    MMM-voice ugly hdmi banner
    Scheduled Pinned Locked Moved Feature Requests
    42 Posts 3 Posters 26.5k Views 3 Watching
      sdetweil @dazza120
      @dazza120 https://motion-project.github.io/motion_build.html
      To install via apt, open up a terminal window and type: sudo apt-get install motion
        dazza120 @sdetweil
        @sdetweil said in MMM-voice ugly hdmi banner:
        Your joking! So is that the packaged installed with that command? As what I was looking at was totally different to this. Thanks for your help.
          sdetweil @dazza120
          @dazza120 from github project page
          Motion, a software motion detector. Home page: https://motion-project.github.io/
          click documentation and then
          https://motion-project.github.io/motion_guide.html
            dazza120 @sdetweil
            @sdetweil i have followed it as best as i could i have the package installed and have located the motion folder in my user directory but for the life of me i cant find this motion.conf file to insert your script.
              motion config is done in /etc/motion/motion.conf
              i just added a line in the readme about that
                dazza120 @sdetweil
                @sdetweil thank you, i have located it with your help, ill work on this when im not at work thanks, so its just a case of adding one of your scripts? think ill just use the start one
                  sdetweil @dazza120
                  @dazza120 its just one script… external_motion… you pass it a parm, started or ended
                  you need to configue both started and ended, else it can’t sleep thinking motion is still going on
                  note that because it is in the /etc folder tree, you must use sudo in front of your editor to get write permission
                    dazza120 @sdetweil
                    @sdetweil motion.conf won’t let me edit it, or rather the pi won’t any way around this?
                      sudo nano /etc/motion/motion.conf
                      nano or whatever editor you choose…
                        also just noticed that the execute bit is not set on the script… SO
                        cd modules/MMM-SleepWake
                        chmod +x external_motion
                          dazza120 @sdetweil
                          @sdetweil so is it just this part i need to put on_event_start /home/pi/MagicMirror/modules/MMM-SleepWake/external_motion started
                            sdetweil @dazza120
                            @dazza120 correct… and right below it the same with ended as the parm for the motion ended notice
                              dazza120 @sdetweil
                              @sdetweil im leaving it with the ; in the command line?
                                sdetweil @dazza120
                                @dazza120 the example doesn’t have ;
                                on_event_start /home/{userid}/MagicMirror/modules/MMM-SleepWake/external_motion started
                                  dazza120 @sdetweil
                                  @sdetweil no it this is what its like i hope this is correct?
                                  # Command to be executed when an event starts. (default: none)
                                  # An event starts at first motion detected after a period of no motion defined $
                                  ; on_event_start /home/pi/MagicMirror/modules/MMM-SleepWake/external_motion sta$
                                  # Command to be executed when an event ends after a period of no motion
                                  # (default: none). The period of no motion is defined by option event_gap.
                                  ; on_event_end value /home/pi/MagicMirror/modules/MMM-SleepWake/external_motion$
                                    ok, that ; is a comment in the motion conf file, just like #… have to remove it
                                    note that the on event end has an extra token there that neds to be removed
                                    on_event_end value
                                      dazza120 @sdetweil
                                      @sdetweil yes it is do i have to remove the # aswell?
                                        sdetweil @dazza120
                                        @dazza120 no, there is no # on those two lines
                                          dazza120 @sdetweil
                                          @sdetweil no on the two lines above it
                                            sdetweil @dazza120
                                            @dazza120 no, those are comments to explain what these lines do
