Unsolved MagicMirror does not start anymore
Hello everyone,
I am coming to you because of a problem that I can not solve.
I rebooted my magic mirror and relaunched it. While everything was working correctly until now, it shows me a black screen.
I started this one with the command npm start dev and it shows me the following error:pi@raspberrypi:~/MagicMirror $ npm start dev > magicmirror@2.5.0 start /home/pi/MagicMirror > sh run-start.sh "dev" Starting MagicMirror: v2.5.0 Loading config ... Loading module helpers ... No helper found for module: alert. No helper found for module: calendar_monthly. WARNING! Could not load config file. Starting with default configuration. Error found: Error: Cannot find module 'valid-url' Loading module helpers ... No helper found for module: alert. No helper found for module: calendar_monthly. App threw an error during load Error: Cannot find module 'valid-url' at Module._resolveFilename (module.js:543:15) at Function.Module._resolveFilename (/home/pi/MagicMirror/node_modules/electron/dist/resources/electron.asar/common/reset-search-paths.js:35:12) at Function.Module._load (module.js:473:25) at Module.require (module.js:586:17) at require (internal/module.js:11:18) at Object.<anonymous> (/home/pi/MagicMirror/modules/default/calendar/node_helper.js:9:16) at Object.<anonymous> (/home/pi/MagicMirror/modules/default/calendar/node_helper.js:80:3) at Module._compile (module.js:642:30) at Object.Module._extensions..js (module.js:653:10) at Module.load (module.js:561:32) Whoops! There was an uncaught exception... { Error: Cannot find module 'valid-url' at Module._resolveFilename (module.js:543:15) at Function.Module._resolveFilename (/home/pi/MagicMirror/node_modules/electron/dist/resources/electron.asar/common/reset-search-paths.js:35:12) at Function.Module._load (module.js:473:25) at Module.require (module.js:586:17) at require (internal/module.js:11:18) at Object.<anonymous> (/home/pi/MagicMirror/modules/default/calendar/node_helper.js:9:16) at Object.<anonymous> (/home/pi/MagicMirror/modules/default/calendar/node_helper.js:80:3) at Module._compile (module.js:642:30) at Object.Module._extensions..js (module.js:653:10) at Module.load (module.js:561:32) code: 'MODULE_NOT_FOUND' } MagicMirror will not quit, but it might be a good idea to check why this happened. Maybe no internet connection? If you think this really is an issue, please open an issue on GitHub: https://github.com/MichMich/MagicMirror/issues Launching application.
I made an update of my raspberry and made a npm install in the MagicMirror folder but that does not change anything.
Could someone give me a track to solve this problem?
Thanking you in advance,
Regards,
Try
npm install valid-url
from the Magic mirror folder -
Thank you for your answer.
I triedinstall valid-url
but it did not change anything.
I solved the problem using a backup of the pi that I had (thankfully) done.
I updated the pi and everything is working properly.
this bug will definitely remain a mystery …Thank you for your help,
Regards, -
@sdetweil This worked for me after my MagicMirror refused to start. Thanks!
