Unsolved Problem with the Module "email"
I sent you an email earlier. Unfortunately, the module still does not show an email and it still says “load”
157/5000
I deleted the folder “email” again and then reinstalled the module. I do not know what the warnings afternpm install
mean:pi@raspberrypi2:~ $ cd MagicMirror/modules pi@raspberrypi2:~/MagicMirror/modules $ git clone https://github.com/ronny3050/e mail-mirror.git email Klone nach 'email' ... remote: Enumerating objects: 60, done. remote: Total 60 (delta 0), reused 0 (delta 0), pack-reused 60 Entpacke Objekte: 100% (60/60), Fertig. pi@raspberrypi2:~/MagicMirror/modules $ cd email pi@raspberrypi2:~/MagicMirror/modules/email $ npm install npm WARN deprecated mailparser@0.6.2: Mailparser versions older than v2.3.0 are deprecated npm WARN deprecated mimelib@0.3.1: This project is unmaintained npm notice created a lockfile as package-lock.json. You should commit this file. npm WARN email@0.0.1 No repository field. npm WARN email@0.0.1 No license field. added 21 packages from 18 contributors and audited 24 packages in 9.564s found 0 vulnerabilities
@cyrus1337 the warnings mean nothing for users.
This module will ONLY show email that arrives AFTER it is started.
@sdetweil said in Problem with the Module "email":
ok, all right :) but I am not yet. The module will simply not load an email
@cyrus1337 I had to reboot to get it to work.
I just did
sudo reboot
unfortunately without success -
Does it show the module on screen?
@cirdan said in Problem with the Module "email":
oes
Yes, the title stands and under the title is “load”
Just did a fresh install. Git clone and npm install like you did. Added example config to config.js. Deleted one of the preset accounts and changed the google one into my email. Typed password
I had to change fade from true to false to get the module to show emails
Make sure there are new mails in the mailbox
Check your passwordFor every new email a line NEW EMAIL is printed in the console
Also when new mail arives, in the console of the webbrowser the payload can be found. When in magic mirror full screen mode, type ctrl shift i. Wait a few seconds. In the console log on the right you should a log containing " new payload array ()." Click on array opens the received emails
@cirdan Unfortunately, the module still does not work for me. Have it disabled mitlerweile again.
