    MagicMirror does not start anymore
    4 Posts 3 Posters 3.4k Views 2 Watching
    • ChrisC Offline
      Chris
      Hello everyone,
      I am coming to you because of a problem that I can not solve.
      I rebooted my magic mirror and relaunched it. While everything was working correctly until now, it shows me a black screen.
      I started this one with the command npm start dev and it shows me the following error:
      pi@raspberrypi:~/MagicMirror $ npm start dev
      > magicmirror@2.5.0 start /home/pi/MagicMirror
      > sh run-start.sh "dev"
      Starting MagicMirror: v2.5.0
      Loading config ...
      Loading module helpers ...
      No helper found for module: calendar_monthly.
      WARNING! Could not load config file. Starting with default configuration. Error found: Error: Cannot find module 'valid-url'
      App threw an error during load
          at Module._resolveFilename (module.js:543:15)
          at Function.Module._resolveFilename (/home/pi/MagicMirror/node_modules/electron/dist/resources/electron.asar/common/reset-search-paths.js:35:12)
          at Function.Module._load (module.js:473:25)
          at Module.require (module.js:586:17)
          at require (internal/module.js:11:18)
          at Object.<anonymous> (/home/pi/MagicMirror/modules/default/calendar/node_helper.js:9:16)
          at Object.<anonymous> (/home/pi/MagicMirror/modules/default/calendar/node_helper.js:80:3)
          at Module._compile (module.js:642:30)
          at Object.Module._extensions..js (module.js:653:10)
          at Module.load (module.js:561:32)
      { Error: Cannot find module 'valid-url'
          at Module.load (module.js:561:32) code: 'MODULE_NOT_FOUND' }
      Launching application.
      I made an update of my raspberry and made a npm install in the MagicMirror folder but that does not change anything.
      Could someone give me a track to solve this problem?
      Thanking you in advance,
      Regards,
        Try npm install valid-url from the Magic mirror folder
        ChrisC S 2 Replies Last reply Reply Quote 1
        • ChrisC Offline
          Chris @sdetweil
          Thank you for your answer.
          I tried install valid-urlbut it did not change anything.
          I solved the problem using a backup of the pi that I had (thankfully) done.
          I updated the pi and everything is working properly.
          this bug will definitely remain a mystery …
          Thank you for your help,
          Regards,
            stianhoe @sdetweil
            @sdetweil This worked for me after my MagicMirror refused to start. Thanks!
