sendNotification help
6 Posts 2 Posters 2.0k Views 3 Watching
    jasondreher
    I want to be able to send a value to https://github.com/mykle1/MMM-EventHorizon to change the time used in a count down timer. Right now I can make the module hide with…
    this.sendNotification('HIDE_TIMER');
    but I cant seem to do much more, how do I change my sendNotification to include a payload to change the date and time in MMM-EventHorizon. I will have to change the notificationReceived in MMM-EventHorizon to I assume…
    S 1 Reply Last reply Jan 18, 2019, 4:29 PM Reply Quote 0
      sdetweil @jasondreher
      @jasondreher just add the payload on to the api call like this
      this.sendNotification('HIDE_TIMER', payload);
      ‘payload’ can be anything… a variable (this.variable_name), a literal(‘some literal string’), a dynamically constructed value (‘some value’ + variable_name + ’ right now ')
      the receiving modules sendNotificationReceived(code, payload, sender) function is responsible for ignoring or processing the payload data according to the shared rules of the sender
        jasondreher
        OK so I change my sendNotification to
        this.sendNotification('SHOW_TIMER','18:25:25');
        and the MMM-EventHorizon notificationReceived to
            notificationReceived: function(notification, payload) {
                if (notification === 'HIDE_TIMER') {
                    this.hide(1000);
                } else if (notification === 'SHOW_TIMER') {
                    this.show(1000);
                    this.time = payload //I added this
                    this.updateDom();  //I added this
        Thinking the paylaod will update the countdown time but it does nothing… Not sure what I am doing worng. I have tested this quite a few different ways and searched quite a bit…
        I can tell its doing something as it flickers (like it is refreshing with the updateDom) but the countdown does not reflect the new time.
        S 1 Reply Last reply Jan 18, 2019, 5:17 PM Reply Quote 0
          @jasondreher you didn’t use the payload. Just hide and show. I don’t know the other module.
          But I would guess u need to start a timer with some elapsed time til the action (from now)
            jasondreher
            @jasondreher said in sendNotification help:
            this.time = payload
            I added “this.time = payload”, this is using the payload correct?
              this.time = payload
              probably
              this.config.time = payload
