    MMM-BackgroundSlideshow
    23 Posts 5 Posters 15.0k Views 5 Watching
    • CyruS1337C Offline
      CyruS1337 Project Sponsor
      I have a question about the background photos. I’ve found that the images are larger when viewed on the raspberry than when I look at them on the PC.
      I am using the MMM BackgroundSlideshow module to display a new image every 10 seconds.
      In custom.css I have the following codes deposited:
       * Magic Mirror                                      *
       * Custom CSS                                        *
       * By Michael Teeuw http://michaelteeuw.nl           *
       * MIT Licensed.                                     *
       * Add any custom CSS below.                         *
       * Changes to this files will be ignored by GIT. *
      .MMM-SystemStats  {
              color: #CEF6CE;
      .normal,
      .dimmed,
      header,
      .MMM-BackgroundSlideshow  {
          color: #fff;
      .MMM-EasyPix  {
              font-weight: 400;
      .MMM-SystemStats {
          font-size: 45%;
      .MMM-darksky-hourly {
      	color: #ffffff;
      Can someone tell me why the PI are “bigger” than when I look at them on the PC
      That’s still my config
      /* Magic Mirror Config Sample
       * MIT Licensed.
      var config = {
      	address: "0.0.0.0", // Address to listen on, can be:
      	port: 8080,
      	language: "de",
      	timeFormat: 24,
      	units: "metric",
      			module: "alert",
      			module: "updatenotification",
      			position: "top_bar"
      			module: "clock",
      			position: "top_left"
      			module: "compliments",
      			position: "lower_third"
      	disabled: false,
          module: "MMM-NewsFeedTicker",
      	position: "bottom_bar",
      	//classes: "day_scheduler",
      	    feeds: [
      			title: "20 min",
      			url: "https://api.20min.ch/rss/view/67",
      			encoding: "UTF-8", //ISO-8859-1
      			className: "myClass",
      			defaultLogo : ""
      	 module: 'internet-monitor',
      	 position: 'top_center',
      		 type: 'minimal',
      		 maxTime: 7000,
      		 updateInterval: 120000,
      		 verbose: false,
      		 displayStrength: true,
      		 displaySpeed: false,
      		 strengthIconSize: 40,
      		 maxGaugeScale: 25,
      		 wifiSymbol:{
      			 fullColor: '#3afc25',
      			 almostColor: '#ffff0c',
      			 halfColor: '#ff8c00',
      			 noneColor: '#ff1111'
          module: 'MMM-darksky-hourly',
          position: 'top_right',  // This can be any of the regions.
            apiKey: 'xxx', // Dark Sky API key.
            latitude:   47.309714,
            longitude: 7.8106514,
      		module: 'MMM-SystemStats',
      		position: 'bottom_left', // This can be any of the regions.
      		classes: 'small dimmed', // Add your own styling. Optional.// classes: 'small dimmed',
      		// header: 'System Stats', // Set the header text OPTIONAL
      			updateInterval: 10000, // every 10 seconds
      			align: 'right', // align labels
      			view: 'textAndIcon',
          module: "MMM-EasyPix",
      	header: "WLAN-Code",
      	position: "bottom_right",
      		picName: "guest_wifi_config.png", // Enter the picture file name.
      		maxWidth: "100%",        // Size picture precisely. Retains aspect ratio.
          module: 'MMM-BackgroundSlideshow',
          position: 'fullscreen_below',
            imagePaths: ['modules/MMM-BackgroundSlideshow/Amerika_2018'],
            transitionImages: true,
            randomizeImageOrder: true
        //disabled:true,
        module: "MMM-AVStock",
        position: "top_right", //"bottom_bar" is better for `mode:ticker`
          apiKey : "WPYPLO6M92PTF7PB", // https://www.alphavantage.co/
          timeFormat: "YYYY-MM-DD HH:mm:ss",
          symbols : ["aapl", "GOOGL", "005930.KS", "SCHN.SW", "UBS", "NOVN.VX",],
          alias: ["Apple", "Google", "SAMSUNG Electronics", "Schindler", "UBS", "Novartis",], //Easy name of each symbol. When you use `alias`, the number of symbols and alias should be the same. If value is null or "", symbol string will be used by default.
          tickerDuration: 60, // Ticker will be cycled once per this second.
          chartDays: 90, //For `mode:series`, how much daily data will be taken. (max. 90)
          poolInterval : 1000*15, // If your AV account is free, at least 13 sec is needed.
          mode : "table", // "table", "ticker", "series"
      			module: "newsfeed",
      				feeds: [
      						title: "New York Times",
      				showSourceTitle: true,
      				showPublishDate: true
        Ok, thanks for your help. I downloaded the program PhotoScape and changed the height and width of all photos. Look, there you go !! Thank you
          Enclosed I send you the two different views. Once on the PI and once on the PC monitor.
          Bild Text
          Bild Text
            [[global:former-user]] @CyruS1337
            @cyrus1337
            I’m not sure, I don’t know anything about backgroundSlideShow, but,
            Your pictures would be greater than resolution of screen.
            Then, your PC viewer might have resized your pictures automatically when they were shown. But backgroundSlideShow might not have that feature. However, there is a possibility of controlling by CSS. Ask to creator.
