MMM-iframe problem plz help me
5 Posts 2 Posters 1.7k Views 2 Watching
  • W Offline
    wltn
    I’d like to launch the web using myframe, but there’s no response.
    Please help me.This is the code I wrote.
    ~/MagicMirror/modules/default/MMM-iFrame/MMM-iFrame .js
    /* global Module */
    /* Magic Mirror
     * Module: iFrame
     * By Ben Williams http://desertblade.com
     * MIT Licensed.
    Module.register("MMM-iFrame",{
                    // Default module config.
                    defaults: {
                                    height:"100px",
                                    width:"100%",
                                    updateInterval: 0.5 * 60 * 1000,
                                    url: "http://www.naver.com",
                                    scrolling: "no"
            start: function () {
                    self = this;
                    var count = 0;
                    if (this.config.url.length > 0 ) {
                          setInterval( function () {
                             self.updateDom(1000);
                             console.log('update' + count++)
                             }, this.config.updateInterval);
      getRandomInt: function (min, max) {
        return Math.floor(Math.random() * (max - min)) + min;
    resume: function() {
       console.log("Resuming");
       return this.getDom();
            // Override dom generator.
            getDom: function() {
                    var iframe = document.createElement("IFRAME");
                    iframe.style = "border:0"
                    iframe.width = this.config.width;
                    iframe.height = this.config.height;
                    iframe.scrolling = this.config.scrolling;
                    var url_index = 0;
             //       console.log("currentURL:" + this.currentURL);
                    var repeat = true;
                    while(repeat) {
                        url_index = this.getRandomInt(0,this.config.url.length);
                        futureURL = this.config.url[url_index];
                        console.log("URL_length:" + this.config.url.length + " " + "URL_index:" + url_index + " " + "url:" + futureURL);
               //         if( futureURL == currentURL) {
                            iframe.src = futureURL;
                 //           currentURL = futureURL;
                            repeat = false;
                    return iframe;
    ~/MagicMirror/config/config.js
                            module: "newsfeed",
                            position: "bottom_bar",
                                    feeds: [
                                                    title: "New York Times",
                                    showSourceTitle: true,
                                    showPublishDate: true
                    module: "MMM-iFrame",
                    position: "middle_center",      // This can be any of the regions.
                                    url: "http://www.naver.com",  // as many URLs you want or you can just ["ENTER IN URL"] if single URL.
                                    updateInterval: 0.5 * 60 * 1000, // rotate URLs every 30 seconds
                                    width: "100%", // Optional. Default: 100%
                                    height: "100px" //Optional. Default: 100px
    ? 1 Reply Last reply Oct 3, 2018, 11:02 AM Reply Quote 0
    • W Offline
      wltn
        A Former User @wltn
        @wltn
        Give us the error logs or more detailed symptoms.
        (한국분이신 거 같아 한글로도 남겨요. 정확히 어떤 증상인지 더 자세한 설명이나 에러로그를 남겨주세요.)
        W 1 Reply Last reply Oct 4, 2018, 3:39 AM Reply Quote 0
        • W Offline
          wltn @Guest
          @sean Thank you!!
          To put a website in the mirror, we put the code below in the module folder and
          we put the code ‘config.js’ in the ‘MMM-iframe’ in it.
          Mirror view will appear normally, but the web site specified in ‘MM-iframe’ will not appear.
          The picture below shows the ‘npm start and stop’ log.
          (아래 사진은 ‘npm start and stop’ 로그입니다.)
          ? 1 Reply Last reply Oct 4, 2018, 7:09 AM Reply Quote 0
            A Former User @wltn
            @wltn
            There are so many iFrame modules. Which one did you use? It seemed this(https://github.com/alberttwong/MMM-iFrame) but your code is not the same with that.
            First, why did you modify the source of MMM-iFrame, especially defaults?
            Second, Since you modified it, the code couldn’t work as its purpose.
            So…
            1. Back to the original source.
            2. Use Configuration like this.
              url: ["http://www.naver.com"],
            (코드 고치셨네요. 오리지널 소스로 돌리시고, config.js에서 윗부분처럼 쓰시기만 하시면 됩니다. 원작자가 배열로 받게 만든 변수를 코드 고치시고 config에서 잘못 지정하시는 바람에 문자열싱글변수가 되어버렸는데 소스 중에 배열처리하는 부분에서 배열이 아니다보니 정상동작을 안하는 듯 하네요.)
