    MMM-Hotword causing Mirror to blackout
    mmm-googleassistanthotwordblackscreen
    12 Posts 3 Posters 6.0k Views 3 Watching
      budddesilva
      Hi there, I’ve looked all over the forum for an answer to my problem. The MagicMirror works fine with the MMM-AssisstantMk2, I then added the Hotword module into the config file and the program starts… but just a black screen. This is what’s displayed on the terminal. Does anyone see what I’m doing wrong?
      > magicmirror@2.5.0 start /home/pi/MagicMirror
      > sh run-start.sh
      Starting MagicMirror: v2.5.0
      Loading config ...
      Loading module helpers ...
      WARNING! Could not load config file. Starting with default configuration. Error found: Error: Cannot find module 'node-record-lpcm16'
      App threw an error during load
          at Module._resolveFilename (module.js:543:15)
          at Function.Module._resolveFilename (/home/pi/MagicMirror/node_modules/electron/dist/resources/electron.asar/common/reset-search-paths.js:35:12)
          at Function.Module._load (module.js:473:25)
          at Module.require (module.js:586:17)
          at require (internal/module.js:11:18)
          at Object.<anonymous> (/home/pi/MagicMirror/modules/MMM-AssistantMk2/node_helper.js:8:16)
          at Object.<anonymous> (/home/pi/MagicMirror/modules/MMM-AssistantMk2/node_helper.js:409:3)
          at Module._compile (module.js:642:30)
          at Object.Module._extensions..js (module.js:653:10)
          at Module.load (module.js:561:32)
      { Error: Cannot find module 'node-record-lpcm16'
          at Module.load (module.js:561:32) code: 'MODULE_NOT_FOUND' }
      Launching application.
      ? 1 Reply Last reply
        budddesilva
        Hold on, I’m wrong here. I don’t think it’s the Hotword module causing the blackout. I just removed that part from the main config file and still get the same issue. I will try and look back in the forum related to MMM-AssistantMk2.
          A Former User @budddesilva
          @budddesilva
          It seems not installed properly. Some dependencies(like lpcm) are missed. Complete installation as documented carefully again.
          B 1 Reply Last reply
            budddesilva @Guest
            @sean
            Thank you for your reply. I did a fresh install of Raspbian Stretch, did all the updates and installed all the dependencies one by one. However, every time I add the default configuration for MMM-Hotword into the main config.js file… I get the black screen. I can safely say MMM-Hotword is the culprit because the mirror works fine without it in the config.js file. Do you have an idea of what’s causing this?
            This is what I have in my config.js file
            /* Magic Mirror Config Sample
             * MIT Licensed.
            var config = {
            	port: 8080,
            	language: "en",
            	timeFormat: 24,
            	units: "metric",
            			module: "alert",
            			module: "updatenotification",
            			position: "top_bar"
            			module: "clock",
            			position: "top_left"
            			header: "US Holidays",
            						symbol: "calendar-check-o ",
              			module: "MMM-AssistantMk2",
                			       	   record: {
            				   recordProgram: "arecord",
            				   device: "plughw:1",
            				notifications: {
            				   ASSISTANT_ACTIVATED: "HOTWORD_PAUSE",
            				   ASSISTANT_DEACTIVATED: "HOTWORD_RESUME",
              module: "MMM-Hotword",
              config: {}
            			module: "compliments",
            			position: "lower_third"
            			module: "currentweather",
            				locationID: "2193734",  //ID from http://bulk.openweathermap.org/sample/; unzip the gz file and find your city
            				appid: "3469461386627eaa3c97129ab3bc70ba"
            			module: "newsfeed",
            			position: "bottom_bar",
            				feeds: [
            						title: "New York Times",
            				showSourceTitle: true,
            				showPublishDate: true
            The error I get when running the mirror with the Hotword module says it cannot find the snowboy module… I didn’t have any problems when I installed snowboy. I rebuilt this without any problems using the code below.
            cd ~/MagicMirror/modules/MMM-Hotword/node_modules/snowboy
            npm install --save-dev electron-rebuild
            npm install nan
            ./node_modules/.bin/electron-rebuild
            ERROR WHEN RUNNING MIRROR WITH HOTWORD MODULE
            > sh run-start.sh
            Loading config ...
            Module helper loaded: MMM-AssistantMk2
            WARNING! Could not load config file. Starting with default configuration. Error found: Error: Cannot find module 'snowboy'
                at Object.<anonymous> (/home/pi/MagicMirror/modules/MMM-Hotword/node_helper.js:10:18)
                at Object.<anonymous> (/home/pi/MagicMirror/modules/MMM-Hotword/node_helper.js:115:3)
            { Error: Cannot find module 'snowboy'
              You should be doing npm install in the MMM-AssistantMk2 folder
                budddesilva
                Thanks for the reply @sdetweil . So, do you mean like… ?
                cd ~/MagicMirror/modules/MMM-AssistantMk2
                npm install nan
                  Yes, but I don’t think u need that last command. The package.json in the module folder is used for installing the dependencies at the right level. U might have to delete the MMM-AssistantMk2/node_modules folder to get it done cleanly
                    @budddesilva said in MMM-Hotword causing Mirror to blackout:
                    Error: Cannot find module ‘snowboy’
                    This says you didn’t (or failed) npm install of modules. snowboy is included in MMM-Hotword and you havn’t installed it completely. Was there any suspicious error when you install MMM-Hotword?
                      budddesilva
                      Ok. These are the steps I took.
                      1. Removed the MMM-AssistantMk2/node_modules folder.
                      2. npm install in the MMM-AssistantMk2 folder
                        npm install nan
                      3. Received the following error
                      WARNING! Could not load config file. Starting with default configuration. Error found: Error: Failed to load gRPC binary module because it was not installed for the current system
                      Expected directory: electron-v2.0-linux-arm-glibc
                      Found: [node-v67-linux-arm-glibc]
                      This problem can often be fixed by running "npm rebuild" on the current system
                      Original error: Cannot find module '/home/pi/MagicMirror/modules/MMM-AssistantMk2/node_modules/grpc/src/node/extension_binary/electron-v2.0-linux-arm-glibc/grpc_node.node'
                      1. Ran the npm rebuild command in the MMM-AssistantMk2 folder
                      2. Still the same error as before.
                      3. Ran the npm rebuild command in the MMM-AssistantMk2 > node_modules folder
                      4. Still the same error as before.
                      What do you think @sdetweil ?
                        @budddesilva
                        sudo apt-get update
                        sudo apt-get upgrade
                        sudo apt-get install build-essentials
                        sudo apt-get install gcc-5
                        do this first.
                        Then,
                        sudo apt-get install libasound2-dev sox libsox-fmt-all
                        Then,
                        I wish you have a luck. Happy holidays.
                          budddesilva
                          Hi @Sean
                          Thank you for your input. I ran through all the commands you gave without any problems. Had to change the “essentials” to “essential”.
                          But, now I get the previous error I had received.
                          WARNING! Could not load config file. Starting with default configuration. Error found: Error: Cannot find module ‘snowboy’.
                            @budddesilva
                            That is another issue. snowboy is related with MMM-Hotword, and that error says you didn’t or failed proper installation of that module. Read the instructions of installation.
