Choppy sound issue solved(I think), If you get still this issue, that might be the lack of computing power of your device.
                          • NotificationTrigger dependency free. Now you can activate without NotificationTrigger (But If you want, you can still use it.)
                          • Making Hook and GAction becomes easier
                          • MMM-TelegramBot and other modules supported
                          Cr4z33C citizendevpiC 3 Replies Last reply
                          • Cr4z33C
                            Cr4z33 @Guest
                            @sean
                            HURRAY! :man_dancing_medium-light_skin_tone:
                            Going to implement it right now!
                            • Cr4z33C
                              Cr4z33 @Guest
                              @sean hmm it is to my understanding that a device ID is mandatory right?
                              Do you have any idea if the Raspberry Voice HAT can be used with your model?
                              And if yes how can I find out the device id then? :thinking_face:
                                @cr4z33
                                Do you mean device ID for audio device?
                                If you have a sound card(HAT) or audio processing integrated into your motherboard, get a list of all the audio devices on your system by executing this command:
                                arecord --list-devices
                                You should get output similar to this:
                                **** List of CAPTURE Hardware Devices ****
                                card 0: IXP [ATI IXP], device 0: ATI IXP AC97 [ATI IXP AC97]
                                  Subdevices: 1/1
                                  Subdevice #0: subdevice #0
                                In this case, your recording device is hw:0,0.
                                You can test with this.
                                arecord  -D hw:0,0 -d 5 test.wav
                                For output device, similar. use
                                aplay --list-devices
                                Cr4z33C 1 Reply Last reply
                                • Cr4z33C
                                  Cr4z33 @Guest
                                  @sean
                                  Thanks for helping a (Raspberry) noob here hehe.
                                  I got a different result:
                                  $ arecord --list-devices
                                  card 0: sndrpigooglevoi [snd_rpi_googlevoicehat_soundcar], device 0: Google voiceHAT SoundCard HiFi voicehat-hifi-0 []
                                    Subdevices: 0/1
                                  Therefore would my recording device still be hw:0,0?
                                  aplay gave me this:
                                  **** List of PLAYBACK Hardware Devices ****
                                    Subdevices: 0/1
                                  I believe it’s the same ID like above right?
                                    @cr4z33 Details are dependent with also your asound config. But,
                                    Can you record and play some audio in Terminal?
                                    arecord -t 5 test.wav & aplay test.wav
                                    Can you execute this? tell me the result.
                                    (I haven’t had voiceHAT, so cannot guaranteed, but same name could be available.)
                                    • Cr4z33C
                                      Cr4z33 @Guest
                                      @sean
                                      I get an error and please note that I’ve tried to translate to English. :winking_face:
                                      [1] 2911
                                      arecord: main:574: unrecognized file format 5
                                      test.wav: File or directory does not exist
                                      [1]+  Output 1                arecord -t 5 test.wav
                                        @cr4z33
                                        Try this.
                                        arecord -t 5 -D hw:0,0 test.wav
                                        Does this make test.wav?
                                        If so, try this again.
                                        aplay -D hw:0,0 test.wav
                                        • Cr4z33C
                                          Cr4z33 @Guest
                                          @sean
                                          Nope. :pensive_face:
                                          ? 2 Replies Last reply
                                            @cr4z33
                                            cat ~/.asoundrc
                                            Tell me the result.
                                            How you can setup previously? (I think you purchased that device for Google AIY project. Was there any instructions?)
                                            • 21
                                            • 22
                                            • 7 / 22
