    Problem with the Module "email"
    57 Posts 4 Posters 36.3k Views 4 Watching
    • CyruS1337C Offline
      CyruS1337 Project Sponsor
      @sdetweil said in Problem with the Module "email":
      @cyrus1337 and password: ‘pw’ where pw is YOUR EMAIL password, right?
      And name@gmail.com is YOUR Gmail username
      Genau, das ist das Passwort für den Emailaccount.
      Bei user habe ich meine Emailadresse angegeben.
      • cirdanC Offline
        cirdan
        Did you set google security lower than the default. Something with allow third party apps?
        Modules MMM-rainfc, MMM-bustimes, MMM-Harmony, MMM-Rijks
          @cirdan said in Problem with the Module "email":
          Yey, i have set
          cirdanC 1 Reply Last reply Reply Quote 0
          • cirdanC Offline
            cirdan @CyruS1337
            @cyrus1337 its an authentication problem. My best guess is an error in typing your userid or password. You can try it with username, without the @gmail.com part
            CyruS1337C 1 Reply Last reply Reply Quote 0
              CyruS1337 Project Sponsor @cirdan
              @cirdan Ok, you mean I should just enter the name: Adriano B …
              • cirdanC Offline
                cirdan @CyruS1337
                @cyrus1337 what I mean is e.g. your email is namexxx@gmail.com that you use namexxx as an username in the config. I remember playing with that when getting to module to work
                  @cirdan I did that. My username in config is adriano.b .....@gmail.com or am I mistaken you?
                  		        module: 'email',
                                  position: 'top_left',
                                  header: 'Email',
                                      accounts: [
                                              user: '...@gmail.com',
                                              password: '...',
                                              host: 'imap.gmail.com',
                  			    port: 993,
                                              tls: true,
                                              authTimeout: 10000,
                                              numberOfEmails: 5,
                                      fade: true,
                                      maxCharacters: 30
                    usually when we show our config.js with personal stuff removed, we use … or xxx instead of the default ‘name’ and ‘pw’.
                    this lets others looking at your issue know you have changed the content
                      CyruS1337 Project Sponsor @sdetweil
                      ok, i changed it. Thanks for the information
                        sdetweil @CyruS1337
                        @cyrus1337 thank you…
                          But I have not come further. Is there something wrong with my config?
                            sdetweil @CyruS1337
                            @cyrus1337 ok, I cut/pasted your config, changed to my userid and password…
                            failed… module imap not found…
                            had to run npm install from the modules/email folder…
                            restart mirror…
                            note: this only shows NEWLY arriving email… i don’t know how the mail drops off, as it hasn’t updated for me… 5 emails shown…
                              @sdetweil I did that you’ve got. Unfortunately without success
                              pi@raspberrypi2:~ $ cd MagicMirror
                              pi@raspberrypi2:~/MagicMirror $ cd modules
                              pi@raspberrypi2:~/MagicMirror/modules $ cd email
                              pi@raspberrypi2:~/MagicMirror/modules/email $ npm install
                              npm WARN email@0.0.1 No repository field.
                              npm WARN email@0.0.1 No license field.
                              audited 24 packages in 4.491s
                              found 0 vulnerabilities
                              pi@raspberrypi2:~/MagicMirror/modules/email $ sudo reboot
                              login as: pi
                              pi@192.168.1.102's password:
                              Linux raspberrypi2 4.14.67-v7+ #1139 SMP Wed Aug 29 15:17:05 BST 2018 armv7l
                              The programs included with the Debian GNU/Linux system are free software;
                              the exact distribution terms for each program are described in the
                              individual files in /usr/share/doc/*/copyright.
                              Debian GNU/Linux comes with ABSOLUTELY NO WARRANTY, to the extent
                              permitted by applicable law.
                              Last login: Thu Nov  8 20:03:08 2018 from 192.168.1.134
                              pi@raspberrypi2:~ $
                                sdetweil @CyruS1337
                                @cyrus1337 ok , open a command prompt so we can look at the error output…
                                then cd MagaicMirror and type
                                npm start
                                i see stuff like this
                                > magicmirror@2.5.0 start /home/odroid/Magi
                                > sh run-start.sh
                                Starting MagicMirror: v2.5.0
                                Loading config ...
