    MMM-Hotword causing Mirror to blackout
    mmm-googleassistanthotwordblackscreen
    12 Posts 3 Posters 5.0k Views 3 Watching
      You should be doing npm install in the MMM-AssistantMk2 folder
        budddesilva
        Thanks for the reply @sdetweil . So, do you mean like… ?
        cd ~/MagicMirror/modules/MMM-AssistantMk2
        npm install --save-dev electron-rebuild
        npm install nan
        ./node_modules/.bin/electron-rebuild
          Yes, but I don’t think u need that last command. The package.json in the module folder is used for installing the dependencies at the right level. U might have to delete the MMM-AssistantMk2/node_modules folder to get it done cleanly
            A Former User @budddesilva
            @budddesilva said in MMM-Hotword causing Mirror to blackout:
            Error: Cannot find module ‘snowboy’
            This says you didn’t (or failed) npm install of modules. snowboy is included in MMM-Hotword and you havn’t installed it completely. Was there any suspicious error when you install MMM-Hotword?
              budddesilva
              Ok. These are the steps I took.
              1. Removed the MMM-AssistantMk2/node_modules folder.
              2. npm install in the MMM-AssistantMk2 folder
                npm install nan
              3. Received the following error
              WARNING! Could not load config file. Starting with default configuration. Error found: Error: Failed to load gRPC binary module because it was not installed for the current system
              Expected directory: electron-v2.0-linux-arm-glibc
              Found: [node-v67-linux-arm-glibc]
              This problem can often be fixed by running "npm rebuild" on the current system
              Original error: Cannot find module '/home/pi/MagicMirror/modules/MMM-AssistantMk2/node_modules/grpc/src/node/extension_binary/electron-v2.0-linux-arm-glibc/grpc_node.node'
              1. Ran the npm rebuild command in the MMM-AssistantMk2 folder
              2. Still the same error as before.
              3. Ran the npm rebuild command in the MMM-AssistantMk2 > node_modules folder
              4. Still the same error as before.
              What do you think @sdetweil ?
                @budddesilva
                sudo apt-get update
                sudo apt-get upgrade
                sudo apt-get install build-essentials
                sudo apt-get install gcc-5
                do this first.
                Then,
                sudo apt-get install libasound2-dev sox libsox-fmt-all
                Then,
                I wish you have a luck. Happy holidays.
                  budddesilva
                  Hi @Sean
                  Thank you for your input. I ran through all the commands you gave without any problems. Had to change the “essentials” to “essential”.
                  But, now I get the previous error I had received.
                  WARNING! Could not load config file. Starting with default configuration. Error found: Error: Cannot find module ‘snowboy’.
                    @budddesilva
                    That is another issue. snowboy is related with MMM-Hotword, and that error says you didn’t or failed proper installation of that module. Read the instructions of installation.
