    Problem with the Module "email"
    57 Posts 4 Posters 37.4k Views 4 Watching
      sdetweil @CyruS1337
      @cyrus1337 ok , open a command prompt so we can look at the error output…
      then cd MagaicMirror and type
      npm start
      i see stuff like this
      > magicmirror@2.5.0 start /home/odroid/Magi
      > sh run-start.sh
      Starting MagicMirror: v2.5.0
      Loading config ...
      Loading module helpers ...
      handler helper in init
      Module helper loaded: MMM-SleepWake
      Module helper loaded: MMM-ImagesPhotos
      Module helper loaded: MMM-BMW-DS
      All module helpers loaded.
      Starting server on port 8086 ...
      You're using a full whitelist configuration
      Server started ...
      Starting module: newsfeed
      Connecting socket for: MMM-SleepWake
      handler helper in start
      Connecting socket for: MMM-ImagesPhotos
      Starting node helper for: MMM-ImagesPhotos
      Connecting socket for: MMM-BMW-DS
      Starting node_helper for: MMM-BMW-DS
      Launching application.
      CyruS1337C 1 Reply Last reply Reply Quote 0
      • CyruS1337C Offline
        CyruS1337 Project Sponsor @sdetweil
        @sdetweil Thanks for the help, I will post my log tonight
          I also see things like you. Here are my logs:
          pi@raspberrypi2:~ $ cd MagicMirror
          pi@raspberrypi2:~/MagicMirror $ npm start
          > magicmirror@2.5.0 start /home/pi/MagicMirror
          > sh run-start.sh
          Loading config ...
          Module helper loaded: MMM-SystemStats
          Module helper loaded: MMM-MyCommute
          Module helper loaded: MMM-GoogleMapsTraffic
          No helper found for module: MMM-PIR-Sensor.
          Module helper loaded: MMM-SoccerLiveScore
          Module helper loaded: MMM-MyCalendar
          Module helper loaded: email
          Server started ...
          Connecting socket for: MMM-SystemStats
          Connecting socket for: MMM-MyCommute
          ====================== Starting node_helper for module [MMM-MyCommute]
          Connecting socket for: MMM-GoogleMapsTraffic
          Starting node_helper for module: MMM-GoogleMapsTraffic
          Connecting socket for: MMM-SoccerLiveScore
          MMM-SoccerLiveScore helper started...
          Connecting socket for: MMM-MyCalendar
          Starting node helper for: MMM-MyCalendar
          Connecting socket for: email
          email helper started ...
          Create new news fetcher for url: https://api.20min.ch/rss/view/1 - Interval: 300000
          Create new news fetcher for url: https://api.20min.ch/rss/view/67 - Interval: 300000
          Working notification system. Notification: MMM-GOOGLE_MAPS_TRAFFIC-GET payload:  { style: 'standard' }
          Create new calendar fetcher for url: https://calendar.google.com/calendar/ical/zeptrion%40gmail.com/private-75149d8982f910a209e0fe7d0363d75f/basic.ics - Interval: 300000
          listening for emails...
          • cirdanC Offline
            cirdan
            Looks good. What happens when you send a new mail to the emailaddress when the logs shows listening for email?
            Modules MMM-rainfc, MMM-bustimes, MMM-Harmony, MMM-Rijks
              @cirdan said in Problem with the Module "email":
              I could try that :) Also, I have 1 unread email in the folder. But I’m trying to send an email to myself tonight and see what happens.
              I’ll call you tonight
                I sent you an email earlier. Unfortunately, the module still does not show an email and it still says “load”
                  I deleted the folder “email” again and then reinstalled the module. I do not know what the warnings after npm install mean:
                  pi@raspberrypi2:~ $ cd MagicMirror/modules
                  pi@raspberrypi2:~/MagicMirror/modules $ git clone https://github.com/ronny3050/e        mail-mirror.git email
                  Klone nach 'email' ...
                  remote: Enumerating objects: 60, done.
                  remote: Total 60 (delta 0), reused 0 (delta 0), pack-reused 60
                  Entpacke Objekte: 100% (60/60), Fertig.
                  pi@raspberrypi2:~/MagicMirror/modules $ cd email
                  pi@raspberrypi2:~/MagicMirror/modules/email $ npm install
                  npm WARN deprecated mailparser@0.6.2: Mailparser versions older than v2.3.0 are        deprecated
                  npm WARN deprecated mimelib@0.3.1: This project is unmaintained
                  npm notice created a lockfile as package-lock.json. You should commit this file.
                  npm WARN email@0.0.1 No repository field.
                  npm WARN email@0.0.1 No license field.
                  added 21 packages from 18 contributors and audited 24 packages in 9.564s
                  found 0 vulnerabilities
                    sdetweil @CyruS1337
                    @cyrus1337 the warnings mean nothing for users.
                    This module will ONLY show email that arrives AFTER it is started.
                      @sdetweil said in Problem with the Module "email":
                      ok, all right :) but I am not yet. The module will simply not load an email
                        sdetweil @CyruS1337
                        @cyrus1337 I had to reboot to get it to work.
                          I just did sudo reboot unfortunately without success
                          • cirdanC Offline
                            cirdan
                            Does it show the module on screen?
                              CyruS1337 Project Sponsor @cirdan
                              oes
                              Yes, the title stands and under the title is “load”
                              • cirdanC Offline
                                cirdan
                                Just did a fresh install. Git clone and npm install like you did. Added example config to config.js. Deleted one of the preset accounts and changed the google one into my email. Typed password
                                I had to change fade from true to false to get the module to show emails
                                Make sure there are new mails in the mailbox
                                Check your password
                                For every new email a line NEW EMAIL is printed in the console
                                Also when new mail arives, in the console of the webbrowser the payload can be found. When in magic mirror full screen mode, type ctrl shift i. Wait a few seconds. In the console log on the right you should a log containing " new payload array ()." Click on array opens the received emails
                                  @cirdan Unfortunately, the module still does not work for me. Have it disabled mitlerweile again.
                                  • mumblebajM Offline
                                    mumblebaj Module Developer @CyruS1337
                                    @CyruS1337 With gmail you have to create an application key on gmail itself. Your email account password would not work.
                                      CyruS1337 Project Sponsor @mumblebaj
                                      @mumblebaj said in Problem with the Module "email":
                                      And how do I create an application key myself? :-/
                                        @CyruS1337 In gmail, you need to select the Google Apps menu: 0_1567611843267_e4890805-370c-4dac-b435-300a7a0fdb2c-image.png
                                        Next click on Account. On the left hand side click on Security.
                                        On the right Select App Passwords and create a password for your app. Copy that key into your mirror where you need to enter the password and that should work.
                                          Hello
                                          Sorry if I ask again, but unfortunately I can not find it. So I go like this -> Account -> Security and then I do not find what you mean.
                                            @CyruS1337 No problem:
                                            When loggin into gmail, on the right hand side there is the “hamburger menu”:
                                            When you click that you get a list of apps, select Account from there. On the left click security:
                                            On the right you will see Signing into Google. Click on the “>” on the line “App Passwords”
                                            On the next screen enter your password and then on the next screen you will be able to create the key.
                                            • 2 / 3
