    MMM-voice ugly hdmi banner
    Scheduled Pinned Locked Moved Feature Requests
    42 Posts 3 Posters 26.5k Views 3 Watching
      sdetweil @dazza120
      @dazza120 the tv is an energystar device. which will show the ugly no input screen until the energyStar timeout (15 minutes) and then power off…
      that is what the HIDE setting on my MMM-SleepWake module does. it blanks the screen, instead of turn off the signal.
        dazza120 @sdetweil
        @sdetweil cheers but I had to leave MMM-SleepWake as I didn’t have a clue how to install the motion project, the more I looked at it the more my tiny brain 🧠 started to smoke 🤯
          sdetweil @dazza120
          @dazza120 https://motion-project.github.io/motion_build.html
          To install via apt, open up a terminal window and type: sudo apt-get install motion
            dazza120 @sdetweil
            @sdetweil said in MMM-voice ugly hdmi banner:
            Your joking! So is that the packaged installed with that command? As what I was looking at was totally different to this. Thanks for your help.
              sdetweil @dazza120
              @dazza120 from github project page
              Motion, a software motion detector. Home page: https://motion-project.github.io/
              click documentation and then
              https://motion-project.github.io/motion_guide.html
                dazza120 @sdetweil
                @sdetweil i have followed it as best as i could i have the package installed and have located the motion folder in my user directory but for the life of me i cant find this motion.conf file to insert your script.
                  motion config is done in /etc/motion/motion.conf
                  i just added a line in the readme about that
                    dazza120 @sdetweil
                    @sdetweil thank you, i have located it with your help, ill work on this when im not at work thanks, so its just a case of adding one of your scripts? think ill just use the start one
                      sdetweil @dazza120
                      @dazza120 its just one script… external_motion… you pass it a parm, started or ended
                      you need to configue both started and ended, else it can’t sleep thinking motion is still going on
                      note that because it is in the /etc folder tree, you must use sudo in front of your editor to get write permission
                        dazza120 @sdetweil
                        @sdetweil motion.conf won’t let me edit it, or rather the pi won’t any way around this?
                          sudo nano /etc/motion/motion.conf
                          nano or whatever editor you choose…
                            also just noticed that the execute bit is not set on the script… SO
                            cd modules/MMM-SleepWake
                            chmod +x external_motion
                              dazza120 @sdetweil
                              @sdetweil so is it just this part i need to put on_event_start /home/pi/MagicMirror/modules/MMM-SleepWake/external_motion started
                                sdetweil @dazza120
                                @dazza120 correct… and right below it the same with ended as the parm for the motion ended notice
                                  dazza120 @sdetweil
                                  @sdetweil im leaving it with the ; in the command line?
                                    sdetweil @dazza120
                                    @dazza120 the example doesn’t have ;
                                    on_event_start /home/{userid}/MagicMirror/modules/MMM-SleepWake/external_motion started
                                      dazza120 @sdetweil
                                      @sdetweil no it this is what its like i hope this is correct?
                                      # Command to be executed when an event starts. (default: none)
                                      # An event starts at first motion detected after a period of no motion defined $
                                      ; on_event_start /home/pi/MagicMirror/modules/MMM-SleepWake/external_motion sta$
                                      # Command to be executed when an event ends after a period of no motion
                                      # (default: none). The period of no motion is defined by option event_gap.
                                      ; on_event_end value /home/pi/MagicMirror/modules/MMM-SleepWake/external_motion$
                                        ok, that ; is a comment in the motion conf file, just like #… have to remove it
                                        note that the on event end has an extra token there that neds to be removed
                                        on_event_end value
                                          dazza120 @sdetweil
                                          @sdetweil yes it is do i have to remove the # aswell?
                                            sdetweil @dazza120
                                            @dazza120 no, there is no # on those two lines
