    Execute script (GPIO Relay) based on if sound is being played
    2 Posts 1 Posters 962 Views 1 Watching
    • Y
      yep_DD
      Hi guys, I want to monitor if audio is being played, e.g:
      cat /proc/asound/card*/pcm*/sub*/status
      And if any status contains running I want to execute a script (in my case turn on the amplifier). I want a simple solution and initially I thought it might be possible with udev or python or bash. Does any of you have a great and easy idea?
      • Y
        yep_DD
        while sleep 1; do
          if grep -q 'RUNNING' '/proc/asound/card0/pcm0p/sub0/status';
          then
            echo "Running!"
          else
            echo "Not Running!"
          fi
        done
        this seems to work but the amplifier produces a too loud cracking sound when switching on, I have two spare relais und my MagicMirror, I will hook up the speakers to those and try again.
