    Fitbit
    129 Posts 42 Posters 226.0k Views 37 Watching
    • K
      kckndrgn @olliewarren411
      @olliewarren411 said in Fitbit:
      Yes, you can change the refresh interval. In the script MMM-fitbit.js you’ll see
      start: function() {
      		Log.info('Starting module: ' + this.name);
      		this.sendSocketNotification('SET CREDS',this.config.credentials)
      		this.sendSocketNotification('GET DATA', 'intial');
      		this.fadeSpeed = 500;
      		// Schedule update interval.
      		var self = this;
      		setInterval(function() {
      			self.updateData();
      		}, 60*60*1000);
      change the 60 x 60 x 1000 to an interval of your choosing. Just be careful to to refresh too often as you’ll get emails from FB telling you that you are pulling too much data. I think (and I’d have to check tonight) that I have mine set to 15 x 60 x 1000.
      O 1 Reply Last reply
      • O
        olliewarren411 @kckndrgn
        @kckndrgn
        Thanks! works perfect. I’ve copied your set up so it refreshes the data every 15 mins.
          plumcraft
          I was getting invalid redirect_uri during the setup process. (sudo python setupAccess.py)
          But now It’s working for me, great module !
          • K
            kckndrgn
            Anyway to get around having to run the setupAccess.py everyday/every other day to keep the tokens fresh?
            Since I have to stop the MM from running, run the script to get new token, start MM again, it gets kind of annoying. I also run my Pi w/o keyboard/mouse so when I need to refresh the tokens I have to connect them.
            I thought about adding a cron job to stop the MM, run the script and start MM, thoughts? Since the script leaves a browser window open, can the cron job kill it or is there a way to have the python script close the window when done?
            TIA
            H 1 Reply Last reply
            • H
              Hellangel1987 @kckndrgn
              @kckndrgn
              dont know exactly but im also interested in your cronjob solution, can you inform us about your steps ? im tired getting every day that setupaccess working :(
              K 1 Reply Last reply
              • K
                kckndrgn @Hellangel1987
                @Hellangel1987 said in Fitbit:
                @kckndrgn
                I haven’t done it, yet, just thinking about it since it was mentioned. I think I’ve narrowed down the issue though:
                {"message": {"401": {"errors": [{"message": "Access token expired: eyJhbGciOiJIUzI1NiJ9.eyJzdWIiOiI0NU5QMzUiLCJhdWQiOiIyMjdRVjkiLCJpc3MiOiJGaXRiaXQiLCJ0eXAiOiJhY2Nlc3NfdG9rZW4iLCJzY29wZXMiOiJ3aHIgd3BybyB3bnV0IHdzbGUgd3dlaSB3c29jIHdhY3Qgd3NldCB3bG9jIiwiZXhwIjoxNDcxNzAxNjYzLCJpYXQiOjE0NzE2NzI4NjN9.VvLWtyYYvVShgrWC4UOVMXfdv0uiy7Nic-WDj7RMiKA. Visit https://dev.fitbit.com/docs/oauth2 for more information on the Fitbit Web API authorization process.", "errorType": "expired_token"}], "success": false}}, "type": "error"}
                {"message": "Getting a new access token", "type": "status"}
                {"message": "Error getting new access token", "type": "error"}
                {"message": {"400": {"errors": [{"message": "Refresh token invalid: 4292cf037821b9441122e432bdd92a238fac61028dfbd6be982d2e6b73474c32. Visit https://dev.fitbit.com/docs/oauth2 for more information on the Fitbit Web API authorization process.", "errorType": "invalid_grant"}], "success": false}}, "type": "error"}
                First got an “expired” token notice, then the process tries to get a new token (possibly using the “refresh” token, I’m not sure at this point). But refresh tokens are valid for one use only, so it’s like the updated token is getting updated in the token.ini file.
                  plumcraft
                  Also interested with the cron mechanism, the module could execute the setupAccess process once a day and trigger a reload on the gui ?
                  I’m using vnc to connect remotely on the RPI since i don’t have mouse/keyboards connected.