            CyruS1337C 1 Reply Last reply Reply Quote 0
              CyruS1337 Project Sponsor @Guest
              @sean Thanks for your quick reply.
              garblefluxG 1 Reply Last reply Reply Quote 0
              • garblefluxG Offline
                garbleflux Project Sponsor @CyruS1337
                @cyrus1337 said in MMM-BackgroundSlideshow:
                I also use this module very successfully. Try to resize the pictures to the resolution of your screen (photoshop), normaly 1920 x 1080, 1024 x 760. Sometimes it is also necessary to set the pictures to the correct aspect ratio 16:9. For me it works fine.
                Regards Mike
                  sdetweil @garbleflux
                  @garbleflux i had to modify another image display module to get the correct presentation of images, no zoom in and no crop of portrait mode. does mean that some of the background shows thru, but the pictures are correctly displayed
                  CyruS1337C 1 Reply Last reply Reply Quote -1
                    CyruS1337 Project Sponsor @sdetweil
                    @sdetweil And what would be your module :)
                      sdetweil @CyruS1337
                      @cyrus1337 I am using the MMM-ImagePhotos module… but I had to change the code to keep my images properly formatted…
                      landscape
                      https://www.dropbox.com/s/adzzi3bc7wwq8q5/IMG_20181114_102356.jpg?dl=0
                      portrait
                      https://www.dropbox.com/s/htxdm7b8sayqazh/IMG_20181114_102350.jpg?dl=0
                      can’t get the pics to actually display here…
                        I made several modules handling photos - MMM-GooglePhotos, MMM-WeatherBackground, MMM-DropboxWallpaper,…
                        All modules can display photos by its aspect-ratio with covering the target area or resizing to show whole picture.
                        Try them.
                        • MMM-DropboxWallpaper (https://github.com/eouia/MMM-DropboxWallpaper)
                        • MMM-GooglePhotos (https://github.com/eouia/MMM-GooglePhotos)
                        S CyruS1337C 2 Replies Last reply Reply Quote 0
                          Anyway, If your module would be using img tag for showing photos, module should know the exact image size and calculate to resize it by proper target ratio.
                          Instead, I prefer using Background CSS trick. background-size:cover will cover whole image to entire area of it’s element, background-size:contain will resize image to fit to target element size. Suprisingly, without any calculation.
                            sdetweil @Guest
                            @sean how about a portrait photo sample…
                            the tv/monitor aspect ratio (16:9) doesn’t fit unless u stretch or clip the image…
                            the sunrise is 6000x4000 pixels the portrait photo is 4000x6000 (both WxH)
                              sdetweil @Guest
                              @sean but it distorts the picture, not in original format… which is what I want…
                                [[global:former-user]] @sdetweil
                                There are two options for vertical photos on horizontal screen.
                                • cover : whole screen will be covered by part of photos. but some areas(top and bottom) of photos will be out of screen
                                • contain : whole picture will be shown from bottom to top. but some remain area of screen (left and right) will be black.
                                  sdetweil @Guest
                                  @sean i understand… but BOTH distort the image presentation
                                    Which distortion? It’s just resizing.
                                      sdetweil @Guest
                                      @sean bingo… if something is clipped (not shown) then its wrong… I fiddled with all those css settings and finally gave up… i calculate the dimensions myself and all is good on EVERY picture
                                        Then you can use just contain mode .
                                        Here is my another module handling image - MMM-Rijks with same technic.
                                        It can show how contain trick works.
                                          sdetweil @Guest
                                          @sean ok, that doesn’t work for me… i am not background, i am foreground. (fullscreen above).
                                          if I set if on the module div or on the image, I get the same extreme zoom in.
                                            @sean With the module MM-Background Slideshow I have now added contain:
                                            	  slideshowSpeed: 5000,
                                                  randomizeImageOrder: true,
                                            	  backgroundSize: 'contain'
                                            The pictures now show it in the correct size. From the pictures, which were photographed in portrait format, it does not display correctly. Funny is that certain something in portrait mode.
                                            https://picload.org/view/dcocdwwl/20181115_1834321.jpg.html
                                            https://picload.org/view/dcocdwwc/20181115_1833561.jpg.html
                                            ? B 2 Replies Last reply Reply Quote 0
                                              @cyrus1337
                                              Each JPEG taken by modern digital camera has EXIF - direction information . Many picture viewers (in PC or Phone) can show the picture of right direction by automatic rotation with that information.
                                              But Most of Web Browser (including Electron/Chrome of MagicMirror) don’t have that feature yet.
                                              If your photos are stored in GooglePhotos or any other “SMART” clouds, the pictures will be stored with right direction when you saved. But… As I know that BackgroundSlideShow use your local directory. Browser cannot know right direction, then It display the picture as it was taken.
                                              I tried automatic rotation on MMM-DropboxWallpaper with EXIF, but not so satisfied. On browser level, it could’t be solved acceptably. Rotation on displaying could make unintended blank area, and Rotation of stored images on RPI needs too much CPU power.
                                              Solution: Rotate photos by manual with image editor in your POWERFUL PC then, save and use them.
