    Problem with the Module "email"
    57 Posts 4 Posters 36.3k Views 4 Watching
    • CyruS1337C Offline
      CyruS1337 Project Sponsor
      I have the config as described on the page https://github.com/ronny3050/email-mirror
      		        module: 'email',
                      position: 'top_left',
                      header: 'Email',
                          accounts: [
                                  user: 'name@gmail.com',
                                  password: 'pw',
                                  host: 'imap.gmail.com',
      			    port: 993,
                                  tls: true,
                                  authTimeout: 10000,
                                  numberOfEmails: 5,
                          fade: true,
                          maxCharacters: 30
        sdetweil @CyruS1337
        @cyrus1337 and password: ‘pw’ where pw is YOUR EMAIL password, right?
        And name@gmail.com is YOUR Gmail username
          @sdetweil said in Problem with the Module "email":
          Genau, das ist das Passwort für den Emailaccount.
          Bei user habe ich meine Emailadresse angegeben.
          • cirdanC Offline
            cirdan
            Did you set google security lower than the default. Something with allow third party apps?
            Modules MMM-rainfc, MMM-bustimes, MMM-Harmony, MMM-Rijks
              @cirdan said in Problem with the Module "email":
              Yey, i have set
              cirdanC 1 Reply Last reply Reply Quote 0
              • cirdanC Offline
                cirdan @CyruS1337
                @cyrus1337 its an authentication problem. My best guess is an error in typing your userid or password. You can try it with username, without the @gmail.com part
                CyruS1337C 1 Reply Last reply Reply Quote 0
                  CyruS1337 Project Sponsor @cirdan
                  @cirdan Ok, you mean I should just enter the name: Adriano B …
                  • cirdanC Offline
                    cirdan @CyruS1337
                    @cyrus1337 what I mean is e.g. your email is namexxx@gmail.com that you use namexxx as an username in the config. I remember playing with that when getting to module to work
                      @cirdan I did that. My username in config is adriano.b .....@gmail.com or am I mistaken you?
                      		        module: 'email',
                                      header: 'Email',
                                          accounts: [
                                                  user: '...@gmail.com',
                                                  password: '...',
                      			    port: 993,
                                                  tls: true,
                                                  authTimeout: 10000,
                                                  numberOfEmails: 5,
                                          fade: true,
                                          maxCharacters: 30
                        usually when we show our config.js with personal stuff removed, we use … or xxx instead of the default ‘name’ and ‘pw’.
                        this lets others looking at your issue know you have changed the content
                          CyruS1337 Project Sponsor @sdetweil
                          ok, i changed it. Thanks for the information
                            sdetweil @CyruS1337
                            @cyrus1337 thank you…
                              But I have not come further. Is there something wrong with my config?
                                sdetweil @CyruS1337
                                @cyrus1337 ok, I cut/pasted your config, changed to my userid and password…
                                failed… module imap not found…
                                had to run npm install from the modules/email folder…
                                restart mirror…
                                note: this only shows NEWLY arriving email… i don’t know how the mail drops off, as it hasn’t updated for me… 5 emails shown…
                                  @sdetweil I did that you’ve got. Unfortunately without success
                                  pi@raspberrypi2:~ $ cd MagicMirror
                                  pi@raspberrypi2:~/MagicMirror $ cd modules
                                  pi@raspberrypi2:~/MagicMirror/modules $ cd email
                                  pi@raspberrypi2:~/MagicMirror/modules/email $ npm install
                                  npm WARN email@0.0.1 No repository field.
                                  npm WARN email@0.0.1 No license field.
                                  audited 24 packages in 4.491s
                                  found 0 vulnerabilities
                                  pi@raspberrypi2:~/MagicMirror/modules/email $ sudo reboot
                                  login as: pi
                                  pi@192.168.1.102's password:
                                  Linux raspberrypi2 4.14.67-v7+ #1139 SMP Wed Aug 29 15:17:05 BST 2018 armv7l
                                  The programs included with the Debian GNU/Linux system are free software;
                                  the exact distribution terms for each program are described in the
                                  individual files in /usr/share/doc/*/copyright.
                                  Debian GNU/Linux comes with ABSOLUTELY NO WARRANTY, to the extent
                                  permitted by applicable law.
                                  Last login: Thu Nov  8 20:03:08 2018 from 192.168.1.134
                                  pi@raspberrypi2:~ $
                                    sdetweil @CyruS1337
                                    @cyrus1337 ok , open a command prompt so we can look at the error output…
                                    then cd MagaicMirror and type
                                    npm start
                                    i see stuff like this
                                    > magicmirror@2.5.0 start /home/odroid/Magi
                                    > sh run-start.sh
                                    Starting MagicMirror: v2.5.0
                                    Loading config ...
                                    Loading module helpers ...
                                    handler helper in init
                                    Module helper loaded: MMM-SleepWake
                                    Module helper loaded: MMM-ImagesPhotos
                                    Module helper loaded: MMM-BMW-DS
                                    All module helpers loaded.
                                    Starting server on port 8086 ...
                                    You're using a full whitelist configuration
                                    Server started ...
                                    Starting module: newsfeed
                                    Connecting socket for: MMM-SleepWake
                                    handler helper in start
                                    Connecting socket for: MMM-ImagesPhotos
                                    Starting node helper for: MMM-ImagesPhotos
                                    Connecting socket for: MMM-BMW-DS
                                    Starting node_helper for: MMM-BMW-DS
                                    Launching application.
                                      @sdetweil Thanks for the help, I will post my log tonight
                                        I also see things like you. Here are my logs:
                                        pi@raspberrypi2:~/MagicMirror $ npm start
                                        > magicmirror@2.5.0 start /home/pi/MagicMirror
                                        > sh run-start.sh
                                        Loading config ...
                                        Module helper loaded: MMM-SystemStats
                                        Module helper loaded: MMM-MyCommute
                                        Module helper loaded: MMM-GoogleMapsTraffic
                                        No helper found for module: MMM-PIR-Sensor.
                                        Module helper loaded: MMM-SoccerLiveScore
                                        Module helper loaded: MMM-MyCalendar
                                        Module helper loaded: email
                                        Server started ...
                                        Connecting socket for: MMM-SystemStats
                                        Connecting socket for: MMM-MyCommute
                                        ====================== Starting node_helper for module [MMM-MyCommute]
                                        Connecting socket for: MMM-GoogleMapsTraffic
                                        Starting node_helper for module: MMM-GoogleMapsTraffic
                                        Connecting socket for: MMM-SoccerLiveScore
                                        MMM-SoccerLiveScore helper started...
                                        Connecting socket for: MMM-MyCalendar
                                        Starting node helper for: MMM-MyCalendar
                                        Connecting socket for: email
                                        email helper started ...
                                        Create new news fetcher for url: https://api.20min.ch/rss/view/1 - Interval: 300000
                                        Create new news fetcher for url: https://api.20min.ch/rss/view/67 - Interval: 300000
                                        Working notification system. Notification: MMM-GOOGLE_MAPS_TRAFFIC-GET payload:  { style: 'standard' }
                                        Create new calendar fetcher for url: https://calendar.google.com/calendar/ical/zeptrion%40gmail.com/private-75149d8982f910a209e0fe7d0363d75f/basic.ics - Interval: 300000
                                        listening for emails...
                                        • cirdanC Offline
                                          cirdan
                                          Looks good. What happens when you send a new mail to the emailaddress when the logs shows listening for email?
                                            I could try that :) Also, I have 1 unread email in the folder. But I’m trying to send an email to myself tonight and see what happens.
                                            I’ll call you tonight