                  • K
                    kckndrgn
                    3 days of syncing without an issue. Not sure what changed, I did pull the latest dev code for MM but made no changes to the fitbit module.
                    (of course now that I’ve said this, it will error out during the day :) )
                    • K
                      kckndrgn
                      Had my first issues in a while last night. The problem was that my router lost internet connection and when it was restored the tokens were expired. I ran the setupAccess.py and got new tokens.
                      Seems that there should be a better way to reset the module on restart, like if the tokens are expired, the go get new ones.
                      • VendittelliV
                        Vendittelli Module Developer
                        The python that accesses the fitbit API is currently having that functionality added, I’m doing some work at the moment to help with install issues and once the work on python-fitbit is complete I’ll update again.
                          chengstark
                          results: [{"message":"Writing credentials to credentials.ini","type":"status"},{"message":"Writing id: 227Z5P and secret: 55b8d28e28533664a52c6ec6a25b51f0","type":"status"},{"message":"Credentials write successful","type":"status"}]
                          nop
                          { Error: process exited with code 1
                              at terminateIfNeeded (/home/pi/MagicMirror/modules/node_modules/python-shell/index.js:100:23)
                              at ChildProcess.<anonymous> (/home/pi/MagicMirror/modules/node_modules/python-shell/index.js:88:9)
                              at emitTwo (events.js:106:13)
                              at ChildProcess.emit (events.js:191:7)
                              at Process.ChildProcess._handle.onexit (internal/child_process.js:215:12)
                            executable: 'python',
                            options: null,
                            script: 'modules/MMM-fitbit/python/getData.py',
                            args: null,
                            exitCode: 1 }
                          i noticed that my mirror stopped getting data updates. it works yesterday but not today, can you help me identify where went wrong?
                          • K
                            kckndrgn @chengstark
                            @chengstark,
                            Possibly the internet connection was lost during a refresh, this will cause the tokens to get out of date.
                            I stop MM, re-run the “setupAccess.py” script using credentials from the file, then re-start MM and all is fine, until the next time I have an internet hiccup.
                            C 1 Reply Last reply
                              chengstark @kckndrgn
                              @kckndrgn thanks, will try
                              • VendittelliV
                                I have released a fix for the .ini files problem in the latest version on GitHub. You’ll need to delete your tokens.ini and credentials.ini files and remake them (as well as performing a git pull) for the fix to be effective.
                                  darrene
                                  For some reason, I’m getting calories displayed, but nothing else. @Vendittelli, does the module have any additional debugging or logging that I can turn on to look through? - I’m not getting any issues in dev mode or in the terminal - it seems that’s the only data I get. When I look in the dev console, I see:
                                  writing steps (data/goal): 0/10000
                                  Writing floors (data/goal): 0/10
                                  writing calories out (data/goal): 1664/2930
                                  writing distance (data/goal) 0/5
                                  writing activeminutes (data/goal): 0/30
                                  writing sleep (data/goal): 0/480
                                  When I clear down my tokens.ini and re-run the setupaccess.py, I can see the scope information for the token results includes u’social’, u’settings’, u’profile’, u’sleep’, u’activity’, u’heartrate’, u’weight’, u’nutrition’, u’location’
                                  if that’s helpful…
                                  As a slight aside: @olliewarren411, would you mind sharing your ‘vertical-layout’ css? I’m still trying to get my head around cascading style sheets!
                                  VendittelliV 1 Reply Last reply
                                  • VendittelliV
                                    Vendittelli Module Developer @darrene
                                    @darrene That is weird. The module is pretty unadvanced so I don’t have proper debugging, unfortunately. The scope looks correct, are you sure you have synced your Fitbit today? It would explain why calories are displayed as they are calculated automatically so you don’t need to sync them.
                                    D 1 Reply Last reply
                                      darrene @Vendittelli
                                      Thanks for the quick reply @Vendittelli - that could be the answer. I didn’r realise the calories were calculated like that - as you say, it’d certainly explain it.
