    MMM-CalendarExt weeks time on events
    8 Posts 2 Posters 2.7k Views 2 Watching
      cptkex @Guest
      @sean hi! Thanks for replying.
      That’s what I’ve added, but there isn’t any time visible on any entry. Are the multiple entries like that or just the one? Can I have changed the wrong one that is
      weeks: {
                      showWeeks: 1,
                      position: 'middle_center',
              //      onlyStartingTime: 1,
                      weeksTitle: 'Vecka',
                      weeksFormat: 'wo',
                      weekdayFormat: 'dd',
                      titleFormat : 'MMM D',
                      overTitleFormat : 'MMM D',
                      counts: 2,
              defaultCalendar: {
                maxEntries:50,
                maxDays:180,
                interval: 1000*60*5,
      and custom.css
      .CALEXT .tableStyle .eventLocation
      .CALEXT .tableStyle .eventTime {
          display:block
        cptkex @cptkex
        @cptkex i have been spending the morning changing values and i dont feel that any change in the custom.rss affects any part of the calendar, can i have added something that would stop it from working? the css that is
          A Former User @cptkex
          @cptkex
          Maybe it’s my mistakes. But at this moment I’m out so cannot give you detail.
          First check ‘custom.css’ is /home/pi/MagicMirror/css/custom.css, not /home/pi/MagicMirror/modules/MMM-CalendarExt/cusom.css.
          I made this module when I was a newb of MM, so at that time the convention of naming was wrong. It might cause your confusing.
          If you still get problem, I’ll reply you on Monday after arriving home.
          C 2 Replies Last reply Reply Quote 0
            cptkex @Guest
            @sean wait so it’s not the one in the calendarext directory it’s the general one in the Css directory? That might very well explain why nothing I do works :)
            I have just finished the process of deleting the module and the code in config.js, to make sure I hadn’t screwed up any code. I will reinstall it, and then change the correct Css one and report back. Thanks for taking the time.
              cptkex @Guest
              @sean editing that into the right Css made all the difference :) thank you for your help! now the next step is to figure out how to add the date inside the icon…
                @cptkex said in MMM-CalendarExt weeks time on events:
                I didn’t make this module for that purpose, So I can think it is not so easy.
                Because all my slot has already it’s period title, thus I think that feature is needless in my module. So I didn’t prepare it.
