    MMM-MirrorMirrorOnTheWall installation issue
    138 Posts 11 Posters 184.4k Views 10 Watching
    • O Offline
      OceanK
      next part, in the alexa skills section where you test the skills you can see logs aswell:
      I can see its triggering the :
      "name": "ShowVideoIntent",
                                  "confirmationStatus": "NONE",
                                  "slots": {
                                      "searchTermVideo": {
                                          "name": "searchTermVideo",
                                          "value": "how to make slime",
      so its looking for the video and then…nothing. check the whole log section for the alexa skill…its ALLOT and maybe you can figure something out from it.
      • richland007R Offline
        richland007
        Yeap exactly like yours …so does that mean that Lambda is not communicating back with Alexa and why not is the million dollar question question??
        Another thing i noticed when you ask for images or display text no errors get recorded on Lambda …does this mean that our Api are missing for searches we have something wrong
        I really don’t know at this point
        • O Offline
          OceanK @richland007
          @richland007 Hey!
          that is exactly what im trying to figure out. For some reason the lamda is not talking to the mirror.
          As you say abt the picture search I have the sam “problem”
          Can you check your iot core(the monitor), on my iot core I can see successful connections.
          So I guess it means that the root.ca is working and talking to the iot core.
            richland007
            Any progress on this at all i have not done anything i was out of town since last Wednesday.
            I don’t know which direction we should look towards … maybe the api keys and requests are the one messing up
            i went back on the google developer console and i see my YouTube api hit a few times and with zero errors i also see the CSE (custom search engine) api hit also but with 100% errors …why ??
            Since it is presenting the data by api numbers that means that the keys are working right but what is the error about??? where do you read more info about that???
            D
              richland007
              Well here it is the 100% Error on CSE is this
              "400 badRequest
              Indicates that the query was invalid. E.g., parent ID was missing or the combination of dimensions or metrics requested was not valid.
              Do not retry without fixing the problem. You need to make changes to the API query in order for it to work."
              How do we fix this??
              • O Offline
                OceanK
                Hey!
                well I havent tryed for a week or so with this project. Im out of ideas for now =(, I can see that the coder has done some minor changes at github but not likley to help us I guess.
                have you seen the new updates at github?
                • O Offline
                  OceanK
                  I did check my CSE and I have actually 8 sucessful picture search…
                  • O Offline
                    OceanK
                    OK si I checked My CSE again after my test yesterday, I can see its hitting my gse everytime I ask for searching of pictures…but the mirror ansers there is a problem…but the statistics showing its working.
                    so the bad link is between the mirror and the lamda funtions. Because the video and picture search are all fine. But all functions like ask to turn all modules off etc is not working at all.
                      richland007
                      Ok so may be it is the Magic Mirrors configuration fault the keys copied to the magic mirror config etc?? maybe we need to redo that one more time
                      have you tried reinstalling (delete completely, download again and reinstall) the MMM- MirrorMirrorOnTheWall part only?? than play around with the key paths and files again etc.
                      Because there is zero communication back with the mirror… all we are doing so far is fine tuning a skill within Alexa…but what worries me the most is why isn’t Alexa showing any videos or images on my Echo Spot …although now that i think about it is that i have not tested it with the Echo Spot since I made the code changes.
                      If you got the MMM module on github the readme file was updated 15 hours ago but i see no other changes since the 3 months ago for mirrormirror.js file
                      anyhow all we got to do is keep trying
                      • O Offline
                        OceanK @richland007
                        @richland007 Hey!
                        I will try to start all over again. See whats happening. I can see there are some new changes in the files from the github. but im not that optimistic.
                        what abt u? have u started from scratch?
                          richland007
                          @OceanK Any news my friend??? I am so upset that we are not progressing with this module…it is exactly what i need and we can not get it to work.
                          I am going to try to mess with it a bit next week and see whats up
                          D
                          • O Offline
                            OceanK @richland007
                            @richland007 hey mate!
                            Well no progress here, I have reached out to the code maker without sucess:(
                            I have tried everything from scratch but no luck. Everything is triggered but not send back to the mirror itself.
                            I dunno where what to do next. Please report back when you have time even if it’s not successful.
                            I guess we are kinda stuck here.
                            richland007R 1 Reply Last reply Reply Quote 0
                              richland007 @OceanK
                              @oceank No news…anything on your part ??? I tried to use another voice module for MM control but that ruins my Alexa installation and it does not work itself after that either so that was no-go.
                              I think we should start reading again that long thread where people said they had gotten it to work and see what else we may find. I think it is only the return part form the Lampda to the mirror that is not working it cant be that complicated probably something simple but what do i know.
