    script or bash to exit MM and exit GUI and run a command in TTY mode
    4 Posts 2 Posters 2.3k Views 4 Watching
      AxLed Module Developer
      Hi to all,
      i am trying to extend my MM for a second purpose -> Retropie.
      Therefore i need a script or bash or any way to do the following:
      • exit MM (maybe exiting PM2 is also fine)
      • exit the Raspian / Pixel GUI (as retropie dont run in GUI Mode)
      • run the “emulationstation” command in the TTY terminal
      Does anybody has hints for me to do that. For the beginning i would be also ok to run a script manual by entering the commands in terminal.
      Thanks in advance.
      AxLED
        Hi to all interested,
        i testet some hours and made little progress.
        There are following requirements:
        Tools:
        • pm2
        • xdotool
        Starting MagicMirror from Retropie works somehow, see the following lines:
        • add a MagicMirror.sh file in the fork folder of retropie with the following code
        #!/bin/bash
            echo "starting MagicMirror"
            sudo service lightdm start #to start GUI
            #pm2 stop emulationstation, final commands missing so far
            pm2 start mm #to start MagicMirror
            xdotool key Ctrl+Alt+F7 #to change to tty7 = Gui
        • make this file executable
        Starting Retropie from MagicMirror works somehow, see the following lines:
        • editing file /opt/retropie/supplementary/runcommand/runcommand.sh, change links from tty to tty1. Make sure owner and group ist root after editing
        • add a es.sh file in a folder of your choice with the following code
        #!/bin/bash
        echo 'starting Emulationstation/Retropie'
        sudo service lightdm stop #to quit GUI
        export DISPLAY=:0
        emulationstation > /dev/tty1 #to execute this command in tty1 where emulationstation/retropie runs
        • put this file into pm2
        Difficulties:
        I dont know how to put two .sh files into pm2 and set one to “start” and one to “stop”, if i only would have one of the to .sh files executed at one time (one .sh is for MagicMirror, second .sh is for emulationstation/retropie)
        AxLED
          Ramez
          put the first one in /home/pi/retropie/roms/ports and you can run it under ports section in ES
          the closing script is a bit tricky you can use MM module that excute a terminal command to exit like this one MMM-TouchButtons and config it like that
            text: 'Exit MM',
            icon: 'skull',
            action: 'exec',
            command: 'killall lightdm'
          it should kicks you back to ES
            @Ramez
            Thanks for your reply, i want to have only one app (either mm or Retropie/Emulationstation) run at one time due the pi ressources.
            But i will try your approach.
            AxLED
