    Problem with the Module "email"
    57 Posts 4 Posters 36.3k Views 4 Watching
    • CyruS1337C Offline
      CyruS1337 Project Sponsor
      I also see things like you. Here are my logs:
      pi@raspberrypi2:~ $ cd MagicMirror
      pi@raspberrypi2:~/MagicMirror $ npm start
      > magicmirror@2.5.0 start /home/pi/MagicMirror
      > sh run-start.sh
      Starting MagicMirror: v2.5.0
      Loading config ...
      Loading module helpers ...
      Module helper loaded: MMM-SystemStats
      Module helper loaded: MMM-MyCommute
      Module helper loaded: MMM-GoogleMapsTraffic
      No helper found for module: MMM-PIR-Sensor.
      Module helper loaded: MMM-SoccerLiveScore
      Module helper loaded: MMM-MyCalendar
      Module helper loaded: email
      All module helpers loaded.
      Server started ...
      Connecting socket for: MMM-SystemStats
      Connecting socket for: MMM-MyCommute
      ====================== Starting node_helper for module [MMM-MyCommute]
      Starting module: newsfeed
      Connecting socket for: MMM-GoogleMapsTraffic
      Starting node_helper for module: MMM-GoogleMapsTraffic
      Connecting socket for: MMM-SoccerLiveScore
      MMM-SoccerLiveScore helper started...
      Connecting socket for: MMM-MyCalendar
      Starting node helper for: MMM-MyCalendar
      Connecting socket for: email
      email helper started ...
      Launching application.
      Create new news fetcher for url: https://api.20min.ch/rss/view/1 - Interval: 300000
      Create new news fetcher for url: https://api.20min.ch/rss/view/67 - Interval: 300000
      Working notification system. Notification: MMM-GOOGLE_MAPS_TRAFFIC-GET payload:  { style: 'standard' }
      Create new calendar fetcher for url: https://calendar.google.com/calendar/ical/zeptrion%40gmail.com/private-75149d8982f910a209e0fe7d0363d75f/basic.ics - Interval: 300000
      listening for emails...
      • cirdanC Offline
        cirdan
        Looks good. What happens when you send a new mail to the emailaddress when the logs shows listening for email?
        Modules MMM-rainfc, MMM-bustimes, MMM-Harmony, MMM-Rijks
          @cirdan said in Problem with the Module "email":
          I could try that :) Also, I have 1 unread email in the folder. But I’m trying to send an email to myself tonight and see what happens.
          I’ll call you tonight
            I sent you an email earlier. Unfortunately, the module still does not show an email and it still says “load”
              I deleted the folder “email” again and then reinstalled the module. I do not know what the warnings after npm install mean:
              pi@raspberrypi2:~ $ cd MagicMirror/modules
              pi@raspberrypi2:~/MagicMirror/modules $ git clone https://github.com/ronny3050/e        mail-mirror.git email
              Klone nach 'email' ...
              remote: Enumerating objects: 60, done.
              remote: Total 60 (delta 0), reused 0 (delta 0), pack-reused 60
              Entpacke Objekte: 100% (60/60), Fertig.
              pi@raspberrypi2:~/MagicMirror/modules $ cd email
              pi@raspberrypi2:~/MagicMirror/modules/email $ npm install
              npm WARN deprecated mailparser@0.6.2: Mailparser versions older than v2.3.0 are        deprecated
              npm WARN deprecated mimelib@0.3.1: This project is unmaintained
              npm notice created a lockfile as package-lock.json. You should commit this file.
              npm WARN email@0.0.1 No repository field.
              npm WARN email@0.0.1 No license field.
              added 21 packages from 18 contributors and audited 24 packages in 9.564s
              found 0 vulnerabilities
                sdetweil @CyruS1337
                @cyrus1337 the warnings mean nothing for users.
                This module will ONLY show email that arrives AFTER it is started.
                CyruS1337C 1 Reply Last reply Reply Quote 0
                  CyruS1337 Project Sponsor @sdetweil
                  @sdetweil said in Problem with the Module "email":
                  ok, all right :) but I am not yet. The module will simply not load an email
                    sdetweil @CyruS1337
                    @cyrus1337 I had to reboot to get it to work.
                      I just did sudo reboot unfortunately without success
                      • cirdanC Offline
                        cirdan
                        Does it show the module on screen?
                          CyruS1337 Project Sponsor @cirdan
                          oes
                          Yes, the title stands and under the title is “load”
                          • cirdanC Offline
                            cirdan
                            Just did a fresh install. Git clone and npm install like you did. Added example config to config.js. Deleted one of the preset accounts and changed the google one into my email. Typed password
                            I had to change fade from true to false to get the module to show emails
                            Make sure there are new mails in the mailbox
                            Check your password
                            For every new email a line NEW EMAIL is printed in the console
                            Also when new mail arives, in the console of the webbrowser the payload can be found. When in magic mirror full screen mode, type ctrl shift i. Wait a few seconds. In the console log on the right you should a log containing " new payload array ()." Click on array opens the received emails
                              @cirdan Unfortunately, the module still does not work for me. Have it disabled mitlerweile again.
                              • mumblebajM Offline
                                mumblebaj Module Developer @CyruS1337
                                @CyruS1337 With gmail you have to create an application key on gmail itself. Your email account password would not work.
                                  CyruS1337 Project Sponsor @mumblebaj
                                  @mumblebaj said in Problem with the Module "email":
                                  And how do I create an application key myself? :-/
                                    @CyruS1337 In gmail, you need to select the Google Apps menu: 0_1567611843267_e4890805-370c-4dac-b435-300a7a0fdb2c-image.png
                                    Next click on Account. On the left hand side click on Security.
                                    On the right Select App Passwords and create a password for your app. Copy that key into your mirror where you need to enter the password and that should work.
                                      Hello
                                      Sorry if I ask again, but unfortunately I can not find it. So I go like this -> Account -> Security and then I do not find what you mean.
                                        @CyruS1337 No problem:
                                        When loggin into gmail, on the right hand side there is the “hamburger menu”:
                                        When you click that you get a list of apps, select Account from there. On the left click security:
                                        On the right you will see Signing into Google. Click on the “>” on the line “App Passwords”
                                        On the next screen enter your password and then on the next screen you will be able to create the key.
                                          i don’t see that on my console… I see
                                          password
                                          use your phone
                                          2-step verification
                                            @sdetweil Strange. I had to generate a key to get email to work. Not sure why you guys don’t see the option.
                                            Edit:
                                            Maybe because your 2FA is turned off.
                                            • 2 / 3
