    Magic Mirror will not start
    8 Posts 2 Posters 2.9k Views 2 Watching
    • E Offline
      elporcho
      Trying to create a magic mirror with google home integration through the use of the voice kit (1.0). I had issues with npm not being present at first, thought i fixed that, got pm2 installed and tried to get everything running, but it wont start at all. Now i’m pretty lost. Thanks for the help.
        sdetweil @elporcho
        @elporcho ‘permission denied’ sounds like you used sudo npm install, which leaves files owned by root, not the normal pi user.
        Best to erase and start again
        • E Offline
          elporcho
          Sorry i’m pretty much a complete noob with linux. Should i be re-imaging the SD card, or is there a simpler way to clear out the installs i did wrong.
          Also, what should i do instead of “sudo npm install”? I just followed instructions as I saw them, so I’m not even sure which installation you’re referring to. Sorry for my ignorance.
            sdetweil @elporcho
            @elporcho from the home folder ( cd ~ ), do sudo -rf rm MagicMirror
            Then clone the mm repo again, then cd MagicMirror, then npm install
            • E Offline
              elporcho
              I appreciate the help. I did sudo -rf rm MagicMirror and it gave the the following error:
              rm: cannot remove ‘MagicMirror’: Is a directory
              I also tried rmdir, but it says Directory not empty.
              • E Offline
                elporcho
                Seems that I’ve got it re-installed, but now npm install still does nothing.
                • E Offline
                  elporcho
                  I was going to follow the instructions here for auto-starting magic mirror:
                  https://github.com/MichMich/MagicMirror/wiki/Auto-Starting-MagicMirror
                  • E Offline
                    elporcho
                    Huh, it appears the work i did before deleting and reinstalling the MagicMirror directory for the auto-start held over and it is working now. Thanks for dealing with me!
