    Problem with the Module "email"
    57 Posts 4 Posters 35.9k Views 4 Watching
      sdetweil @CyruS1337
      @cyrus1337 I don’t know anything about this module, but I would guess that your email config is wrong.
      The error means the module failed parsing the email data, because there was a connection or permissions error (tls implies ssl connection problem)
      • CyruS1337C Offline
        CyruS1337 Project Sponsor
        I have the config as described on the page https://github.com/ronny3050/email-mirror
        		        module: 'email',
                        position: 'top_left',
                        header: 'Email',
                            accounts: [
                                    user: 'name@gmail.com',
                                    password: 'pw',
                                    host: 'imap.gmail.com',
        			    port: 993,
                                    tls: true,
                                    authTimeout: 10000,
                                    numberOfEmails: 5,
                            fade: true,
                            maxCharacters: 30
          sdetweil @CyruS1337
          @cyrus1337 and password: ‘pw’ where pw is YOUR EMAIL password, right?
          And name@gmail.com is YOUR Gmail username
            @sdetweil said in Problem with the Module "email":
            Genau, das ist das Passwort für den Emailaccount.
            Bei user habe ich meine Emailadresse angegeben.
            • cirdanC Offline
              cirdan
              Did you set google security lower than the default. Something with allow third party apps?
              Modules MMM-rainfc, MMM-bustimes, MMM-Harmony, MMM-Rijks
                @cirdan said in Problem with the Module "email":
                Yey, i have set
                cirdanC 1 Reply Last reply Reply Quote 0
                • cirdanC Offline
                  cirdan @CyruS1337
                  @cyrus1337 its an authentication problem. My best guess is an error in typing your userid or password. You can try it with username, without the @gmail.com part
                  CyruS1337C 1 Reply Last reply Reply Quote 0
                    CyruS1337 Project Sponsor @cirdan
                    @cirdan Ok, you mean I should just enter the name: Adriano B …
                    • cirdanC Offline
                      cirdan @CyruS1337
                      @cyrus1337 what I mean is e.g. your email is namexxx@gmail.com that you use namexxx as an username in the config. I remember playing with that when getting to module to work
                        @cirdan I did that. My username in config is adriano.b .....@gmail.com or am I mistaken you?
                        		        module: 'email',
                                        header: 'Email',
                                            accounts: [
                                                    user: '...@gmail.com',
                                                    password: '...',
                        			    port: 993,
                                                    tls: true,
                                                    authTimeout: 10000,
                                                    numberOfEmails: 5,
                                            fade: true,
                                            maxCharacters: 30
                          usually when we show our config.js with personal stuff removed, we use … or xxx instead of the default ‘name’ and ‘pw’.
                          this lets others looking at your issue know you have changed the content
                            CyruS1337 Project Sponsor @sdetweil
                            ok, i changed it. Thanks for the information
                              sdetweil @CyruS1337
                              @cyrus1337 thank you…
                                But I have not come further. Is there something wrong with my config?
                                  sdetweil @CyruS1337
                                  @cyrus1337 ok, I cut/pasted your config, changed to my userid and password…
                                  failed… module imap not found…
                                  had to run npm install from the modules/email folder…
                                  restart mirror…
                                  note: this only shows NEWLY arriving email… i don’t know how the mail drops off, as it hasn’t updated for me… 5 emails shown…
                                    @sdetweil I did that you’ve got. Unfortunately without success
                                    pi@raspberrypi2:~ $ cd MagicMirror
                                    pi@raspberrypi2:~/MagicMirror $ cd modules
                                    pi@raspberrypi2:~/MagicMirror/modules $ cd email
                                    pi@raspberrypi2:~/MagicMirror/modules/email $ npm install
                                    npm WARN email@0.0.1 No repository field.
                                    npm WARN email@0.0.1 No license field.
