MMM-AssistentMk2 without function
5 Posts 3 Posters 1.3k Views 3 Watching
    seppel1078
    I have installed the above mentioned module and it runs so far on my Magic Mirror. Only when I click the button from the module is a short “Pling” and nothing else happens when I speak into the microphone. Here is the log:
    pi@raspberrypi3:~/MagicMirror $ npm start
    > magicmirror@2.5.0 start /home/pi/MagicMirror
    > sh run-start.sh
    Starting MagicMirror: v2.5.0
    Loading config ...
    Loading module helpers ...
    Module helper loaded: MMM-AssistantMk2
    Module helper loaded: MMM-Hotword
    Module helper loaded: MMM-DWD-WarnWeather
    Module helper loaded: MMM-Admin-Interface
    All module helpers loaded.
    Server started ...
    Connecting socket for: MMM-AssistantMk2
    MMM-AssistantMk2 started
    Connecting socket for: MMM-Hotword
    MMM-Hotword started
    Connecting socket for: MMM-DWD-WarnWeather
    MMM-DWD-WarnWeather helper started...
    Connecting socket for: MMM-Admin-Interface
    Starting node helper for: MMM-Admin-Interface
    Starting module: newsfeed
    { Error: listen EADDRINUSE 127.0.0.1:8080
        at Object._errnoException (util.js:1024:11)
        at _exceptionWithHostPort (util.js:1046:20)
        at Server.setupListenHandle [as _listen2] (net.js:1351:14)
        at listenInCluster (net.js:1392:12)
        at GetAddrInfoReqWrap.doListen [as callback] (net.js:1501:7)
        at GetAddrInfoReqWrap.onlookup [as oncomplete] (dns.js:97:10)
      code: 'EADDRINUSE',
      errno: 'EADDRINUSE',
      syscall: 'listen',
      address: '127.0.0.1',
      port: 8080 }
    Launching application.
    someone an idea what it could be
    Grettings Seppel
    ? 1 Reply Last reply Oct 17, 2018, 6:44 AM Reply Quote 0
    • K Offline
      KingEagle
      Hi Does your RaspiP have internet?
      127.0.0.1 is no interface / IP.
        A Former User @seppel1078
        @seppel1078
        You were running 2 instances of MM at once. I think you didn’t stop MM and execute it again.
        Usually in that case, you might have missed pm2 stop mm.
          seppel1078
          you are right sean. after I stopped Magic Mirror and restarted the error message does not come anymore. I have a new one for that now ;-).
          look here:
          > sh run-start.sh
          Loading config ...
          Server started ...
          MMM-Hotword started
          [HOTWORD] begins listening.
          Create new calendar fetcher for url: https://calendar.google.com/calendar/ical/sf9vk8is4t40pufpociepqmlt8%40group.calendar.google.com/public/basic.ics - Interval: 300000
          Create new news fetcher for url: http://www.tagesschau.de/xml/rss2 - Interval: 300000
          assistant ready
          Conversation Error: { Error: 14 UNAVAILABLE: Service unavailable.
              at Object.exports.createStatusError (/home/pi/MagicMirror/modules/MMM-AssistantMk2/node_modules/grpc/src/common.js:87:15)
              at ClientDuplexStream._emitStatusIfDone (/home/pi/MagicMirror/modules/MMM-AssistantMk2/node_modules/grpc/src/client.js:235:26)
              at ClientDuplexStream._receiveStatus (/home/pi/MagicMirror/modules/MMM-AssistantMk2/node_modules/grpc/src/client.js:213:8)
              at Object.onReceiveStatus (/home/pi/MagicMirror/modules/MMM-AssistantMk2/node_modules/grpc/src/client_interceptors.js:1290:15)
              at InterceptingListener._callNext (/home/pi/MagicMirror/modules/MMM-AssistantMk2/node_modules/grpc/src/client_interceptors.js:564:42)
              at InterceptingListener.onReceiveStatus (/home/pi/MagicMirror/modules/MMM-AssistantMk2/node_modules/grpc/src/client_interceptors.js:614:8)
              at /home/pi/MagicMirror/modules/MMM-AssistantMk2/node_modules/grpc/src/client_interceptors.js:1110:18
            code: 14,
            metadata: Metadata { _internal_repr: {} },
            details: 'Service unavailable.' }
          I use a USB Microphone. Something does not seem to simulate that. I used the standart config
          Greeting Seppel
            seppel1078
            it works now. I changed that in the config under “record”
            Old:
            device        : null        // recording device (e.g.: "plughw:1")
            New:
            device        : "plughw:1"         // recording device (e.g.: "plughw:1")