                              D
                                richland007
                                @OceanK Yesterday i tried all afternoon to play with this again … i tried to change the keys path on the MirorMirrorOnTheWallSKILL before uploading it to Lambda and nothing changed. Well it gave errors that it was not working so i reverted back to the old working zip file that i had where “everything” was last seem to be fine and another error surfaced but the skill works fine.
                                The error is this
                                2018-11-05T04:11:36.100Z	e2223a43-e0b0-11e8-a28e-557bbecf4c24	The applicationIds don't match: amzn1.ask.skill.[unique-value-here] and amzn1.ask.skill.eXXXXX-dXXX-48bd-9b1c-3d309a950fcf
                                2018-11-05T04:11:36.122Z	e2223a43-e0b0-11e8-a28e-557bbecf4c24
                                    "errorMessage": "Invalid ApplicationId: amzn1.ask.skill.eXXXXXXX-XXX-48bd-9b1c-3d309a950fcf",
                                    "errorType": "Error",
                                    "stackTrace": [
                                        "AlexaRequestEmitter.ValidateRequest (/var/task/node_modules/alexa-sdk/lib/alexa.js:157:27)",
                                        "HandleLambdaEvent.i18n.use.init (/var/task/node_modules/alexa-sdk/lib/alexa.js:123:29)",
                                        "/var/task/node_modules/i18next/dist/commonjs/i18next.js:190:9",
                                        "done (/var/task/node_modules/i18next/dist/commonjs/i18next.js:281:21)",
                                        "/var/task/node_modules/i18next/dist/commonjs/i18next.js:302:7",
                                        "I18n.loadResources (/var/task/node_modules/i18next/dist/commonjs/i18next.js:238:7)",
                                        "I18n.changeLanguage (/var/task/node_modules/i18next/dist/commonjs/i18next.js:301:10)",
                                        "load (/var/task/node_modules/i18next/dist/commonjs/i18next.js:186:14)",
                                        "I18n.init (/var/task/node_modules/i18next/dist/commonjs/i18next.js:195:7)",
                                        "AlexaRequestEmitter.HandleLambdaEvent (/var/task/node_modules/alexa-sdk/lib/alexa.js:114:32)"
                                the xxx are my changes to hide my id.
                                I went and checked my appid and it has not changed and like i said the skill works when you go on the Alexa console and it responds with “Hello my queen…” however i do not see any video or photo requests coming though n the logs on the youtube api etc.
                                Another thing that has changed and i do no know why is the IoT endpoint on IoT Core at the bottom under settings.
                                Can you check yours ne more time please run an error test on lambda and see if you see any changes and check your IoT Core endpoint that we copy paste on index.js file
                                Denis
                                • O Offline
                                  OceanK @richland007
                                  @richland007 Hey!
                                  I will try later tonite! Im going to do this from scratch again. I will report back. I have been on vaccation for coupple of weeks in dubai. But now Im back!
                                  So lets try this again!
                                  • O Offline
                                    OceanK
                                    hey!
                                    its not possible to build the alexa module with the intentmodel.json
                                    The intentmodel.json is depricated, and I cannot build the model =(
                                    what to do now?
                                    • O Offline
                                      OceanK
                                      So im back again!
                                      I started it all from scratch!
                                      still getting this:
                                      “errorMessage”: “In state: . No handler function was defined for event SessionEndedRequest and no ‘Unhandled’ function was defined.”,
                                      “errorType”: “Error”,
                                      “stackTrace”: [
                                      “AlexaRequestEmitter.EmitEvent (/var/task/node_modules/alexa-sdk/lib/alexa.js:212:15)”,
                                      “AlexaRequestEmitter.ValidateRequest (/var/task/node_modules/alexa-sdk/lib/alexa.js:181:23)”,
                                      “HandleLambdaEvent.i18n.use.init (/var/task/node_modules/alexa-sdk/lib/alexa.js:123:29)”,
                                      “/var/task/node_modules/i18next/dist/commonjs/i18next.js:190:9”,
                                      “done (/var/task/node_modules/i18next/dist/commonjs/i18next.js:281:21)”,
                                      “/var/task/node_modules/i18next/dist/commonjs/i18next.js:302:7”,
                                      “I18n.loadResources (/var/task/node_modules/i18next/dist/commonjs/i18next.js:238:7)”,
                                      “I18n.changeLanguage (/var/task/node_modules/i18next/dist/commonjs/i18next.js:301:10)”,
                                      “load (/var/task/node_modules/i18next/dist/commonjs/i18next.js:186:14)”,
                                      “I18n.init (/var/task/node_modules/i18next/dist/commonjs/i18next.js:195:7)”
                                      • O Offline
                                        OceanK
                                        Something is not right with the lamda function.
                                        • O Offline
                                          OceanK
                                          Nothing from your side @richland007 ?
                                            richland007
                                            nothing at all my friend
                                            • 3 / 7
