    MagicMirror crashed due to "gnutls_handshake() failed: Error in the push function"
    2 Posts 1 Posters 1.2k Views 1 Watching
    • evroomE
      evroom
      This morning my MM showed a black screen and the pm2 log says following:
      /home/pi/.pm2/logs/MagicMirror-error.log last 15 lines:
      0|MagicMir | fatal: unable to access 'https://github.com/fewieden/MMM-soccer.git/': gnutls_handshake() failed: Error in the push function.
      0|MagicMir |
      0|MagicMir | fatal: unable to access 'https://github.com/raywo/MMM-PublicTransportHafas.git/': gnutls_handshake() failed: Error in the push function.
      0|MagicMir |
      0|MagicMir | fatal: unable to access 'https://github.com/shbatm/MMM-RTSPStream.git/': gnutls_handshake() failed: Error in the push function.
      0|MagicMir |
      0|MagicMir | fatal: unable to access 'https://github.com/fmandal/MMM-YrThen/': gnutls_handshake() failed: Error in the push function.
      0|MagicMir |
      0|MagicMir | fatal: unable to access 'https://github.com/MichMich/MagicMirror.git/': gnutls_handshake() failed: Error in the push function.
      0|MagicMir |
      I did a search in the forum, but I could not find any other occurrences.
      Will search the web now to see if I can find something more on this topic.
      In the meantime any clue as to what happened is welcome.
      MagicMirror version: 2.37.0
      • evroomE
        evroom
        Btw, a simple restart of MagicMirror solved the issue and my MM is working again.
        Web search tells me that:
        gnutls_handshake(): This function performs the handshake of the TLS/SSL protocol, and initializes the TLS session parameters.
        Looks to be related with git, as all calls were done to github.com.
