    Is there a way . . .
    23 Posts 8 Posters 11.5k Views 8 Watching
      A Former User @BKeyport
      @bkeyport
      In modern CSS, you can use variables. If you are using values referenced frequently or dependently, you can set that value as variables.
      In prior example, --body-margin is defined. Now you can use it instead static fixed value 20px. So when you have to change that value, just modify --body-margin once.
      • BKeyportB Offline
        BKeyport Module Developer
        This is the part that’s getting me…
        width: calc(100vh - var(–body-margin) * 2);
        height: calc(100vw - var(–body-margin) * 2);
        If I’m reading this correctly - it’s taking the calculation of 100% of the viewpoint(direction) - the margin defined in the varible multiplied by 2?
        100% of the viewport height minus 40 pixels in your example?
        ? S 2 Replies Last reply Reply Quote 0
          @bkeyport
          Yes. you are right.
          Just one point, user-defined property should be start with -- not -
            sdetweil @BKeyport
            @bkeyport margin is both sides, or top and bottom. All the way around.
            If u look at the original the width is hard coded at 100%- 2 times the margin value
            • BKeyportB Offline
              @sdetweil so, then because I have to use the following:
              body {
              margin: 0px;
              height: calc(100vh - 10px);
              width: calc(100vw - 5px);
              am I correct in assuming that magicmirror sees the screen a few pixels bigger than it really is - and that’s being expressed by running off the right and bottom of the screen when I don’t have the 10px subtract from height, and the 5px subtract from width?
              S michael5rM 2 Replies Last reply Reply Quote 0
                sdetweil @BKeyport
                @bkeyport I also had a heck of a time modifying body to get a fullscreen image.
                I finally changed to use the .fullscreen.above css setting. I was also worried that if I required body to be changed and some else’s module also required body changed, then the conflict would mess up my display.
                • michael5rM Offline
                  michael5r Module Developer @BKeyport
                  @bkeyport said in Is there a way . . .:
                  body {
                  margin: 0px;
                  No - the screen is the size it is.
                  Your CSS above doesn’t make sense (you’re setting a body height that’s 10px smaller than the window height). If you set the body height to be 100vh and you get a vertical scrollbar, it’s because of another margin that’s pushing the body element.
                  In general, it’s good practice to also do:
                  html {
                      margin: 0;
                      padding: 0;
                  to avoid situations like this.
                  • BKeyportB Offline
                    BKeyport Module Developer @michael5r
                    @michael5r - Actually, I don’t get scrollbars at all. If I don’t subtract back from the 100vh/100vw or 100% - It’ll just run off the edge of the screen as if the system is seeing the screen (In this case, the RasPi’s 7" touchscreen) bigger than it is. With it set the way I have it, everything is dead on edge, giving the maximum use of the screen.
                    michael5rM 1 Reply Last reply Reply Quote 0
                      I’m glad it works for you, but it still doesn’t make any sense :)
                        j.e.f.f Project Sponsor Module Developer @michael5r
                        @michael5r the CSS is also set to hide overflow on the body so even if the CSS defines a screen size larger than 100% you won’t get scroll bars. You’ll just get the contents pushing off screen or at least not centred.
                          michael5r Module Developer @j.e.f.f
                          @j-e-f-f Sure, that’s the magic of the overflow: hidden style. But what puzzles me is this:
                          An example:
                          If you run a webpage in fullscreen mode (either through Electron using Chromium or in a regular browser), and style the body like this:
                          body {
                              background-color: #333;
                              width: 100vw;
                              height: 100vh;
                              padding: 0;
                              margin: 0;
                              overflow: hidden;
                          you will have a grey area that takes up the entire width & height of your screen.
                          If, on the other hand, you styled the body tag like this:
                          body {
                              width: calc(100vw-10px);
                              height: calc(100vh-10px);
                              padding: 0;
                              margin: 0;
                              overflow: hidden;
                          you will have a grey area that is 10px shorter and narrower than the available screen space.
                          The only reason this wouldn’t be the case is if the html tag has a margin or padding (which would restrict the amount of space available to the body tag) or if you’ve specified a specific screen size directly in Electron (using electronOptions.width and electronOptions.height).
                          It’s no different than the standard body styles defined in MagicMirror’s main.css file - in there, a margin of 60px is set and then the height & width are set with width: calc(100%-120px) and height: calc(100%-120px) respectively.
