    MMM-voice ugly hdmi banner
    Scheduled Pinned Locked Moved Feature Requests
    42 Posts 3 Posters 27.0k Views 3 Watching
      sdetweil @dazza120
      @dazza120 no, there is no # on those two lines
      D 1 Reply Last reply
        dazza120 @sdetweil
        @sdetweil no on the two lines above it
          sdetweil @dazza120
          @dazza120 no, those are comments to explain what these lines do
            dazza120 @sdetweil
            @sdetweil ok cool so this is how i have it now
            # Command to be executed when an event starts. (default: none)
            # An event starts at first motion detected after a period of no motion defined by event_gap
             on_event_start /home/pi/MagicMirror/modules/MMM-SleepWake/external_motion started
            # Command to be executed when an event ends after a period of no motion
            # (default: none). The period of no motion is defined by option event_gap.
             on_event_end /home/pi/MagicMirror/modules/MMM-SleepWake/external_motion ended
              sdetweil @dazza120
              @dazza120 looks good
                dazza120 @sdetweil
                @sdetweil thanks ive done this command chmod +x external_motion but i don’t see an outcome it just re turns to pi@raspberrypi:~/MagicMirror/modules/MMM-SleepWake
                whole commandline below
                pi@raspberrypi:~/MagicMirror/modules/MMM-SleepWake $ chmod +x external_motion
                  sdetweil @dazza120
                  @dazza120 right. That makes my script executable, so motion can execute it
                  Now u will see files appear in the MMM-SleepWake/motion folder
                  When the motion module detects motion, and when it ends.
                  My module uses those files
                  Reply Quote 2
                    @sdetweil u start the motion tool with sudo motion &
                    And u can see it’s actions in /var/log/motion/motion.log
                    The tail command will show you the last few lines (default 20) of a file
                    D 2 Replies Last reply
                    Reply Quote 2
                      dazza120 @sdetweil
                      @sdetweil i’ll have a look tomorrow, thanks very much for your help much appreciated for your help
                        dazza120 @sdetweil
                        @sdetweil not sure its supposed to look like this
                        pi@raspberrypi:~ $ sudo motion &
                        [1] 28276
                        pi@raspberrypi:~ $ [0:motion] [ALR] [ALL] conf_load: could not open configfile /usr/local/etc/motion/motion.conf: No such file or directory
                        [0:motion] [CRT] [ALL] conf_load: No config file to process, using default values
                        [0:motion] [NTC] [ALL] motion_startup: Using default log level (NTC) (6)
                        [0:motion] [NTC] [ALL] motion_startup: Logging to syslog
                        [0:motion] [NTC] [ALL] motion_startup: Motion 4.2.1+git20181209-7bd179c Started
                        [0:motion] [NTC] [ALL] motion_startup: Using default log type (ALL)
                        [0:motion] [NTC] [ALL] motion_startup: Using log type (ALL) log level (NTC)
                        [0:motion] [NTC] [ENC] ffmpeg_global_init: ffmpeg libavcodec version 57.64.101 libavformat version 57.56.101
                        [0:motion] [NTC] [ALL] translate_init: Language: English
                        [0:motion] [NTC] [ALL] motion_start_thread: Camera ID: 0 Camera Name: (null) Device: /dev/video0
                        [0:motion] [NTC] [ALL] main: Waiting for threads to finish, pid: 28281
                        [1:ml1] [NTC] [ALL] motion_init: Camera 0 started: motion detection Enabled
                        [1:ml1] [NTC] [VID] vid_start: Opening V4L2 device
                        [1:ml1] [NTC] [VID] v4l2_device_open: Using videodevice /dev/video0 and input -1
                        [1:ml1] [NTC] [VID] v4l2_device_capability: - VIDEO_CAPTURE
                        [1:ml1] [NTC] [VID] v4l2_device_capability: - READWRITE
                        [1:ml1] [NTC] [VID] v4l2_device_capability: - STREAMING
                        [1:ml1] [NTC] [VID] v4l2_input_select: Name = "ov534"- CAMERA
                        [1:ml1] [NTC] [VID] v4l2_norm_select: Device does not support specifying PAL/NTSC norm
                        [1:ml1] [NTC] [VID] v4l2_pixfmt_select: Configuration palette index 17 (YU12) for 640x480 doesn't work.
                        M 1 Reply Last reply
                          mdhenriksen @dazza120
                          @dazza120 Hey Dazza. Post it in the code-block you can use in the editor. Otherwise it’s hard to read your code/output.
                            dazza120 @mdhenriksen
                            @mdhenriksen not sure why it came out like that but i am doing it via vnc on my phone lol thank you that should be sorted now
                              sdetweil @dazza120
                              @dazza120 Hm… mine says
                              [-1191364720:motion] [NTC] [ALL] conf_load: Processing thread 0 - config file /etc/motion/motion.conf
                                dazza120 @sdetweil
                                @sdetweil hi for some reason I have no motion.conf file in there, but I was getting tones of video clips stored in /home/Pi folder, can you tell me the best remove command for motion project as I’ll start again from scratch and looking at one of the files in the home/Pi folder it said
                                Install complete! The default configuration file, motion-dist.conf, has been
                                installed to /usr/local/etc/motion. You need to rename/copy it to motion.conf
                                for Motion to find it. More configuration examples as well as init scripts
                                can be found in /usr/local/share/motion/examples.
                                  sdetweil @dazza120
                                  @dazza120 weird… if u installed with
                                  apt-get install motion
                                  then the command is
                                  apt-get --purge remove motion
                                    dazza120 @sdetweil
                                    @sdetweil thanks done that, i seem to have a motion folder in this location /usr/local/etc/motion is the a folder that the pi had before do you know?
                                      sdetweil @dazza120
                                      @dazza120 that is what u posted in the prior message
                                      • 2 / 3