                                Loading module helpers ...
                                handler helper in init
                                Module helper loaded: MMM-SleepWake
                                Module helper loaded: MMM-ImagesPhotos
                                Module helper loaded: MMM-BMW-DS
                                All module helpers loaded.
                                Starting server on port 8086 ...
                                You're using a full whitelist configuration
                                Server started ...
                                Starting module: newsfeed
                                Connecting socket for: MMM-SleepWake
                                handler helper in start
                                Connecting socket for: MMM-ImagesPhotos
                                Starting node helper for: MMM-ImagesPhotos
                                Connecting socket for: MMM-BMW-DS
                                Starting node_helper for: MMM-BMW-DS
                                Launching application.
                                  @sdetweil Thanks for the help, I will post my log tonight
                                    I also see things like you. Here are my logs:
                                    pi@raspberrypi2:~/MagicMirror $ npm start
                                    > magicmirror@2.5.0 start /home/pi/MagicMirror
                                    > sh run-start.sh
                                    Loading config ...
                                    Module helper loaded: MMM-SystemStats
                                    Module helper loaded: MMM-MyCommute
                                    Module helper loaded: MMM-GoogleMapsTraffic
                                    No helper found for module: MMM-PIR-Sensor.
                                    Module helper loaded: MMM-SoccerLiveScore
                                    Module helper loaded: MMM-MyCalendar
                                    Module helper loaded: email
                                    Server started ...
                                    Connecting socket for: MMM-SystemStats
                                    Connecting socket for: MMM-MyCommute
                                    ====================== Starting node_helper for module [MMM-MyCommute]
                                    Connecting socket for: MMM-GoogleMapsTraffic
                                    Starting node_helper for module: MMM-GoogleMapsTraffic
                                    Connecting socket for: MMM-SoccerLiveScore
                                    MMM-SoccerLiveScore helper started...
                                    Connecting socket for: MMM-MyCalendar
                                    Starting node helper for: MMM-MyCalendar
                                    Connecting socket for: email
                                    email helper started ...
                                    Create new news fetcher for url: https://api.20min.ch/rss/view/1 - Interval: 300000
                                    Create new news fetcher for url: https://api.20min.ch/rss/view/67 - Interval: 300000
                                    Working notification system. Notification: MMM-GOOGLE_MAPS_TRAFFIC-GET payload:  { style: 'standard' }
                                    Create new calendar fetcher for url: https://calendar.google.com/calendar/ical/zeptrion%40gmail.com/private-75149d8982f910a209e0fe7d0363d75f/basic.ics - Interval: 300000
                                    listening for emails...
                                    • cirdanC Offline
                                      cirdan
                                      Looks good. What happens when you send a new mail to the emailaddress when the logs shows listening for email?
                                        I could try that :) Also, I have 1 unread email in the folder. But I’m trying to send an email to myself tonight and see what happens.
                                        I’ll call you tonight
                                          I sent you an email earlier. Unfortunately, the module still does not show an email and it still says “load”
                                            I deleted the folder “email” again and then reinstalled the module. I do not know what the warnings after npm install mean:
                                            pi@raspberrypi2:~ $ cd MagicMirror/modules
                                            pi@raspberrypi2:~/MagicMirror/modules $ git clone https://github.com/ronny3050/e        mail-mirror.git email
                                            Klone nach 'email' ...
                                            remote: Enumerating objects: 60, done.
                                            remote: Total 60 (delta 0), reused 0 (delta 0), pack-reused 60
                                            Entpacke Objekte: 100% (60/60), Fertig.
                                            npm WARN deprecated mailparser@0.6.2: Mailparser versions older than v2.3.0 are        deprecated
                                            npm WARN deprecated mimelib@0.3.1: This project is unmaintained
                                            npm notice created a lockfile as package-lock.json. You should commit this file.
                                            added 21 packages from 18 contributors and audited 24 packages in 9.564s