                                      I’ll have a look into it. If it comes to it, I’ll recreate the app - I seem to remember there are a list of tick boxes for the fitibit attributes and on the pi browser, it was really difficult to tell whether or not they were ticked!
                                        moshinh
                                        I am having the same issue Greppie had at some point.
                                        Next thing is, that setupAccess.py doesnt work or I did not understood how it does. The script start a server at port 8080 but if fitbit redirects to it I get an error that the page is not accessible. However I copied the token from url an put it into tokens.ini. There’s only an access token and no refresh token, right?
                                        I am having this same problem, I get a 404 error on the attempt to get my tokens. I was able to pull the token from the URL, but have no way to get the refresh. Please help, im so close! Thanks for all of your effort.
                                        When I click the autogenerated authorization URL, I am redirected to http://127.0.0.1:8080/ and throw this 404 error.
                                        404 Not Found
                                        Missing parameters: state
                                        File “/usr/local/lib/python2.7/dist-packages/cherrypy/_cprequest.py”, line 670, in respond
                                        response.body = self.handler()
                                        File “/usr/local/lib/python2.7/dist-packages/cherrypy/lib/encoding.py”, line 217, in call
                                        self.body = self.oldhandler
                                        (*args, **kwargs)
                                        File “/usr/local/lib/python2.7/dist-packages/cherrypy/_cpdispatch.py”, line 67, in call
                                        raise sys.exc_info()[1]
                                        HTTPError: (404, ‘Missing parameters: state’)
                                        This is what I see when I run setupAccess.py
                                        Is this part normal?
                                        CherryPy Checker:
                                        The Application mounted at ‘’ has an empty config.
                                        Full output:
                                        pi@mirror:~/MagicMirror/modules/MMM-fitbit/python $ sudo python setupAccess.py
                                        Get credentials from credentials.ini? (Y/N)
                                        n
                                        Would you like to enter them manually now? (Y/N)
                                        y
                                        Enter client id:
                                        227WT7
                                        Enter client secret:
                                        9fe3da42b609603a67e7730aad3ca96a
                                        [25/Oct/2016:11:20:26] ENGINE Listening for SIGHUP.
                                        [25/Oct/2016:11:20:26] ENGINE Listening for SIGTERM.
                                        [25/Oct/2016:11:20:26] ENGINE Listening for SIGUSR1.
                                        [25/Oct/2016:11:20:26] ENGINE Bus STARTING
                                        CherryPy Checker:
                                        [25/Oct/2016:11:20:26] ENGINE Started monitor thread ‘Autoreloader’.
                                        [25/Oct/2016:11:20:26] ENGINE Started monitor thread ‘_TimeoutMonitor’.
                                        [25/Oct/2016:11:20:27] ENGINE Serving on http://127.0.0.1:8080
                                        [25/Oct/2016:11:20:27] ENGINE Bus STARTED
                                        127.0.0.1 - - [25/Oct/2016:11:20:40] “GET / HTTP/1.1” 404 1206 “” “Mozilla/5.0 (X11; Linux armv7l) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/51.0.2704.91 Safari/537.36”
                                        T 1 Reply Last reply
                                        • F
                                          frog
                                          I have the same issue but I think the problem is earlier in the install
                                          Well I’m having an even earlier problem in installing the dependencies:
                                          pi@Mirror1:~/MagicMirror/modules/MMM-fitbit $ npm install python-shell
                                          returns:
                                          └── python-shell@0.4.0
                                          npm WARN enoent ENOENT: no such file or directory, open '/home/pi/MagicMirror/modules/package.json'
                                          npm WARN enoent ENOENT: no such file or directory, open '/home/pi/MagicMirror/modules/node_modules/node_helper/package.json'
                                          npm WARN modules No description
                                          npm WARN modules No repository field.
                                          npm WARN modules No README data
                                          npm WARN modules No license field.
                                          The python-shell is clearly not installing.
                                          A 1 Reply Last reply
                                          • T
                                            tismepaulo @moshinh
                                            I’m also having the same issues as @moshinh and @frog during installation. Has anyone been able to get this working?
                                            F O 2 Replies Last reply
                                            • 3 / 7