                                    audited 24 packages in 4.491s
                                    found 0 vulnerabilities
                                    pi@raspberrypi2:~/MagicMirror/modules/email $ sudo reboot
                                    login as: pi
                                    pi@192.168.1.102's password:
                                    Linux raspberrypi2 4.14.67-v7+ #1139 SMP Wed Aug 29 15:17:05 BST 2018 armv7l
                                    The programs included with the Debian GNU/Linux system are free software;
                                    the exact distribution terms for each program are described in the
                                    individual files in /usr/share/doc/*/copyright.
                                    Debian GNU/Linux comes with ABSOLUTELY NO WARRANTY, to the extent
                                    permitted by applicable law.
                                    Last login: Thu Nov  8 20:03:08 2018 from 192.168.1.134
                                    pi@raspberrypi2:~ $
                                      sdetweil @CyruS1337
                                      @cyrus1337 ok , open a command prompt so we can look at the error output…
                                      then cd MagaicMirror and type
                                      npm start
                                      i see stuff like this
                                      > magicmirror@2.5.0 start /home/odroid/Magi
                                      > sh run-start.sh
                                      Starting MagicMirror: v2.5.0
                                      Loading config ...
                                      Loading module helpers ...
                                      handler helper in init
                                      Module helper loaded: MMM-SleepWake
                                      Module helper loaded: MMM-ImagesPhotos
                                      Module helper loaded: MMM-BMW-DS
                                      All module helpers loaded.
                                      Starting server on port 8086 ...
                                      You're using a full whitelist configuration
                                      Server started ...
                                      Starting module: newsfeed
                                      Connecting socket for: MMM-SleepWake
                                      handler helper in start
                                      Connecting socket for: MMM-ImagesPhotos
                                      Starting node helper for: MMM-ImagesPhotos
                                      Connecting socket for: MMM-BMW-DS
                                      Starting node_helper for: MMM-BMW-DS
                                      Launching application.
                                        @sdetweil Thanks for the help, I will post my log tonight
                                          I also see things like you. Here are my logs:
                                          pi@raspberrypi2:~/MagicMirror $ npm start
                                          > magicmirror@2.5.0 start /home/pi/MagicMirror
                                          > sh run-start.sh
                                          Loading config ...
                                          Module helper loaded: MMM-SystemStats
                                          Module helper loaded: MMM-MyCommute
                                          Module helper loaded: MMM-GoogleMapsTraffic
                                          No helper found for module: MMM-PIR-Sensor.
                                          Module helper loaded: MMM-SoccerLiveScore
                                          Module helper loaded: MMM-MyCalendar
                                          Module helper loaded: email
                                          Server started ...
                                          Connecting socket for: MMM-SystemStats
                                          Connecting socket for: MMM-MyCommute
                                          ====================== Starting node_helper for module [MMM-MyCommute]
                                          Connecting socket for: MMM-GoogleMapsTraffic
                                          Starting node_helper for module: MMM-GoogleMapsTraffic
                                          Connecting socket for: MMM-SoccerLiveScore
                                          MMM-SoccerLiveScore helper started...
                                          Connecting socket for: MMM-MyCalendar
                                          Starting node helper for: MMM-MyCalendar
                                          Connecting socket for: email
                                          email helper started ...
                                          Create new news fetcher for url: https://api.20min.ch/rss/view/1 - Interval: 300000
                                          Create new news fetcher for url: https://api.20min.ch/rss/view/67 - Interval: 300000
                                          Working notification system. Notification: MMM-GOOGLE_MAPS_TRAFFIC-GET payload:  { style: 'standard' }
                                          Create new calendar fetcher for url: https://calendar.google.com/calendar/ical/zeptrion%40gmail.com/private-75149d8982f910a209e0fe7d0363d75f/basic.ics - Interval: 300000
                                          listening for emails...
                                          • cirdanC Offline
                                            cirdan
                                            Looks good. What happens when you send a new mail to the emailaddress when the logs shows listening for email?
