    MMM-AssistentMk2 without function
    5 Posts 3 Posters 1.4k Views 3 Watching
      seppel1078
      I have installed the above mentioned module and it runs so far on my Magic Mirror. Only when I click the button from the module is a short “Pling” and nothing else happens when I speak into the microphone. Here is the log:
      pi@raspberrypi3:~/MagicMirror $ npm start
      > magicmirror@2.5.0 start /home/pi/MagicMirror
      > sh run-start.sh
      Starting MagicMirror: v2.5.0
      Loading config ...
      Loading module helpers ...
      Module helper loaded: MMM-AssistantMk2
      Module helper loaded: MMM-Hotword
      Module helper loaded: MMM-DWD-WarnWeather
      Module helper loaded: MMM-Admin-Interface
      All module helpers loaded.
      Server started ...
      Connecting socket for: MMM-AssistantMk2
      MMM-AssistantMk2 started
      Connecting socket for: MMM-Hotword
      MMM-Hotword started
      Connecting socket for: MMM-DWD-WarnWeather
      MMM-DWD-WarnWeather helper started...
      Connecting socket for: MMM-Admin-Interface
      Starting node helper for: MMM-Admin-Interface
      Starting module: newsfeed
      { Error: listen EADDRINUSE 127.0.0.1:8080
          at Object._errnoException (util.js:1024:11)
          at _exceptionWithHostPort (util.js:1046:20)
          at Server.setupListenHandle [as _listen2] (net.js:1351:14)
          at listenInCluster (net.js:1392:12)
          at GetAddrInfoReqWrap.doListen [as callback] (net.js:1501:7)
          at GetAddrInfoReqWrap.onlookup [as oncomplete] (dns.js:97:10)
        code: 'EADDRINUSE',
        errno: 'EADDRINUSE',
        syscall: 'listen',
        address: '127.0.0.1',
        port: 8080 }
      Launching application.
      someone an idea what it could be
      Grettings Seppel
      • K Offline
        KingEagle
        Hi Does your RaspiP have internet?
        127.0.0.1 is no interface / IP.
          A Former User @seppel1078
          @seppel1078
          You were running 2 instances of MM at once. I think you didn’t stop MM and execute it again.
          Usually in that case, you might have missed pm2 stop mm.
            seppel1078
            you are right sean. after I stopped Magic Mirror and restarted the error message does not come anymore. I have a new one for that now ;-).
            look here:
            > sh run-start.sh
            Loading config ...
            Server started ...
            MMM-Hotword started
            [HOTWORD] begins listening.
            Create new calendar fetcher for url: https://calendar.google.com/calendar/ical/sf9vk8is4t40pufpociepqmlt8%40group.calendar.google.com/public/basic.ics - Interval: 300000
            Create new news fetcher for url: http://www.tagesschau.de/xml/rss2 - Interval: 300000
            assistant ready
            Conversation Error: { Error: 14 UNAVAILABLE: Service unavailable.
                at Object.exports.createStatusError (/home/pi/MagicMirror/modules/MMM-AssistantMk2/node_modules/grpc/src/common.js:87:15)
                at ClientDuplexStream._emitStatusIfDone (/home/pi/MagicMirror/modules/MMM-AssistantMk2/node_modules/grpc/src/client.js:235:26)
                at ClientDuplexStream._receiveStatus (/home/pi/MagicMirror/modules/MMM-AssistantMk2/node_modules/grpc/src/client.js:213:8)
                at Object.onReceiveStatus (/home/pi/MagicMirror/modules/MMM-AssistantMk2/node_modules/grpc/src/client_interceptors.js:1290:15)
                at InterceptingListener._callNext (/home/pi/MagicMirror/modules/MMM-AssistantMk2/node_modules/grpc/src/client_interceptors.js:564:42)
                at InterceptingListener.onReceiveStatus (/home/pi/MagicMirror/modules/MMM-AssistantMk2/node_modules/grpc/src/client_interceptors.js:614:8)
                at /home/pi/MagicMirror/modules/MMM-AssistantMk2/node_modules/grpc/src/client_interceptors.js:1110:18
              code: 14,
              metadata: Metadata { _internal_repr: {} },
              details: 'Service unavailable.' }
            I use a USB Microphone. Something does not seem to simulate that. I used the standart config
            Greeting Seppel
              seppel1078
              it works now. I changed that in the config under “record”
              Old:
              device        : null        // recording device (e.g.: "plughw:1")
              New:
              device        : "plughw:1"         // recording device (e.g.: "plughw:1")
