    MMM-iframe problem plz help me
    5 Posts 2 Posters 1.9k Views 2 Watching
    • W Offline
      wltn
      I’d like to launch the web using myframe, but there’s no response.
      Please help me.This is the code I wrote.
      ~/MagicMirror/modules/default/MMM-iFrame/MMM-iFrame .js
      /* global Module */
      /* Magic Mirror
       * Module: iFrame
       * By Ben Williams http://desertblade.com
       * MIT Licensed.
      Module.register("MMM-iFrame",{
                      // Default module config.
                      defaults: {
                                      height:"100px",
                                      width:"100%",
                                      updateInterval: 0.5 * 60 * 1000,
                                      url: "http://www.naver.com",
                                      scrolling: "no"
              start: function () {
                      self = this;
                      var count = 0;
                      if (this.config.url.length > 0 ) {
                            setInterval( function () {
                               self.updateDom(1000);
                               console.log('update' + count++)
                               }, this.config.updateInterval);
        getRandomInt: function (min, max) {
          return Math.floor(Math.random() * (max - min)) + min;
      resume: function() {
         console.log("Resuming");
         return this.getDom();
              // Override dom generator.
              getDom: function() {
                      var iframe = document.createElement("IFRAME");
                      iframe.style = "border:0"
                      iframe.width = this.config.width;
                      iframe.height = this.config.height;
                      iframe.scrolling = this.config.scrolling;
                      var url_index = 0;
               //       console.log("currentURL:" + this.currentURL);
                      var repeat = true;
                      while(repeat) {
                          url_index = this.getRandomInt(0,this.config.url.length);
                          futureURL = this.config.url[url_index];
                          console.log("URL_length:" + this.config.url.length + " " + "URL_index:" + url_index + " " + "url:" + futureURL);
                 //         if( futureURL == currentURL) {
                              iframe.src = futureURL;
                   //           currentURL = futureURL;
                              repeat = false;
                      return iframe;
      ~/MagicMirror/config/config.js
                              module: "newsfeed",
                              position: "bottom_bar",
                                      feeds: [
                                                      title: "New York Times",
                                      showSourceTitle: true,
                                      showPublishDate: true
                      module: "MMM-iFrame",
                      position: "middle_center",      // This can be any of the regions.
                                      url: "http://www.naver.com",  // as many URLs you want or you can just ["ENTER IN URL"] if single URL.
                                      updateInterval: 0.5 * 60 * 1000, // rotate URLs every 30 seconds
                                      width: "100%", // Optional. Default: 100%
                                      height: "100px" //Optional. Default: 100px
      • W Offline
        wltn
          A Former User @wltn
          @wltn
          Give us the error logs or more detailed symptoms.
          (한국분이신 거 같아 한글로도 남겨요. 정확히 어떤 증상인지 더 자세한 설명이나 에러로그를 남겨주세요.)
          • W Offline
            wltn @Guest
            @sean Thank you!!
            To put a website in the mirror, we put the code below in the module folder and
            we put the code ‘config.js’ in the ‘MMM-iframe’ in it.
            Mirror view will appear normally, but the web site specified in ‘MM-iframe’ will not appear.
            The picture below shows the ‘npm start and stop’ log.
            (아래 사진은 ‘npm start and stop’ 로그입니다.)
              A Former User @wltn
              @wltn
              There are so many iFrame modules. Which one did you use? It seemed this(https://github.com/alberttwong/MMM-iFrame) but your code is not the same with that.
              First, why did you modify the source of MMM-iFrame, especially defaults?
              Second, Since you modified it, the code couldn’t work as its purpose.
              So…
              1. Back to the original source.
              2. Use Configuration like this.
                url: ["http://www.naver.com"],
              (코드 고치셨네요. 오리지널 소스로 돌리시고, config.js에서 윗부분처럼 쓰시기만 하시면 됩니다. 원작자가 배열로 받게 만든 변수를 코드 고치시고 config에서 잘못 지정하시는 바람에 문자열싱글변수가 되어버렸는데 소스 중에 배열처리하는 부분에서 배열이 아니다보니 정상동작을 안하는 듯 하네요.)
