    Default Calender relative removes start time
    14 Posts 3 Posters 6.4k Views 3 Watching
      cptkex @lavolp3
      @lavolp3 thanks for that suggestion, ill try that tonight when i get home!
      I will have to check when i get home, i was moving between the three options of absolute, relative and dateheader and i dont really remember if it gave me the date when i switched back to absolute.
      ill doublecheck tonight, because i was trying to achieve my wish of having the start time to be absolute by changing the startdate variable to MMM Do HH:mm. ill get back to you on this. Again, sorry, kind of new at this.
      • lavolp3L Offline
        lavolp3 Module Developer @cptkex
        @cptkex
        Aha! The “dateheaders” option is quite new and I haven’t seen that before. Will check that out as well
          cptkex @lavolp3
          @lavolp3 I’m home and I was mistaken. It does not show the date when it goes into relative, only the end time. I will try your code later tonight and see if it works.
            cptkex @lavolp3
            @lavolp3 i tried your addition to the code but it only said
            meeting in 5 hoursInvalid Date-1800
            lavolp3L 2 Replies Last reply Reply Quote 0
            • lavolp3L Offline
              • lavolp3L Offline
                @cptkex There is an open issue that might describe the same issue:
                https://github.com/MichMich/MagicMirror/issues/1457
                Yours?
                Else it might be worth following.
                  cptkex @lavolp3
                  @lavolp3 not mine, but thanks, i will keep an eye on it
                  • lavolp3L Offline
                    @cptkex
                    You could try this
                    timeWrapper.innerHTML = this.capFirst(moment(event.startDate, "x").fromNow()) + this.capFirst(moment(event.startDate, "x").format(this.config.dateEndFormat));
                    I took the dirty way to use the dateEndFormat variable for a starting time.
                    This is just a guess! I haven’t tried it out yet…
                    • BKeyportB Offline
                      BKeyport Module Developer
                      because of the ending times, I went 100% absolute. works best on a small screen, too…
                      dateFormat: “M/D h:mm a”,
                      fullDateEventDateFormat: “M/D”,
                      timeFormat: “absolute”,
                      getRelative: 0,
                      urgency: 0,
                      dateEndFormat: “h:mm a”,
                      • lavolp3L Offline
                        lavolp3 Module Developer @BKeyport
                        @bkeyport that’s what I would recommend otherwise as well.
                        I’m using the same config with the timeFormat: ‘dateheaders’ but for some reason I’m missing the ending times…
